Flown to an airshow's closed airport?
Old October 9th 08, 05:37 PM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
Default Flown to an airshow's closed airport?
In article
Ricky wrote:
On Oct 7, 5:04*pm, Dana M. Hague
d(dash)m(dash)hague(at)comcast(dot)net wrote:
I figured it was OK to land on the far end of cross runway
which wasn't X'd out...
-Dana
Well, what's wrong with landing on a non-Xed runway? Does an X on one
make the entire airport un-landable?
I mean, I know the airport is closed (for an airshow?) but legally,
isn't it o.k. to land an the runway you did?
Ricky
It depends on where the X s are positioned.
If they are on both ends of a runway, it means that runway is closed. If
they are in the center of the airport, it means that the whole airport
is closed.
I had a similar experience at the Abbottsford Airshow in Canada in 1975.
They were accepting traffic on one runway distant from airshow center,
while the airshow was in progress, with no problems. You could not do
that in the US, as the whole airport would be NOTAMed as CLOSED.
Different rules for different countries!
Remove _'s from email address to talk to me.
Old October 10th 08, 12:04 AM posted to rec.aviation.piloting
Dana
I don't remember the details, it was a long time ago... maybe the X was in
the center, probably the whole airport was NOTAM'd closed.
Or maybe the FAA guy later decided what we did was in fact legal but
didn't want to admit it.
-Dana
Old October 10th 08, 01:23 AM posted to rec.aviation.piloting
Mike
"Dana" "d(dash)m(dash)hague(at)comcast(dot)net" wrote in message
newsp.uir41pwpp1n3wr@hague-laptop...
It's possible to close only one runway and in fact, this happens quite often
at larger airports with numerous runways.
However if the entire airport has a NOTAM or TFR, you must abide by those
notices which is where 91.103 comes into play.
Old October 14th 08, 04:40 PM posted to rec.aviation.piloting
es330td
Closing one runway happens all the time at KAHN in the Fall. When UGA
has a home game they'll close 2/20 and use it for parking and let the
9/27 primary handle all the traffic.
Mammoth airport closed temporarily Hellman Soaring 1 August 31st 08 11:41 PM
Identifying a closed airport A Guy Called Tyketto Piloting 12 March 11th 07 05:40 AM
Wurtsboro Airport NY Closed ?? PA-12 Piloting 2 January 5th 06 03:28 PM
Wurtsboro Airport NY Closed ?? PA-12 Piloting 0 January 5th 06 01:21 AM
VKX airport (Home of SuperAWOS) CLOSED awos Piloting 0 November 8th 05 03:15 PM
