Who has recommendations for inline filters on the air compressor, for
water and other stuff? And sources? thanks Ed Wischmeyer |
"Ed Wischmeyer" wrote in message
... Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks Ed Wischmeyer Harbor Freight currently has their filter/regulator/lubricator unit #45009 on sale at 50% off ($19.99). http://www.harborfreight.com/cpi/cta...unction=Search Rich S. |
"Rich S." wrote in message
... "Ed Wischmeyer" wrote in message ... Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks Ed Wischmeyer Harbor Freight currently has their filter/regulator/lubricator unit #45009 on sale at 50% off ($19.99). http://www.harborfreight.com/cpi/cta...unction=Search Rich S. Oops - checked that link and it doesn't work. Sorry. Just go to http://www.harborfreight.com/ and enter 45009 under the item number search. Rich S. |
"Rich S." wrote in message ... Harbor Freight currently has their filter/regulator/lubricator unit #45009 on sale at 50% off ($19.99). http://www.harborfreight.com/cpi/cta...unction=Search I'd recommend against using any inline lubricators. You're just going to contaminate things, and a lot of tools which require lubrication are really picky about what you lubricate them with, so it's better to deal with them on a item by item basis. I've got a simple filter/water trap (CH I believe) in my line. |
contaminate things, and a lot of tools which require lubrication are really picky about what you lubricate them with, so it's better to deal with them on a item by item basis. I've got a simple filter/water trap (CH I believe) in my line. Simple solution is to not put any lubricant into the filter. What is "CH"? thanks Ed |
. .. I'd recommend against using any inline lubricators. You're just going to contaminate things, and a lot of tools which require lubrication are really picky about what you lubricate them with, so it's better to deal with them on a item by item basis. I've got a simple filter/water trap (CH I believe) in my line. Agree. You don't need to use the lubricator function of the HF unit (and probably shouldn't unless it is a dedicated line for one tool. This unit, though, is so reasonably priced that it beats buying a stand alone filter/water trap from one of the "big name" manufacturers. Plus- you get the regulator. HF also has their automatic compressor tank water drain valve #46960 on sale for $6.97. That reminds me - it's past time to wheel my compressor outside and drain the tank. I don't know when that sucker is gonna rust out. It's thirty years old. I can see coming home from a long weekend and the compressor has been running all the time I was gone. Either that or the garage is burned down. d ![]() Rich S. |
"Ed Wischmeyer" wrote in message ... I'd recommend against using any inline lubricators. You're just going to contaminate things, and a lot of tools which require lubrication are really picky about what you lubricate them with, so it's better to deal with them on a item by item basis. I've got a simple filter/water trap (CH I believe) in my line. Simple solution is to not put any lubricant into the filter. What is "CH"? Campbell Hausfeld, a maker of inexpensive air compressors and accessories. |
The lubricator does not have a filter. It uses a porous material to atomize
the oil and it will plug up quickly if you try to use it as a filter. Then why pay extra for a lubricator if you don't need it? Just buy a filter/water trap and a good regulator. -- David D Cowell "Ed Wischmeyer" wrote in message ... I'd recommend against using any inline lubricators. You're just going to contaminate things, and a lot of tools which require lubrication are really picky about what you lubricate them with, so it's better to deal with them on a item by item basis. I've got a simple filter/water trap (CH I believe) in my line. Simple solution is to not put any lubricant into the filter. What is "CH"? thanks Ed |
"David D Cowell" wrote in message
... Then why pay extra for a lubricator if you don't need it? Just buy a filter/water trap and a good regulator. Because the filter/regulator/lubricator is on sale for $19.99, and the filter/regulator is not and is $39.99. Did you not bother to look at the referenced catalog listing? Rich S. "Money - it's always about money" ) |
Ed Wischmeyer wrote: Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks I second the tool lubricator. You definitely need a water filter (sump) and need to drain the air tank periodically, or it will corrode and can result in a nasty explosion. A friend was painting a new RV-8 and was getting fisheye, even though he had cleaned everything. I suggested that his air supply was contaminated (it was) and was putting out droplets of oil alnoh with the paint. He cleaned wverything up and got a nice finish. |
| Thread Tools | |
| Display Modes | |
