Kyle gets the mini lathe home and then what??? btw "Kyle" in this context is just a name for any one of us. OK you get your mini lathe home then what? first thing you discover is that it just sits there inert on the bench. then you start wondering just how you go about actually making anything on the lathe. after all it just spins stuff around and you have to wind the knobs. it doesnt take long for you to totally disbelieve the comment that the lathe is the king of tools. (it is btw but only after you know how to use it) what you need to do is spend the next few nights in the workshop (oh it probably isnt one of those yet so you'll just be working in the shed with all the gardening tools, or in a back room) what you've got to do is to look at the lathe, play with it a bit, oil it, play with it a bit more and cogitate. what you wont realise until later is that you have embarked on a change in the way you are going to think about everything around you. instead of looking at a widget as something that you buy in harbour freight your transformation process will lead you to seeing everything as assemblies of parts. each part being made from materials by a sequential set of steps which does the michaelangelo thing to the raw materials eventually generating swarf, a bin full of mistakes, and some usable parts. oh michaelangelo... was once asked how he carved a statue.' I look at the block of stone and see in my minds eye a statue, then I carve away everything that isnt the statue.' it really is that simple ....eventually. when you finally understand the use of your lathe you will find that you look at something like a pratt and whitney(sp?) radial engine as just a thousand bits made by sequential processes. making one just requires you to draw out all the sizes on paper or in a CAD program to make sure they will all work together, and then pick the most interesting bit, get the materials together and then work out which is the first step and most importantly of all, actually get started. for a doodle around project as your first bit of machining I might suggest making yourself 3 little plumb bobs. you need about 8ft of string on each one. you can make them quite easily to a better quality than you can buy them. once you've made them you hang one off the leading edge of your wing on each side of the aircraft about a foot out from the side of the fuselage. run a piece of masking tape acoss the floor between the plumb bobs then draw an accurate pencil line between the plumb bobs. that is the datum. leave one plumb bob in place so you can check that the aircraft hasnt moved. you then hang one off the centre of the firewall. you hang the third one under the tail. masking tape and pencil line between the two plumb bobs and you have the centreline of the aircraft. being a resourceful guy I'll let you work out the rest of the details in redoing your aircraft weight and balance. it isnt hard and doing the job with 3 plumb bobs you've made yourself is quite neat. :-) like the zen monk that I am I've told you everything and yet I've told you nothing. the process of understanding how to make stuff on your lathe will take a while. making mistakes is an essential part of the process. be patient, be persistent and ask questions when you get stuck. Stealth Pilot (who spent the day making patterns and reconditioning his casting green sand in readiness for the day of propeller melting that is coming up soon.) |
Stealth Pilot wrote:
Kyle gets the mini lathe home and then what??? btw "Kyle" in this context is just a name for any one of us. OK you get your mini lathe home then what? first thing you discover is that it just sits there inert on the bench. then you start wondering just how you go about actually making anything on the lathe. after all it just spins stuff around and you have to wind the knobs. it doesnt take long for you to totally disbelieve the comment that the lathe is the king of tools. (it is btw but only after you know how to use it) what you need to do is spend the next few nights in the workshop (oh it probably isnt one of those yet so you'll just be working in the shed with all the gardening tools, or in a back room) what you've got to do is to look at the lathe, play with it a bit, oil it, play with it a bit more and cogitate. what you wont realise until later is that you have embarked on a change in the way you are going to think about everything around you. instead of looking at a widget as something that you buy in harbour freight your transformation process will lead you to seeing everything as assemblies of parts. each part being made from materials by a sequential set of steps which does the michaelangelo thing to the raw materials eventually generating swarf, a bin full of mistakes, and some usable parts. oh michaelangelo... was once asked how he carved a statue.' I look at the block of stone and see in my minds eye a statue, then I carve away everything that isnt the statue.' it really is that simple ...eventually. when you finally understand the use of your lathe you will find that you look at something like a pratt and whitney(sp?) radial engine as just a thousand bits made by sequential processes. making one just requires you to draw out all the sizes on paper or in a CAD program to make sure they will all work together, and then pick the most interesting bit, get the materials together and then work out which is the first step and most importantly of all, actually get started. for a doodle around project as your first bit of machining I might suggest making yourself 3 little plumb bobs. you need about 8ft of string on each one. you can make them quite easily to a better quality than you can buy them. once you've made them you hang one off the leading edge of your wing on each side of the aircraft about a foot out from the side of the fuselage. run a piece of masking tape acoss the floor between the plumb bobs then draw an accurate pencil line between the plumb bobs. that is the datum. leave one plumb bob in place so you can check that the aircraft hasnt moved. you then hang one off the centre of the firewall. you hang the third one under the tail. masking tape and pencil line between the two plumb bobs and you have the centreline of the aircraft. being a resourceful guy I'll let you work out the rest of the details in redoing your aircraft weight and balance. it isnt hard and doing the job with 3 plumb bobs you've made yourself is quite neat. :-) like the zen monk that I am I've told you everything and yet I've told you nothing. the process of understanding how to make stuff on your lathe will take a while. making mistakes is an essential part of the process. be patient, be persistent and ask questions when you get stuck. Stealth Pilot (who spent the day making patterns and reconditioning his casting green sand in readiness for the day of propeller melting that is coming up soon.) http://lineymachine.googlepages.com/ and companies like that sell plans and kits for steam engines. Some are very simple and all can be built from basic stock without castings. If nothing else they are confidence building exercises for beginners. Liney assumes you have a basic understanding how lathe and mills work. There are videos on youtube that show one how to do basic work. Sherline has a page on how to sharpen lathe tools. I do suggest modifying a trash bag to cover the machine when not in use. If one isn't going to use it for awhile the lathe will serve as a dust magnet. One of my pet peeves about many homebuilt aircraft I have seen there are rows of identical toggle switches. One could make knobs for them with different shapes to provide tactile cues. It's cheaper than buying such switches. Dan, U.S. Air Force, retired |
