Fuel System Musings, comments encouraged
Old October 20th 08, 08:42 PM posted to rec.aviation.homebuilt
flybynightkarmarepair
Default Fuel System Musings, comments encouraged
On Oct 20, 8:17*am, Copperhead wrote:
On Oct 20, 8:43*am, flybynightkarmarepair wrote:
On Oct 19, 5:31*pm, Jerry Wass wrote:
Have you looked at an Ercoupe fuel system? Two wing tanks in common
(IIRC), pumping with a mech. pump, continuously to a small (5 gal.?)
header tank. Header tank overflows back to a wing tank when it's full.
Header tank feeds the engine via gravity flow.
When the wing tanks are empty, the header tank float & wire gauge
begins to drop. At the moment, you know exactly how much fuel is left.
Works excellently and is very simple. If the pump fails, you still
have the header tank.
Rich S.
I wonder about paralleling the pumps, instead of series.---If you run
both for takeoff/landing you get double the pressure..(may flood engine)
In series, if one stops up w/trash, there's no route around it.
there's a very small leak back orifice to prevent
Heat-expansion/flooding. *Jerry
RE the Ercoupe example: I don't like header tanks from a crash safety
standpoint, and another vent, and a return line souunds like MORE
plumbing to me. *Plus, this is a VW conversion, and if I used a
mechanical fuel pump it would be on the TOP of the engine, plus they
are not sealed like aircraft mechanical fuel pumps are, so this is a
no-go.
Paralleling the pumps also introduces more fittings. *There are finger
strainers in the fuel tanks to keep out the big crap, plus the fuel
pumps only see fuel coming FROM the gascolator, so that failure mode -
jamming due to FOD - seems to unlikely to plan around, IMHO. *I'm more
concerned about an electrical fault, or the failure of the pump itself
due to some internal fault, thus Series makes more sense to me. *And
the pumps already have more than enough flow for full throttle.
Thanks for the feedback, it keeps me thinking, the point of the
exercise.- Hide quoted text -
- Show quoted text -
Ryan,
I fully understand your dislike of a header tank, but have you
considered a small fuel cell instead.
Yes, I have. They are heavier than a tank without their features
would be, and the "stock", relatively inexpensive ones don't have the
vents and outlets arranged in a particularly convenient way, plus I
don't really have the space for them.
Also insofar as fuel pumps are concerned what are the
possibilities regarding the use of an electric fuel pump?
I guess you mean the failure possibilities.
First, I want to clarify one key point. Only one pump operates at a
time. The primary pump is also wired so that it ONLY operates when
there is oil pressure. The secondary pump is wired seperately,
perhaps even to a secondary battery, and is direct, and controlled by
a big, boldly marked switch in the panel.
My understanding is that these pumps are a solenoid driven by an
oscillator driving a power transistor. The oscillator circuit board
sometimes fails due to the usual reasons electronics fail. That's
about the only failure mode worth mentioning.
A few links, that are on my blog, but this discussion seems to have a
life of it's own, so:
http://www.flycorvair.com/601Sep2004.html Scroll down to see the
Model System I'm riffing off of, and a discusion of why the mechanical
pump on this installation was removed. There is a pretty complete
description both of the original arrangement WITH a mechanical pump
and the final version WITHOUT one.
http://www2.cip1.com/PhotoGallery.as...27%2D025 %2DG
Stock VW fuel pump. Push-on hose barbs, all sealed up, so no way to
safety internals. Not particularly confidence inspiring.
http://www.pilotfriend.com/experimental/build_17.htm Great article by
Lyle Powell on fuel systems, originally published in Sport Aviation,
and recommended by the Ellison people. Some of his conclusions can be
VERY difficult to implement, such as no tanks without sumps.
Old October 20th 08, 08:57 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Copperhead" wrote in message
Electrical fuel pumps are very reliable things, electrical systems are
unfortunately somewhat less reliable. The first is useless without the other.
I had an alternator quietly die on a cross country in a rental airplane a
year or two ago. I noticed the problem when my low voltage light winked on.
Shortly after that, radios and other electrical gizmos started to die in spite
of my power conservation efforts. Since it was a gravity feed Cessna, it sure
was nice to not have to wonder when the engine was going to stop.
If I can't have gravity feed, give me the combination of a mechanical pump
backed up by electrical boost pumps.
Vaughn
Old October 20th 08, 10:11 PM posted to rec.aviation.homebuilt
Mike Isaksen
wrote ...
