#21
![]() "Bob Kuykendall" wrote in message ... On Aug 26, 4:18 pm, Uncle Fuzzy wrote: Those things give me the willies, I'm always worried about carbon monoxide poisoning. Thanks, Bob K. As well you should be! Carbon Monoxide detectors are available and inexpensive. They look like smoke detectors. Pilot shops sell CO detectors for the cockpit. Insidious and deadly. Use extreme caution. Hartley Falbaum |
On Aug 26, 9:02*pm, Uncle Fuzzy wrote:
On Aug 26, 5:07*pm, Bob Kuykendall wrote: On Aug 26, 4:18*pm, Uncle Fuzzy wrote: Was Brad using a Space Heater, or a forced air gas furnace like you have? I wouldn't think your heater would be a problem. Brad laid up his fuselage shells at my shop, using my shop heater, not a space heater. It's a Modine Hot Dawg 75 kbtu unit I put up several years ago. In the past I've used kerosene and propane space heaters, but mostly just with quickie polyester/glass layups. Those things give me the willies, I'm always worried about carbon monoxide poisoning. Thanks, Bob K. That's what I thought. *Unfortunately, that kinda' decreases the chances that excess moisture in the air caused the epoxy not to bond to the gelcoat. The process the factories use has developed over quite some time. Important factors include: 1) The exact chemistries of the gelcoat and epoxy being used. These are chemically disimilar materials being asked to form a "permanent" bond during curing. 2) The timing of the process. The time from when gelcoat is sprayed and has gelled- but not cured- to when the first application of epoxy is important to getting whatever "bond" you get between materials . Using a developmental process with different materials will obviously require a good bit of testing. Another option could be to skip the whole gelcoat thing and do the lamination of epoxy/glass/carbon directly in the mold and accept that it will need pinhole/prime/fill and then paint. You would avoid the time delay failure mode that gelcoat finishes have inherent to them. They all fail- its only a matter of time till the gelcoat comes off in sheets or chips. FWIW UH |
#24
On Aug 27, 1:37*pm, Eric Greenwell wrote:
wrote: Another option could be to skip the whole gelcoat thing and do the lamination of epoxy/glass/carbon directly in the mold and accept that it will need pinhole/prime/fill and then paint. You would avoid the time delay failure mode that gelcoat finishes have inherent to them. They all fail- its only a matter of time till the gelcoat comes off in sheets or chips. It's all about the duration, though: Time = 5 years = angry owner Time = 50 years = happy owner(s) Do the factories offering polyurethane paint as an option to gel coat still use a thin layer gel coat? How much does that method extend the life of the gel coat? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * * * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org The painted gliders still come out of the mold with gelcoat. It gives them something to sand and provide basis for finish. Life isn't known yet because the aren't that many out there with original PU finishes. It has only been commonly available, as far as I know, for maybe 5 yrs. If you can keep moisture and UV away from it, I would expect gelcoat to last quite a while, certainly longer than "natural" gelcoat. All this said, we have a Std Libelle in our club which is over 35 yr old and the finish on the wings(original) is still excellent. We also have an ASK-21 which is about 25 yr old which I expect we will be able to take the gelcoat off with a chisel(don't ask) in chunks. |
#25
still use a thin layer gel coat? How much does that method extend the life of the gel coat? Yes, it is necessary to use gel coat or an in-mold primer gel coat. As Hank mentioned it is not practical to laminate directly on the mold surface. The laminate will be full of pinholes and require extensive post-mold priming and sanding before a finish coating can be applied. Now here's a catch 22 - It is not feasible to apply a "thin" layer of polyester gel coat. The normally recommended wet film thickness ranges from a low of 14 mils (mil =.001") to 18+ mils. With anything thinner than 14 mils the proportional amount of styrene lost through evaporation becomes so high that there is not enough styrene left for complete crosslinking. Bottomline - overly thin gel coat will be permanently under-cured regardless of catalyst level or curing temperature. A linear urethane topcoat will extend the life of a well applied gel coat substrate condsiderably. Bob |
#26
On Aug 27, 1:31*pm, RL wrote:
Do the factories offering polyurethane paint as an option to gel coat still use a thin layer gel coat? How much does that method extend the life of the gel coat? Yes, it is necessary to use gel coat or an in-mold primer gel coat. As Hank mentioned it is not practical to laminate directly on the mold surface. The laminate will be full of pinholes and require extensive post-mold priming and sanding before a finish coating can be applied. Now here's a catch 22 - It is not feasible to apply a "thin" layer of polyester gel coat. The normally recommended wet film thickness ranges from a low of 14 mils (mil =.001") to 18+ mils. With anything thinner than 14 mils the proportional amount of styrene lost through evaporation becomes so high that there is not enough styrene left for complete crosslinking. Bottomline - overly thin gel coat will be permanently under-cured regardless of catalyst level or curing temperature. A linear urethane topcoat will extend the life of a well applied gel coat substrate condsiderably. Bob http://www.dg-flugzeugbau.de/gelcoat-e.html http://www.dg-flugzeugbau.de/pur-lack-e.html |
#27
#28
![]() With anything thinner than 14 mils the proportional amount of styrene lost through evaporation becomes so high that there is not enough styrene left for complete crosslinking. Bottomline - overly thin gel coat will be permanently under-cured regardless of catalyst level or curing temperature. Bob, You just solved my gelcoat problem. The layer was to thin. In the areas where it was thicker, I had to use a DA to get it off, everywhere else, it flaked off with the sandpaper or by sliding a putty knife under the paint and removing "leaves" of it. I have had ISP problems the last several days, hence my dissapearance on this thread! Will give you a call tonight Bob. Brad |
#29
I believe AMS-Fligth in Slovenia is building gliders with only PU. They
have developed a method for spraying the PU in the mold prior to layup so that the pieces comeout with a PU finish. This is the way my APIS was built. The finish is all PU, no gelcoat that I am aware of. http://www.ams-flight.si/ abour 1/3 of the way down the page "AMS Sets The Standard In Glider Finishes". John Scott |
#30
On Aug 27, 4:33*pm, "John Scott" wrote:
I believe AMS-Fligth in Slovenia is building gliders with only PU. *They have developed a method for spraying the PU in the mold prior to layup so that the pieces comeout with a PU finish. *This is the way my APIS was built. *The finish is all PU, no gelcoat that I am aware of. * * * * * *http://www.ams-flight.si/* * * *abour 1/3 of the way down the page "AMS Sets The Standard In Glider Finishes". John Scott My Apis was built by Albastar, not sure what they used as a mold coat. Whatever it was, it was really thin, and I used it as a primer coat for Prestec 2781. Brad |
Grob gelcoat | Gary Emerson | Soaring | 1 | December 19th 07 05:55 AM |
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
First Glider no gelcoat | Doug Reeve | Soaring | 0 | February 10th 06 10:05 AM |
Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 08:34 AM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