"Dan" wrote . There are videos on youtube that show one how to do basic work. Good point! I had never thought of that! I had unlimited access to a full sized Taiwan knock-off for a while at school, and nobody knew anything about running it, so I taught myself a few things. Since the ag teacher that had it in his shop didn't know how to use it, it went off to surplus sales. I made a few adapters for some scaffolding, and a few other machine parts, and got so I was not totally incompetent, but I knew I was incompetent enough to not want to make anything on it for an airplane! g I might have to get a small (but not too small) lathe sometime in the next year or two, and get with someone that can teach me how to properly use it to make some things my life would depend on. Even some self study books would go a long way toward learning some good basics, and then go from there with some more advanced learning. I could probably get into a machine shop class at the local community college. They seem to have a pretty good shop, but I don't know anything about the teacher. And yes, I could see how you could get hooked, in a hurry! -- Jim in NC |
On Aug 17, 12:21 pm, "Morgans" wrote:
"Dan" wrote . There are videos on youtube that show one how to do basic work. Good point! I had never thought of that! I had unlimited access to a full sized Taiwan knock-off for a while at school, and nobody knew anything about running it, so I taught myself a few things. Since the ag teacher that had it in his shop didn't know how to use it, it went off to surplus sales. I made a few adapters for some scaffolding, and a few other machine parts, and got so I was not totally incompetent, but I knew I was incompetent enough to not want to make anything on it for an airplane! g I might have to get a small (but not too small) lathe sometime in the next year or two, and get with someone that can teach me how to properly use it to make some things my life would depend on. Even some self study books would go a long way toward learning some good basics, and then go from there with some more advanced learning. I could probably get into a machine shop class at the local community college. They seem to have a pretty good shop, but I don't know anything about the teacher. And yes, I could see how you could get hooked, in a hurry! -- Jim in NC I got spoiled by 12 years of running decent lathes and other stuff for a living in the machine shop, and my own 13 x 36 at home. Made up to $40 an hour with that one. Then we moved and I sold all that stuff and now, in the shop at work, we have an ancient South Bend 9" belt-driven machine that is horrible, and a Bridgeport knee mill that's wonderful. One of these days I'd like to get another Taiwanese lathe at home, not one of those little tiny Chinese toy lathes. My projects tend to be too big for machines like that, and light lathes can't maintain accuracy because they flex too much under load. Dan |
Kyle gets the mini lathe home and then what??? snip Years ago the father of good friend was a retired tool and die maker and had taught machine shop in a community college. At the time I had access to a lathe and didn't have a clue how to use it. His suggestion was to buy some closet dowel and start my experimenting on that. His reasoning was that I wouldn't ruin any cutting tools and the doweling was pretty cheap. I too am in the market for a lathe but I need something large enough to turn some wheel hubs and disk brake carriers. Tony |
"Stealth Pilot" wrote in message ... Kyle gets the mini lathe home and then what??? I got a new mini-lathe? Cool!! Um, where did I put it? Anyone seen a mini-lathe around here? Actually, I wish I already had one. I need to fabricate a prop balancing rig and a mini-lathe would be the ideal tool to make the little fittings I need. Fortunately, I have buddies who DO have lathes, so all I need to do is sketch out what I need and I can probably get the part made in a day or so... |
"Dan" == Dan writes:
Dan There are videos on Dan youtube that show one how to do basic work. http://www.youtube.com/watch?v=DGszB...eature=related Metal forming on a lathe is a beautiful thing. Somewhere on youtube-- perhaps the same fellow as the above link--is how to make an aluminum aircraft spinner from a flat aluminum circle. Truly an art form. -- In spite of everything I still believe that people are really good at heart. ~ Anne Frank, holocaust victim |
"Dan" wrote A show on television showed a lathe turning a drive shaft for an aircraft carrier. Now that was a tad too large for me. How about a milling machine large enough to profile and balance an aircraft carrier propeller? Yep, a bit big for me, too. I wonder if that 4 foot lathe was used for truing compressor wheels from jet engines? -- Jim in NC |
Morgans wrote:
"Dan" wrote A show on television showed a lathe turning a drive shaft for an aircraft carrier. Now that was a tad too large for me. How about a milling machine large enough to profile and balance an aircraft carrier propeller? Can you imagine the click a breakaway torque wrench needed to tighten the nut holding that prop on would make? Yep, a bit big for me, too. I wonder if that 4 foot lathe was used for truing compressor wheels from jet engines? That would be depot level. The lathe I saw had a 4 foot bed, not 4 foot swing. Dan, U.S. Air Force, retired |
| Thread Tools | |
| Display Modes | |
| "...but I don't have a lathe." | [email protected] | Home Built | 47 | September 20th 08 01:53 AM |
| Kyle Welke | The Good Poster[_2_] | Aviation Photos | 0 | July 1st 07 10:22 PM |
| Phil Kyle R.I.P? | Michael Baldwin, Bruce | Products | 0 | December 14th 06 12:25 PM |
| So...does KYLE ever learn How to Fly??... | D. Reid | Home Built | 11 | November 5th 04 05:43 PM |
| Lathe Help | Bruce A. Frank | Home Built | 15 | February 7th 04 10:05 AM |
