need for dial altimeter?
Old September 26th 08, 02:52 PM posted to rec.aviation.soaring
Peter Purdie[_4_]
Default need for dial altimeter?
Transponders give Flight Level (assuming they are working properly), so
will give the altitude ATC are intereted in. That's how they know what
FL you are at when not talking to them.
At 12:52 26 September 2008, John Smith wrote:
JJ Sinclair wrote:
On the last home-built I regestered, the federallies required a
mechanical airspeed, altimeter and compass........nothing else. But I
have observed that the panel I am now flying has altitude displayed
all over the place, in two GPS's, in the SN-10 and in the
transponder.
The large altimeter takes up a lot of space and provides the least
important info..........................we can all estimate our
altitude for landing, can't we? The rest of the time its just nice to
know info.
Except when you're flying in the among controlled airspace, where
neither GPS altitude (geometric) nor transponder altitude (QNE) do you
any good. Loggers usually can give you QNH altitude, provided you set
them correctly and your battery isn't flat.
Old September 26th 08, 05:12 PM posted to rec.aviation.soaring
Eric Greenwell
know info.
so will give the altitude ATC are intereted in. That's how they
know what FL you are at when not talking to them.
The pilot still needs to know msl altitude, because that's how the
airspace is designated at 18,000' and below in the USA. Also, elevations
(airports, mountains, obstructions, etc) use msl, and other gliders and
aircraft will report their altitudes in msl.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old September 26th 08, 05:43 PM posted to rec.aviation.soaring
5Z
will give the altitude ATC are intereted in. *That's how they know what
The controller see your transponder altitude CORRECTED for the local
pressure. So don't give them the number off the transponder display
unless the current pressure is 29.92
That's why the altimeter must be calibrated when you calibrate the
transponder. You must be able to set the altimeter to the current
(not what it was several hours or hundreds of miles away) before
talking to ATC, and that is why they will give you an altimeter
setting on initial contact unless you indicate you have current ATIS
info.
-Tom
Old September 26th 08, 06:14 PM posted to rec.aviation.soaring
bumper
"TXBill" wrote in message
Wouldn't a glass-cockpit soaring instrument, say something like the new
ClearNav from NK, provide even better situational awareness if it had an
airspeed strip down the right edge and an altitude strip down the left
edge? How about adding "altitude required for next waypoint" and "speed to
fly" indicators to those strips?
I'd sure like to have them....but, then, I'd like to have a horizon, too.
And a G-meter strip next to the airspeed strip. Oh, and how about a vario
strip next to the altitude strip? With real-time and average indicators?
Maybe a voltmeter? A compass? Synthetic 3D terrain view? Thermal markers?
What else do y'all think might be useful?
Sounds like a whole new class of instrument, an "ESIS" or "Electronic
Soaring Information System". Put all that on a 12inch-diagonal daylight
visible screen and the only "steam guages" I'd have in the cockpit would
be a compass and 57mm airspeed indicator. Just in case.
Hmm, sounds like an idea for a future "Soaring Tech" article.....
See you on the porch,
- Bill
All well an' good, but to gain wide acceptance it needs to be energy
efficient with battery back-up for at least 5 hours on two AA cells.
bumper
zz
Minden
Old September 26th 08, 10:14 PM posted to rec.aviation.soaring
John Smith
There are places in the world where airspace structure is pretty complex
and where you must know your QNH altitude to stay clear of airspaces,
regardless of ATC.
Old September 27th 08, 02:45 AM posted to rec.aviation.soaring
Darryl Ramm
pressure. *So don't give them the number off the transponder display
transponder. *You must be able to set the altimeter to the current
info.
-Tom
Actually this is a common misconception, (one of several reported
recently in the Safety Corner in Soaring magazine). The encoder/
transponder/altimeter system is checked as a part of an install and
you must also do this if the static system is touched during
maintenance. Subsequent checks for aircraft operating VFR are only
required to test the transponder RF/signal properties and do not need
to check the altitude calibration. IFR calibration do. See FAR 91.413
appendix F (RF/signal properties only) and Appendix E (install/static
maintenance and IFR checks).
Back to the original question, I would not want to fly any aircraft
without the ability to reliably (i.e. when the battery dies) know and
be able to report pressure altitude.
Darryl
Old September 27th 08, 03:51 PM posted to rec.aviation.soaring
JJ Sinclair
Darryl
If your battery dies, wouldn't you lose your ability to report
anything to anybody?
I'm not suggesting we fly around without an altitude readout of some
kind, but does it have to be the big, old 80mm round dial? Why can't I
use the pressure altitude displayed in double height on the home page
of my SN-10. Keep the black cursor on it, so my altitude can be read
at a glance. If I should have the SN-10 on another page, I can always
read pressure altitude to the nearest 100 feet off my transponder. If
for some reason I'm unable to use any of the above, I can always read
pressure altitude off the GPS (model 20).
Most of us have two batteries so we can switch if the primary goes
dead.
JJ
Old September 27th 08, 08:17 PM posted to rec.aviation.soaring
John Smith
No it hasn't to be 80mm, mine is 57mm. Aside from this, yes it has to:
More than once I was happy to be able to continue my flight under a
class C ceiling despite of two flat batteries.
Besides, many contries reqire gliders to be equipped with a certificated
altimeter.
Old September 27th 08, 09:32 PM posted to rec.aviation.soaring
Darryl Ramm
Darryl
dead.
JJ
Yes, assuming the backup handheld dies as well, then I'd just be
talking to myself.
I fly a certified glider so I have no choice but to follow the
equipment list. You tell us J.J. what is the requirements for
homebuilt/experimental and racing/exhibition/experimental.
Darryl
Old September 27th 08, 10:57 PM posted to rec.aviation.soaring
JJ Sinclair
Darryl
Alas, yes they both require old fashioned dial altimiters. With todays
glass cockpits, I'm wondering if this requirement isn't outdated?
JJ
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Direct dial FSS phone numbers being suggested as work-around to long hold times Peter R. Piloting 3 May 15th 07 01:16 PM
ADV: Please Dial Up My New Aviation Gear E-Store! Kates Saloon and Knife Emporium Products 0 January 18th 04 06:40 AM
