Wright Replica Fails to Fly
Old December 18th 03, 03:34 PM
robert arndt
Default Wright Replica Fails to Fly
http://www.ctv.ca/servlet/ArticleNew...ub=CTVNewsAt11
.... as expected... despite $1.2 mil invested and painstaking attention
to detail. At least the two GW No.21 replicas both flew easily. IMO,
the Wrights lucked out last century with a rail, right wind, and
warping experience. The 21st century guys trying to fly that flimsy
replica can't replicate the Wright's experience (with their own
design) nor the right conditions for the flight(s) in 1903. The GW
No.21, OTOH, took off under its own power and flew about half a mile-
in 1901. The replicas of the GW No.21 flew easily and there is little
doubt that a third aircraft with an exact replica of the
engine/powered gear mechanism would fly as well...
Rob
p.s. So much for the Wright's absurd claim that the GW No.21 could NOT
fly due to its configuration alone. They were proven wrong TWICE with
the replicas that flew in the '80s and '90s. Historically, the early
Taube which strongly resembles the GW No.21 also flew easily.
Old December 18th 03, 04:26 PM
Kevin Brooks
"robert arndt" wrote in message
om...
Rob
God, you are a sad little cretin. IIRC the wind conditions were a bit off
yesterday compared to what they were in 1903. Are you actually claiming the
1903 flight was some sort of conspiracy theory? Or that the GW flew a
controlled, poered flight before the Wright demonstration? You are in need
of a few whacks with the loon mallet.
Brooks
Old December 18th 03, 04:41 PM
Keith Willshaw
om...
No they didnt
The first crashed injuring the pilot and the team then spent several years
re-engineering the 'replica' and they rationalised the differences between
the machine they built and the one in contemporary photos by arguing
that the photos must represent an early variant of the machine before
Whitehead made the changes necessary to make it fly !
Talk about circular logic
The flight testing of the second replica lasted may weeks during
which the following problems occurred
Quote
The wings collapsed during initial tow cart testing. The cause
of the difficulties proved to be structural deficiencies in both
the original design and the reproduction.
Whitehead's original design had obviously included too few
ropes for the tensioning of the flexible bamboo structure.
In addition to this fact, the ropes used on the reproduction machine
were constructed partially of elastic material. As a result, the bamboo
spars were distorted by dynamic air pressure, and wing form and tension
lost.
The first practical measurement of lift showed that a speed of 78 kmh
would be required to get the projected take-off mass airborne, which
meant a power requirement far greater than the Whitehead propeller
engine was capable of providing.
The first subject for trouble-shooting was the construction of the
reproduction airframe and engine, which was obviously too heavy,
even based on the technical standards of the turn of the century.
The airframe was therefore modified to such an extent that weight
was reduced by almost 20 kg, or 11%.
A similar percentage weight saving on the engine would have
reduced the take-off mass to 3580 kg, with a corresponding
reduction in take-off speed required, to 75 kmh. This was still
far too high, however, as it meant a power requirement of 20 hp,
with no reserve for propeller efficiency.
All possibilities of weight saving having been exhausted, a
reduction in flying speed was now only possible via
improvement of wing aerodynamic performance.
The camber of the wing profile installed by the Gustav Weißkopf
Historical Research Society was calibrated.
The results revealed the risks inherent in reproductions due to
deficiencies in construction or historical compatibility, for
the wings were found to be completely without camber.
/Quote
This is just a sample , they made literally dozens of changes to
'the replica' during the course of testing in order to make the
thing fly, not least of which was the use of a modern engine and propellors
The team themselves were honest about this stating
Quote
1. The concept of the Gustave Whitehead Flying Machine No 21
had no inherent weakness which would have ruled out its flying capability.
Attention must, however, be drawn to the following points:
a. Several modifications were required, as is the case with all prototypes
in early stages of development. The modifications performed were
of a structural nature, which did not alter the basic design. There is,
however, no doubt that the necessity for and nature of these
modifications would have been identified and performed by Whitehead.
b. The "recreated" flight control as used in reproduction No 21 B has not
been
verified in the historical documentation included in the referenced
literature. I
t cannot be identified in the glass-plate photographs due their lack of
resolution.
However, the flight as described by Richard Howell over a distance of half a
mile,
or 1,000 metres, would be impossible without flight control, in particular
without
longitudinal control. It cannot be completely ruled out on the other hand,
as the
flying machine possessed a considerable degree of inherent stability, that
Whitehead
could have survived a few hops in calm air without too much trouble,
even without active flight control. Attempts at steering by shifting body
weight
did not provide any evidence of practical value.
2. It was possible to repeat the flights of up to 6 ft described by
eyewitnesses,
at a take-off weight of 3335 N. The thrust required at brake release was
1080 N, which dropped to 714 N at a flying speed of 52 kmh. (Annex 15,
diagram)
/Quote
See http://www.setp.org/historicalflying.htm
for the full report
Rob
The machine built in the 80's CRASHED, I suppose this was easy
As I have shown the second replica required structural alterations
and a modern engine to be fitted before it would fly and even then
the team admit it was not truly controllable
Keith
Old December 18th 03, 06:43 PM
Stephen Harding
No they didnt
This sounds a bit like the story of "proving" that Langley's airplane
was the real thing before the Wright's.
