Wanted, electret microphone
Old August 23rd 08, 07:46 PM posted to rec.aviation.owning
noname
Default Wanted, electret microphone
The microphone in my old headset went TU and need a replacement.
Anybody have a working one they would like to part with?
Thanks
Dave
Old August 24th 08, 08:35 PM posted to rec.aviation.owning
Thanks
Dave
You could probably fix it with the electret mike from a
cheap telephone (not an old carbon-mike phone). I built a headset once
and used the mike from a $3 corded phone, no preamp or anything, and
it worked OK. Had to put a small capacitor across it to bleed off some
of the high freqencies. The mike itself was maybe 3/8" diameter, about
the same thick, and fit nicely into a holder carved of wood.
Dan
Old August 25th 08, 12:59 AM posted to rec.aviation.owning
Mike[_22_]
Thanks
Dave
Dan
That sounds like a lot of work to develop something that's going to be less
effective than a replacement, but I can't say I'm innocent of spending way
too many man-hours trying to save a few bucks. The problem with using one
from a telephone is I don't think the impedence matches up and most aviation
mics have some type of noise cancelling circuitry.
Old August 25th 08, 01:38 AM posted to rec.aviation.owning
john smith
In article NBmsk.718$lf2.305@trnddc07, "Mike"
Thanks
Dave
Dan
What makes you think the impedence of the ones in the telephones are
different from the ones in your headset?
Old August 25th 08, 04:18 AM posted to rec.aviation.owning
dave
Thanks
Dave
Dan
I'd rather not cobble something up if I can help it. I was just looking
for somebody with an old headset with a workable microphone that still
works.
Dave
Old August 25th 08, 04:31 AM posted to rec.aviation.owning
Orval Fairbairn[_2_]
Thanks
Dave
Dan
less
aviation
works.
Dave
If it is a David Clark, they will replace for free at fly-ins, where DC
has a rep.
Remove _'s from email address to talk to me.
Old August 25th 08, 05:14 AM posted to rec.aviation.owning
Mike[_22_]
"John Smith" wrote in message
Thanks
Dave
Dan
less
way
one
aviation
Because they are two different devices used in two different applications.
All microphones, even electret models, don't have the same impedence and
there are wide variances depending on the application. Even a mic removed
from a DC military headset won't work well in their civilian version because
of the differences in impedence.
What makes you think they are the same?
Old August 25th 08, 11:37 PM posted to rec.aviation.owning
john smith
In article %kqsk.741$lf2.630@trnddc07, "Mike"
The voltages and currents they are typically designed to work at.
Old August 26th 08, 12:59 AM posted to rec.aviation.owning
Mike[_22_]
applications.
removed
because
Which can vary widely in telephones and don't by themselves determine
impedence anyway.
Some telephone electret mics are 1000 ohms and civilian headset electret
mics are typically 50 ohms. That's not to say there aren't telephone
electret mics that are also 50 ohms, but I suspect most are higher.
Old August 26th 08, 01:50 AM posted to rec.aviation.owning
RST Engineering
I've been watching this thread for some time and what is said below is just
busslit. No native electret mic that was ever made was 50 ohms, nor are
aircraft microphones 50 ohms nor are thelphone electret mikes 1k. You are
blowing smoke.
BTW, having been in the aircraft headset business for twenty years and
change, I can tell you that when a clown like this comes on asking where to
get a "replacement mic" without telling you the manufacturer and model of
the headset, he is trolling for ANY microphone that he can use to convert a
Harbor Freight type headset to aircraft use on the cheap.
Bluetooth Microphone? Gary Emerson Soaring 2 October 27th 07 11:18 PM
Headset Microphone Quality Marco Leon Piloting 14 May 15th 07 07:44 PM
Connection of second microphone yuval Soaring 2 January 14th 07 08:34 PM
Radio / microphone question. Bruce Home Built 3 January 29th 06 05:58 PM
Telex 500T Microphone... DGRTEK Soaring 0 July 15th 03 10:55 PM
