Mode S transponder display to ATC?
Old September 6th 08, 09:21 AM posted to rec.aviation.ifr
Thomas Borchert
Default Mode S transponder display to ATC?
Peter,
which display aircraft
registrations do it by containing software and database to decode the
24-bit code.
Why wouldn't they simply use the flight ID data field?
Thomas Borchert (EDDH)
Old September 6th 08, 01:23 PM posted to rec.aviation.ifr
Mike[_22_]
"Thomas Borchert" wrote in message
Peter,
24-bit code.
For one, not all ModeS transponders have that capability as it's implemented
as a level 2 function. I know that many, if not all, areas of western
Europe require a ModeS transponder, but I'm not sure if they require a level
2 ModeS transponder.
Old September 6th 08, 05:14 PM posted to rec.aviation.ifr
Michael Huber[_2_]
Peter wrote:
You would however get into trouble if you recorded ATC and then openly
published the recording, e.g. on a website. I don't know why there is
this sensitivity because UK ATC are generally highly professional;
Maybe a parallel to Germany might help. In Germany, tapping into any
communication not intended by the sender to be heard/read/whatever by
oneself is illegal (regardless of whether there are measures taken to
prevent this) under privacy laws. There are some exceptions, but that's the
general rule. ATC communication is only intended for a limited circle of
recipients. Plane spotters are not the intended recipients, thus, they may
not listen.
It has nothing to do with perceived professionality of the ATC people, and
everything with protecting the privacy of ATC and pilots.
Old September 6th 08, 08:47 PM posted to rec.aviation.ifr
Mxsmanic
Michael Huber writes:
not listen.
If you take that to its logical conclusion, it should be illegal for pilots to
listen to any ATC transmission that isn't specifically addressed to them.
I'm certain that it has nothing to do with protecting privacy, and everything
to do with protecting incompetence.
Old September 6th 08, 09:16 PM posted to rec.aviation.ifr
Viperdoc[_5_]
everything
Finally, Anthony has found something where he has some expertise and
experience- congratulations!
Old September 6th 08, 09:51 PM posted to rec.aviation.ifr
Michael Huber[_2_]
pilots to listen to any ATC transmission that isn't specifically addressed
to them.
*sigh* I'm going to violate my rule against replying to MXS and reply to
this, since I think it's an easy mistake to make. It isn't, as the ATC (and
any transmitting pilots) are fully aware that all pilots are listening in.
Thus, it is not an invasion of their privacy, since the transmitting party
is aware of these listeners. Further, it is actually beneficial and
intended for all pilots to listen, since listening to all transmissions can
enhance the pilots' situational awareness - they know what the other guy is
doing. So, the argument is that while only one plane is specifically
adressed, the intended recipients are really planes on the frequency.
Old September 7th 08, 12:05 AM posted to rec.aviation.ifr
Mxsmanic
In that case, since pilots and ATC are also generally aware that people on the
ground are listening in, spotters and others listening to the communications
aren't breaking the law, either.
doing.
It is beneficial for people on the ground to listen in as well, as it improves
their situational awareness of the state of flights in the air.
So is it legal for United to have a channel on the aircraft that allows
passengers to listen to ATC? Why, or why not?
  #28
Old September 7th 08, 01:39 AM posted to rec.aviation.ifr
Viperdoc[_5_]
Anthony, don't worry, you don't have or need a mode S transponder, or for
that matter a transponder of any kind. These devices are used by people who
actually fly airplanes, and are used in actual airplanes. They are not a
factor for gamers, like yourself. So, don't worry.
If you need to hear any other voices in the dark, you can always communicate
with your imaginary controllers and fellow game players via the net.
Everything will be alright, don't worry. The demons will go away soon.
  #29
Old September 7th 08, 08:29 AM posted to rec.aviation.ifr
Sam Spade
Thomas Borchert wrote:
Peter,
Doesn't the system process the flightid field?
Some do. In Europe, more and more do.
Or isn't that
transmitted?
It certainly is.
Not in the U.S.
  #30
Old September 7th 08, 09:14 AM posted to rec.aviation.ifr
Thomas Borchert
Sam,
Not in the U.S.
Source? A source that shows a Garmin GTX330 does not transmit flight ID
data in the US would suffice.
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
