Crab, slips, and crossed controls
Old September 26th 08, 02:23 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Bertie's has crabs, wears his mothers slips, and crosses his legs everywhere he drools.
"Mick" #$$#@%%%.^^^ wrote in :
And of course you would know that, because you are an aviation legend.
Thenkkew.
Bertie
  #132
Old September 26th 08, 02:45 AM posted to rec.aviation.piloting
Mick[_2_]
Default Bertie has crabs, and slips are just slips. - 1 attachment - 1 attachment
| | | Stefan wrote in
| | | Bertie the Bunyip schrieb:
| | | You're full of ****, stefan.
| | | Still better than completely hollow like you.
| | | Slips are slips no matter where you are and slips, while
| | | aerodynamically identical have different references.
| | | Of course they have different references... visual references,
| | | that is: In one, you look straight ahead, in the other, you look
| | | slightly to one side. I'm fully aware that this difference is
| | | enough for
| simple
| | | minded like you to think they are two different maneuvres.
| | | Yeah, right backpedaling boi.
| | | Bertie
  #133
Mick[_2_]
| Thenkkew.
| Bertie
  #134
Old September 26th 08, 03:29 AM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_28_]
Default Crab, slips, and crossed controls
| Stefan wrote in news:9cc9b$48d7b746
$54487392
| Robert Moore schrieb:
| A slip is a slip is a slip.
| From The FAA H-8083-3a, Airplane Flying Handbook
| Ok, so in the USA there exist several different brands of slips.
| In the rest of the world however, a slip is a slip is a slip. Which
is
| how airplanes see it, too, I suppose.
aerodynamically
| Bertie
But they are still slips, dumb ass.
Oww!
What an astute observation.
And you're stil a fjukktard.
Bertie
  #135
| "Mick" #$$#@%%%.^^^ wrote in news:xEACk.10086$tp1.4322
@newsfe06.iad:
| "Vaughn Simon" wrote in message
| | This is one of those aeronautical "discussions" that can go on
| | forever
| | without a clear winner or loser, unless you can agree on who's
| | definition
| you
| | wish to accept. For very basic piloting questions like this, I
keep
| | an
| old copy
| | of "Stick and Rudder" on the shelf. I found it interesting that
| | Wolfgang apparently found no need to make a distinction;
regardless
| | if done for
| glidepath
| | control or landing in a crosswind, he calls them both "sideslips".
| | Go figure.
| | Vaughn
| Does the term forward slip describe a slip? Yes.
| Does the term side slip describe a slip? Yes.
| Do both requre the same control inputs? Yes.
| What next? Will we have pattern turns, cross country turns, sight
| seeing turns, high altitude turns etc.
| What's this "we" ****, wannabe boi?
| Bertie
You and your ignorant sock puppets.
Yeh, sure fjuukwit.
you can't even follow up your own lames
bertie
  #136
Old September 26th 08, 03:30 AM posted to rec.aviation.piloting,alt.usenet.kooks
| Stefan wrote in
| Of course they have different references... visual references, that
| is: In one, you look straight ahead, in the other, you look slightly
| to one side. I'm fully aware that this difference is enough for simple
| Bertie
No he's not.
Thank you.
Bertie
  #137
Old September 26th 08, 03:31 AM posted to rec.aviation.piloting,alt.usenet.kooks
| Stefan wrote in news:63abb$48d80395
$d9a270a8
| Stefan wrote in
that
slightly
| simple
| You're halluzinating, as usual.
| And the follow-up trick is soooooo old and soooo booooring.
| What folowup trick fjukkwit?
| A good k00k deserves to be shared.
| Shouldn't you be chiseling the gold teeth out of a dead body, BTW?
| Bertie
What a useless and unrelated reply.
Bwawahwh!
Nope.