As some may know, Langley's airplane was launched from a platform in
the Potomac river, only to do an aeronautical example of a belly flop.
Langley claimed the problem wasn't with the airplane, but with the
launching gear. A few months later, Wilbur and Orville took off.
However, Langley didn't give up. The plane "would have flown" before
the Wrights if only the launching gear hadn't broken the airplane.
To prove this, the Langley airplane was "flown again" around 10 years
later in an effort to keep credit away from the Wrights. Curtis, who
had been in continuous litigation with the Wrights (and generally losing),
was only too happy to "reconstruct" the Langley aircraft, to prove the
"Wrights had no rights", to their airplane patents.
The "fixes" included more efficient propellers, more powerful engine,
some structural improvements to the wings, and at some point, a pair of
pontoons to take off from the water without need of the launching boat.
When the "re-test" occurred, Curtis claimed the aircraft did take off
and fly for a distance far greater than what the Wrights had achieved.
Unfortunately, newspapermen reporting the event from shore reported
they couldn't tell if the aircraft left the water or not. If it did,
it wasn't very high nor a very long flight.
Curtis eventually got the Langley aircraft airborne up towards 3,000
feet on many flights, but it just wasn't the same aircraft as 1903.
Of course, Langley was head of the Smithsonian, which accounted for
the Wrights getting no credit in that institution until about WWII,
when the Wright flyer was returned from England to take up residence
in the museum.
SMH
Old December 18th 03, 07:56 PM
Steven P. McNicoll
om...
No true GW No.21 replica has ever been constructed.
The GW
in 1901.
No credible evidence of any flight GW No.21 has ever been produced.
Old December 19th 03, 01:54 AM
Eugene Griessel
"Steven P. McNicoll" wrote in message et...
om...
The GW
in 1901.
I think that the final summation of the dilemma is in the fact that
although a fair number of pioneers in the 19th century and early 20th
managed to make short uncontrolled hops or glides and that some even
built aircraft that may have been, given the right conditions, capable
of flight - none persevered with their ideas to the point where a
viable flying machine resulted. That is one which could ultimately be
depended upon to fly nearly every time and which finally evolved
beyond a curiosity into a practical tool. Furthermore, like nearly
every major invention, the Wrights stood on the shoulders of many of
those pioneers, evolving and combining proven technologies to the
point where it could all come together in one machine.
As for Herr Weisskopf, if he did indeed fly, his publicity department
let him down badly. The controversy goes back many, many years - I
recall reading something in the mid-sixties where fervent supporters
were kicking up a fuss.
However, having arranged for his aircraft to be photographed
statically, why did he not also arrange for one to be photographed in
flight? Strange that. The excuse that he only flew at night is also
peculiar. And his witnesses' statements are also slightly less than
credible. And finally, having built a flying machine why did he not
persist and evolve the thing into a practical machine - and here we
really run into some pathetic arguments such as he was not interested
in flying, only evolving a motor. If indeed this latter argument was
the case he would have done better with a horseless carriage rather
than attempting to pioneer two unkowns at once.
In the final summation it matters little whether Whitehead did indeed
manage
sustained, controllable flight prior to the Wrights. He neither
exploited it nor documented it beyond reasonable doubt and he
certainly did not advance to a point where he could demonstrate his
achievement repeatedly.
That honour indisputably goes to Orville and Wilbur. Whether the
modern replica of their machine flies or not neither proves nor
disproves that fact.
Eugene Griessel
Old December 20th 03, 07:53 PM
Mary Shafer
On Thu, 18 Dec 2003 16:26:22 GMT, "Kevin Brooks"
According to the guy who owned Learjet for a while, the weather at
Kitty Hawk a hundred years ago did make a contribution to the success
of the flight. There was high pressure and it was cold, so the
pressure altitude was negative. This would have improved performance
a little.
I've seen the photos and read the diaries and he's right about the
weather generally. I don't know about the barometer, though. It's an
interesting concept, at any rate.
Mary
Mary Shafer Retired aerospace research engineer
Old December 20th 03, 08:57 PM
Tarver Engineering
"Mary Shafer" wrote in message
snip of idiot imnsulting poster
a little.
You mean the guy who invented the 8-track?
The flyer probably weighed 1000 lbs, this week; as opposed to the 700 pound
original. (ie wet)
Will Wright Replica Fly- Who Knows??? robert arndt Military Aviation 5 December 16th 03 11:36 AM
The Wright Stuff and The Wright Experience John Carrier Military Aviation 54 October 12th 03 04:59 AM
Wright Replica FAILS to Fly robert arndt Military Aviation 36 October 1st 03 12:51 PM
Hughes Racer Replica Lost Wayne Sagar Home Built 9 August 10th 03 01:45 PM
