Preadator UAV's pass 400,000 flight hours
Old August 21st 08, 08:41 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Tiger
Default Preadator UAV's pass 400,000 flight hours
http://www.strategypage.com/htmw/hta.../20080821.aspx
Too Many Predators Are Not Enough
August 21, 2008: The U.S. MQ-1 Predator UAV has flown 400,000 hours. It
took its first ten years of service (including development) to reach
100,000 hours. But the last 100,000 hours took only ten months. Predator
is expected to reach 500,000 hours is less than five months. There are
about a hundred Predators in service, and they are averaging about 200
flight hours a month. That's over three times as much air time as jet
fighters get.
The Predators are mainly reconnaissance aircraft, but ones that are
capable to carrying out a relatively new airborne mission; surveillance
(keeping an eye on one patch of ground for an extended period).
Surveillance missions tie up a lot of airborne hours, but yield big
results on the ground, where lots of enemy activity can be observed
(especially at night). The army and marines have developed new tactics
to take advantage of these new reconnaissance and surveillance
capabilities. As more Predators become available, the ground troops put
them right to work. So far, too many Predators are not enough.
Last year, the U.S. Air Force has formed the first UAV Wing (the432nd).
The Wing began with six Predator and one maintenance squadrons. Each
Predator squadron has at least twelve UAVs, and sometimes as many as 24.
Squadrons have 400-500 personnel. Only about two thirds of those troops
go overseas with the UAVs. The rest stay behind in the United States,
and fly the Predators via a satellite link from (at the moment) five
different air force bases. The Wing expected to have its UAVs in the air
for at least 75,000 hours during its first year of operation. When in a
combat zone, each Predator averages up to 200 hours in the air each
month. Each aircraft flies 6-10 sorties a month, each one lasting 15-25
hours.
Wings, which are roughly the size of army brigades, are the largest
units in the air force, aside from the numbered air forces (1st Air
Force, 7th Air Force, and so on). There used be Air Divisions (composed
of two or more Wings), but these were phased out in the 1990s.
In another two years, the air force expects to have fifteen Predator
squadrons, and two or more Predator Wings. During that period it is
buying about a hundred MQ-1 Predators and MQ-9 Reapers. About a third of
the new UAVs will be Reapers.
While the Predator was a reconnaissance aircraft that could carry
weapons (two Hellfire missiles, each weighing a hundred pounds), the
Reaper was designed as a combat aircraft that also does reconnaissance.
The Reaper can carry over half a ton of GPS or laser guided bombs, as
well as the 250 pound SDB, or Hellfire missiles. The Predators cost
about $4.5 million each, while the Reaper goes for about $8.5 million
(although that can go a lot higher depending on what kind of sensors you
install).
The Reaper weighs about four times as much as a Predator, and carries
sensors equal to those found in targeting pods like the Sniper XL or
Litening, and flies at the same 20,000 foot altitude of most fighters
using those pods. This makes the Reaper immune to most ground fire, and
capable of seeing, and attacking, anything down there. All at one tenth
of the price of a manned fighter aircraft. The air force expects to stop
buying the Predator in three years, and switch over to the Reaper and MQ-1B.
1976 Overhaul, 1100 Hours..Pass???/ [email protected] Owning 44 September 15th 05 01:44 AM
Pricing flight hours Andrew Gideon Owning 9 May 6th 05 11:41 PM
Local flight >227 hours duration Casey Wilson Piloting 4 February 22nd 05 10:49 PM
7th flight - 7.9 hours in.. Too fun! JIM105 Rotorcraft 10 August 30th 04 04:45 PM
Flight sims way to cheap to pass up for sale on Ebay. Curtis Simulators 0 November 20th 03 04:41 PM
