Does SeeYou have a separate Validation DLL?
Old October 18th 08, 11:13 PM posted to rec.aviation.soaring
Papa3
Default Does SeeYou have a separate Validation DLL?
On Oct 17, 8:47*pm, Darryl Ramm wrote:
On Oct 17, 4:22*pm, Papa3 wrote:
On Oct 16, 7:42*pm, Darryl Ramm wrote:
On Oct 16, 4:00*pm, Tim Newport-Peace wrote:
At 22:22 16 October 2008, Papa3 wrote:
On Oct 16, 5:08=A0pm, DRN *wrote:
On Oct 16, 3:15=A0pm, Papa3 *wrote:
Folks,
I know I should post this to the SeeYou forums, but I'm having
issues
resetting my password.
I'm looking for a SeeYou DLL in the prescribed IGC format for
validating the SeeYou G-Record. =A0I already have the stand alone
DOS
application from SeeYou; that's not what I need. =A0 I want the DLL
tha=
t
can be launched from the Mark Ramsey validation shell application on
the IGC website.
Thanks,
Erik Mann
LS8-18 P3
Eric - The validation DLL is logger-specific and supplied by the
logger
manufacturer. So, check the IGC web site or your logger-vendor's
site ?
See ya, Dave "YO electric"
Should have clarified further. * SeeYou supports downloading from non-
IGC-Approved loggers, specifically Garmin. * *In so doing, it creates
its own proprietary Security Record (G-Record). * *I want to see if
there is a DLL which would validate files downloaded under this
scenario.
Cheers,
P3
The security record (G-record) is generated in the Recorder for
IGC-approved recorders.
Garmin does not create a G-record, so there is nothing to validate, so
there is no purpose in a Validation DLL.
Tim Newport-Peace >
Skype: specialist_systemshttp://www.spsys.demon.co.uk/icom.htm
Eric
Do you mean using SeeYou (the program on a PC) or using SeeYou Mobile
on a PDA with the Garmin as a GPS/NEMA source? in which case yes there
is a G record created. But since the Garmin+SeeYou Mobile combination
is not an IGC approved logger there is no IGC validation program, and
no point to having one. The only benefit AFAIK is those files are
useful for OLC.
Darryl- Hide quoted text -
- Show quoted text -
This has nothing to do with the IGC or the sporting code. *This
relates to another initiative.
P3
Your question may not have anything to do with the IGC but the kind of
obvious answer (there is not one) does. The combination you are
talking about is not an IGC approved logger or intended to be
therefore unlikely anybody would create an IGC specific validation DLL
for it.
Darryl
Tim already answered... in fact others have created DLLs even for non-
approved loggers/downloads for the very reason that there are many
uses of IGC files outside of "official" IGC reasons. In fact, SeeYou
has a Vali routine which validates a G-Record it creates to IGC Spec,
so they obviously saw a need. The only issue is/was whether there is
a standalone DLL that doesn't have to run under the DOS shell. Since
G72Win does, I thought it might be possible that SeeYou would have
one. As usual on R.A.S., we got a lot of commentary which doesn't
answer the question :-)
Old October 20th 08, 08:10 AM posted to rec.aviation.soaring
Andrej Kolar[_2_]
As has been stated here before. We do have a vali-cu.exe DOS
validation routine which can be downloaded he
http://www.naviter.si/download/other....php?Itemid=27
At present we don't have a Windows DLL for that since there was no
need for it until now.
Please write to support at naviter dot com for help with resetting the
password, Eric.
Thanks.
Andrej Kolar
Tim already answered... in fact others have created DLLs *even for non-
uses of IGC files outside of "official" IGC reasons. * In fact, SeeYou
so they obviously saw a need. * The only issue is/was whether there is
a standalone DLL that doesn't have to run under the DOS shell. * Since
one. * As usual on R.A.S., we got a lot of commentary which doesn't
answer the question *:-)
OLC validation Ken Bell Soaring 4 March 1st 07 04:36 AM
OLC validation Ken Bell Soaring 0 February 25th 07 05:21 PM
OLC validation Ken Bell Soaring 1 February 25th 07 04:35 PM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
Validation problem Ian Cant Soaring 25 December 18th 04 02:51 AM
