#121
Dudley Henriques writes:
80 isn't all that bad for a normal takeoff in a 182. Sea Level Vy for the airplane if I remember is right around 78kts? Been a long time :-) Hmm ... in that case I guess I'm doing okay. I like having airspeed. Hang in there. You're doing fine! Well, my last 767 flight (and most 767 flights before that) ended in tragedy. I've only managed two decent landings, and they were both autolands. It seems that 767s just don't want to descend. However, I just managed a very clean flight in the 182, VFR at night no less. |
#122
Nomen Nescio writes:
You panic quite easily, don't you? Not at all. BTW, panic in the air will kill you just as fast as panic in the water. I'm not prone to panic in the air. |
#123
On Aug 17, 1:37 am, Mxsmanic wrote:
Nomen Nescio writes: You panic quite easily, don't you? Not at all. BTW, panic in the air will kill you just as fast as panic in the water. I'm not prone to panic in the air. I have a friend like that, one helluva nice guy, but he has a hard time figuring out fact from fiction, he reads a novel and then believes it was his own personal experience, and that becomes part of his memory of something he actually did. The shrinks likely have a name for that specific syndrome. Of course everyone has an issue with deciding fact from fiction, so I guess it's a matter of degree. Ken |
#124
"Ken S. Tucker" wrote in
: On Aug 17, 1:37 am, Mxsmanic wrote: Nomen Nescio writes: You panic quite easily, don't you? Not at all. BTW, panic in the air will kill you just as fast as panic in the water. I'm not prone to panic in the air. I have a friend like that, one helluva nice guy, but he has a hard time figuring out fact from fiction, he reads a novel and then believes it was his own personal experience, and that becomes part of his memory of something he actually did. The shrinks likely have a name for that specific syndrome. Of course everyone has an issue with deciding fact from fiction, so I guess it's a matter of degree. yeah, a "friend" Bertie |
#125
#126
#127
On Aug 16, 6:08*pm, "Ken S. Tucker" wrote:
On Aug 16, 2:27 pm, Mxsmanic wrote: Ken S. Tucker writes: Ok, have you ever been in a sail boat? No. Well you must try it. Your doing a tack with the sail fully stable suckin' energy from the wind, cuttin' water and bouncin' waves off the starboards, that's the sound you hear. Next, you reverse tact and the sail flutters (stalls) until re-acquistion of stability going in nearly the opposite direction and you're still heading into the wind, so the net motion is into the wind. Every pilot should do that. I was on trapeze, *with a good fat old captain on the til, and me being a skinny lively bitch loved jumped to either side of the boat, pulling the sail to max the energy out of the wind. Regards Ken PS: Read about it. On our boat we put the crew to the windward side to keep the mast more vertical. We adjust the sail by pulling on the correct strings, and it depends on the tack as to which is the lee rail going awash. As for stalling a sail -- on a beat there's lots of flow separation on the low pressure side of the sail, but it continues to drive the boat. The luffing at the trailing edge just means there's marginal flow separation there, not at the leading edge. If you want to really see a sail stall, do a jibe, not a come about. If you don't duck you'll learn soon enough why the part sweeping across the cockpit is called a boom. |
#128
![]() "Jim Logajan" wrote in message .. . I may actually try creating a Google Groups piloting group as a final experiment. No offense (honest), but why would I want you as my moderator? I don't even know you, and your unsolicited offer to appoint yourself does nothing to give me confidence. Vaughn |
#129
Mxsmanic wrote:
Nomen Nescio writes: You panic quite easily, don't you? Not at all. Right, that's why you've almost drowned several times when all you had to do was relax, lean your head back, and float. I'm not prone to panic in the air. Right. -- Jim Pennino Remove .spam.sux to reply. |
#130
Google Groups Beta | Steven P. McNicoll | Piloting | 27 | June 10th 05 02:33 PM |
Posting via Google Groups | jim rosinski | Piloting | 7 | February 4th 05 08:13 PM |
The New Google Groups Interface | [email protected] | Soaring | 2 | December 13th 04 06:29 AM |
