List of Questions about restoring a glider
Old October 1st 08, 11:09 PM posted to rec.aviation.soaring
Default List of Questions about restoring a glider
Here's a list of questions about restoring an ASW-15B model.
How expensive is it to tint a canopy?
What about hinging it?
The old metal Ben Greene trailer sure could use some struts/hydraulic
to help open and close the lid. It's really heavy. Anything to
assist in opening it?
What are some ways to remove the painted on contest ID? I was told
Laquer, but wasn't sure if that was laquer thinner exactly.
Thanks in advance!
Scott
Old October 1st 08, 11:37 PM posted to rec.aviation.soaring
Robert Gaines[_2_]
If Comp Number is painted, lacquer thinner is fine.. Same for
Acetone.....if the main finish is Gelcoat.
I've never seen a hinge on a 15 canopy. Such a modification probably
would negate the Standard Airworthiness unless you could get a Field
Approval.
Gas struts for trailer top might help?
Old October 2nd 08, 02:59 PM posted to rec.aviation.soaring
Try the ASW 15 portal - www.asw15.org. Its a pretty good site with
worldwide input. You can pretty much forget hinging the canopy. I
think it was done once, with the canopy hinged a the rear. My
understanding is that it was very expensive. The removable canopy is a
bit of a pain but you get used to it. You have to be careful of where
you put it when its off the ship, particularly in windy conditions.
My trailer is a semi-clamshell of an unknown make but it has two gas
struts on each side. It works well except in really cold weather, but
I don't fly when its that cold anyway.
Mike
ASW 15
Old October 2nd 08, 07:13 PM posted to rec.aviation.soaring
On Oct 2, 5:59*am, wrote:
Try the ASW 15 portal -www.asw15.org. Its a pretty good site with
Mike
ASW 15
Mike what kind of gas strut are on your trailer? What are the
dimensions?
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
glider add on rating questions [email protected] Soaring 1 August 15th 07 03:12 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Bodypilot Home Built 0 August 2nd 04 11:47 AM
