need for dial altimeter?
Old September 27th 08, 11:51 PM posted to rec.aviation.soaring
Andy[_1_]
Default need for dial altimeter?
On Sep 27, 2:57*pm, JJ Sinclair wrote:
Alas, yes they both require old fashioned dial altimiters. With todays
glass cockpits, I'm wondering if this requirement isn't outdated?
JJ
JJ - Can you, or anyone else, reference a regulation on altimeters
that includes the word DIAL.
91.205.b.2) requires for VFR flight an "altimeter"
91.205.d.5) requires for IFR flight "a sensitive altimeter adjustable
for barometric pressure".
Neither requires a dial and neither requires a mechanical instrument.
Andy
Old September 28th 08, 07:25 AM posted to rec.aviation.soaring
SoaringXCellence
JJ
91.205.b.2) *requires for VFR flight an "altimeter"
Andy
I am also building a homebuilt sailplane and talked with the DAR
(designated airworthiness representative) about the instrumentation.
The answer I got was that it's pretty much up to him. I can have a
compass out of a child's toy if that's what I want and he's willing to
sign it off. Ditto for most of the other instruments.
Old September 28th 08, 02:55 PM posted to rec.aviation.soaring
JJ Sinclair
Good point, Andy.....................maybe we can use one of the many
altitude displays available. As you may have guessed, I removed the
big dial altimeter about a year ago when I installed a transponder. I
set field elevation on the SN10 which is on the first (custom) page
and set-up to be displayed at twice normal height. When not otherwise
being used I leave the black cursor on altitude.................works
like a charm! Yes, my flight manual says I need an altimiter approved
for use on certified aircraft, but it also says I must use the Prandtl
tube, but I'm using a triple probe instead. The guy that's sign'n off
my annual condition inspections doesn't sweat the little stuff.
JJ
JJ
Andy
Looking for TSO Altimeter Rob Turk Home Built 0 June 9th 07 03:52 PM
Direct dial FSS phone numbers being suggested as work-around to long hold times Peter R. Piloting 3 May 15th 07 01:16 PM
ADV: Please Dial Up My New Aviation Gear E-Store! Kates Saloon and Knife Emporium Products 0 January 18th 04 06:40 AM
