Nexus program of any use flying?
Old September 7th 08, 08:46 PM posted to rec.aviation.piloting
Paul kgyy
Default Nexus program of any use flying?
There's a $50 program to speed Canada/U.S. cross border transportation
for marine and highway use.
Is it of any value when flying across? Scuttlebutt is that flying
into Canada isn't any hassle but coming back into the U.S. can be a
real PITA.
Old September 8th 08, 12:12 AM posted to rec.aviation.piloting
john smith
In article
real PITA.
Pre-9/11, there existed a US program similar to CANPASS, but it only
applied if one was an aircraft owner. If you were a renter, you couldn't
use it.
Post 9/11, it went away.
Old September 8th 08, 05:13 AM posted to rec.aviation.piloting
Rich Ahrens[_2_]
on 9/7/2008 6:12 PM John Smith said the following:
In article
real PITA.
use it.
Just to be clear, though, the CANPASS program for private aircraft does
still exist for going *to* Canada. I have used it after 9/11, but not
recently. Info:
http://www.cbsa-asfc.gc.ca/prog/canp...teair-eng.html
The GATE program for return to the U.S. died on 9/11 as John says.
Biggest hassle now are the advance notice requirements for Customs. You
have to notify them directly, not just depend on ATC to advise them. You
have to be on a flight plan and have a discrete transponder code
assigned when you cross the border. And heaven help you if you have any
old radium-painted instruments when you clear Customs...
Old September 9th 08, 06:47 PM posted to rec.aviation.piloting
Darkwing
"Paul kgyy" wrote in message
real PITA.
If you're an AOPA member contact them, they probably know the best ways to
come and go.
Wings Program, SoCal, USA, Thurs 7-12-07 Desert Summer Flying CindyB Piloting 2 July 12th 07 05:31 AM
Wings Program, SoCal, USA, Thurs 7-12-07 Desert Summer Flying CindyB Soaring 2 July 12th 07 05:31 AM
E6-B program for HP 15C Chris W Piloting 5 June 12th 05 02:17 AM
L.A.R.K. Program Flyingmonk Home Built 6 April 15th 05 01:23 AM
Program about the B-26 vincent p. norris Military Aviation 1 January 1st 04 01:41 AM