Bertie
  #138
Old September 26th 08, 03:32 AM posted to rec.aviation.piloting,alt.usenet.kooks
| Ari wrote in
| On Mon, 22 Sep 2008 20:00:14 +0000 (UTC), Bertie the Bunyip wrote:
| Stefan wrote in
that
slightly
| simple minded like you to think they are two different maneuvres.
| Bertie
| Bert, first time Little Luke took me up in his Velocity, he failed
to
| inform me that the rudder system is different from ˇ§conventionalˇ¨
| aircraft in both design and performance. In most aircraft the
rudder
| pedals are interconnected. Pushing down on one rudder pedal causes
a
| corresponding movement in the opposite (upward) direction of the
| other.
| LL says to me, let's slip this baby home. Taje the center stick."
| Uh, like first of all, I'm not LHanded. Then I find the rudder
pedals.
| lol
| I was quick to note that the rudder pedals in the Velocity operate
| independent from each other,what I they failed to notice is that
much
| of the sensory feedback with respect to rudder deployment is
****faced
| gone. Push one rudder pedal in the Velocity and the other remains
| motionless. Cessna and Piper pilots like me learn to rest both feet
on
| the rudder pedals to get a ˇ§feelˇ¨ for the rudder position.
| Transferring this habit to the Velocity invites a common mistake ˇV
| the unintentional deployment of one (or both!) rudder(s) in flight.
| I passed the slip back to Little Puker.
| Yes, I've heard about this feature in that type of airplane. I'm
going
| to get a chance to fly a Long Eze pretty soon and I believe it works
| same way. You can use both together as a speed brake, yes?
| Berti
Let us know when, so we can hide in our bunkers.
Best get hiding, fjukkktard
Bertie
  #139
|a wrote in
| news:0adc0f44-ea01-4a7a-ac08-9781be5aeb54
@z66g2000hsc.googlegroups.com
| On Sep 24, 12:26 pm, Bertie the Bunyip wrote:
| Ari wrote
| innews:6jv4u2F59v
| wrote:
| Stefan wrote in
| . ch:
| look slightly to one side. I'm fully aware that this
| difference is enough for simple minded like you to think they
| Bertie
| failed to inform me that the rudder system is different from
| conventional aircraft in both design and performance. In most
| aircraft the rudder pedals are interconnected. Pushing down on
| one rudder pedal causes a corresponding movement in the opposite
| (upward) direction of the other.
| stick."
| pedals. lol
| operate independent from each other,what I they failed to notice
| is that much of the sensory feedback with respect to rudder
| deployment is ****faced gone. Push one rudder pedal in the
| Velocity and the other remains motionless. Cessna and Piper
| pilots like me learn to rest both feet on the rudder pedals to
| get a feel for the rudder position. Transferring this habit to
| the Velocity invites a common mistake V the unintentional
| going to get a chance to fly a Long Eze pretty soon and I believe
| it works the same way. You can use both together as a speed brake,
| yes?
| Bertie
| Do those fins deploy in only one direction -- ie,outward, or inward
| -- and are spring loaded to neutral? Is the change in the
| airplane's axis pointing direction just caused by the drag increase
| when one side or the other is deployed? It looks to me almost like
| the way the MU aircraft used spoilers on top of the wings instead
| of ailerons (I think).
| Well, that's the way i understood it, but I've never flown one..
| Bertie
We could apparently write a book about things you have never ACTUALLY
done.
Yep, you could, lamerboi.
Who's that "we" again, BTW?
Bertie
  #140
Old September 26th 08, 03:34 AM posted to rec.aviation.piloting,alt.usenet.kooks
| forever
| definition you wish to accept. For very basic piloting questions
| like this, I keep an old copy of "Stick and Rudder" on the shelf.
| I found it interesting that Wolfgang apparently found no need to
| make a distinction; regardless if done for glidepath control or
| Mmm, cept Stefan the cheese nazi has no intention of discussing
| anythign.
| Bertie
Bull****, lamer. You're the one with CDD..
Uh, yeh. OK lamerboi.
Bertie
Slips and skids William Hung[_2_] Piloting 25 March 17th 08 02:27 AM
slips to landing in PTS BB Soaring 6 April 17th 07 05:58 AM
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 08:24 PM
A reluctance to take the controls Jay Honeck Piloting 161 December 1st 06 08:27 PM
About forward slips Mxsmanic Piloting 77 November 2nd 06 11:35 PM
