(OT) lathes & mills : vocabulary questions
Old August 18th 08, 12:35 PM posted to rec.aviation.homebuilt
Default (OT) lathes & mills : vocabulary questions
On Aug 17, 4:05*pm, Charlie wrote:
snipped B) If correct on A, how to understand the dimensions? Perhaps a 36x9"
lathe has 36" between centers, and 9" is the max. diameter of basic
stock?
Right again. (well, the 9" is the distance from the bed to the center -
you may have trouble mounting 9"stock)
snipped
Minor correction: I believe that 'swing' is actually the maximum
diameter of the work. 9" swing would mean 4 1/2" between the bed (rails
that the tailstock moves on) and the centerline.
Charlie
It used to depend on the country but now everything I see for sale
seems to be max diameter turned. Bigger numbers sound better I guess.
Karl
Old August 18th 08, 10:55 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Charlie" wrote in message
snipped
stock?
snipped
Minor correction: I believe that 'swing' is actually the maximum diameter
of the work. 9" swing would mean 4 1/2" between the bed (rails that the
Yes, my mistake.
Geoff
Mini Lathes Kyle Boatright Home Built 11 August 18th 08 05:56 AM
Caddo Mills SW Soaring Closing 31 Dec [email protected] Soaring 10 December 14th 07 04:14 PM
PMA Questions Mike Granby Piloting 24 December 11th 05 11:24 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) Jim Yanik Military Aviation 2 October 9th 03 09:36 PM