Two low-wing tanks require left/right control to avoid
sucking air from an empty tank. No Both position, or you'll
have trouble, especially if they have separate vents and the
tank pressures aren't exactly equal.
Great thread! I've always believed the above also, but the certified Beech
Skipper has low wing tanks with individual (45 degree cut tube) venting and
a single Both/Off selector. Each tank feeds thru an inline check valve into
a common header tube below the cabin floor, then single outlet to On/Off
valve then to gascolator. The design does try to keep common tank pressure
via a tube interconnecting the top of each individual vent tube. But unequal
feeding is one of the most common complaints.
Old October 21st 08, 01:45 AM posted to rec.aviation.homebuilt
no-go.
The Ercoupe design has worked safely and well for over fifty years.
The lack of a header tank does not guarantee crash safety - nor does
it's presence necessarily increase the danger.
The one pump in that design can either be mechanical or electric, it
matters not. There are no vents involved in the design. The float
gauge holes in the caps provide adequate venting. If you are forced to
park outside in the rain, you simply put a cap over the cap. There is
one line connecting the two tanks which are located at the wing roots.
If one wing is parked, or flown, a little low it makes no difference.
There is a tee in the line that leads to the inlet of the pump. The
outlet of the pump goes to the header tank. The overflow of the header
tank goes to one wing tank.
IMHO, you are making a mountain out of a molehill. This ain't rocket
science and you aren't building a space shuttle. Gravity flow to a
carburated engine is the safest and most reliable fuel feed possible,
until you are attacked by Feherenghi using anti-grav phasers. Listen
carefully - putting any pump, electric or mechanical, in the fuel line
to the carb will restrict or prevent fuel flow in the event of pump
failure. Be safe - use gravity.
My 2 cents worth.
Rich S.
Old October 21st 08, 06:55 AM posted to rec.aviation.homebuilt
no-go.
I've read an accident report where 2 POB died in an otherwise
survivable Ercoupe crash due to the fuel tank splitting and soaking
them in gas. Ignition happened, and they became human wicks.
Others have noted ways of mitigating this via fuel cells, and while
you make a pretty good argument, I'm not convinced. Fred Weick, the
designer of the Ercoupe (although perhaps not this part of it...) also
had significant input to the most numerous low wing production design,
the Piper Cherokee, and it DOES NOT use a header tank. Strictly
circumstantial, to be sure, but draw your own conclusions.
I don't like this at all. I don't like relying on the nut between the
headphones to keep me safe from a significant hazard (water in the
gas) in an airplane with as small a fuel capacity as the one I'm
building. I want a screened vent of at least 3/8 in. dia. that exits
the BOTTOM of the wing, but vents the TOP of the tank.
There is
I recall a LONG argument on this forum (or maybe it was on a Zenith
601 forum - LOTS of that design fly with a system VERY much like
you're advocating) about unporting a tank at low fuel levels and
sucking air, that I don't want to rehash, but I'll just note that I'm
firmly in the LEFT/RIGHT/OFF fuel selector camp for low wing planes
with wing tanks.
Gravity flow to a
I agree, I agree, to the extent that I'd rather build a high wing
airplane if plans for one that meets my mission requirements were
available when I was first looking. The Aerosport Quail is the only
HIGH wing all metal VW powered single place homebuilt aircraft I'm
aware of, and it's not clear you can actually get plans, although a
source iin Oregon is rumored.
For a low wing plane with fuel in the wings, which I'm well convinced
is safer than fuel in the fuselage, pumps are a necessary evil, and
since they can fail, I'll take two please. William Wynne has done
more engine installations by far than I have, and he's going this way;
so am I.
Anybody have anything to say about the fittings? That was my initial
interest. Should I ditch the pumps I have and just bite the bullet
and go with AN fittings per the exemplar? Do all those unions make
sense?(heavy little suckers! Think of a ball of solid brass the
diameter of a quarter for the 1/8" NPT size, and the diameter of a
Susan B. Anthony dollar for the 1/4" NPT size, and they lighten the
wallet to the tune of $13-20 per at the same time they increase empty
weight) - given that NPT fittings don't seal anyway metal-to-metal,
and you can "clock" them with SOME degree of freedom as long as
they're at least slightly more than finger tight, relying on Loctite
Pipe Sealant to keep them leak free?
Old October 21st 08, 07:43 AM posted to rec.aviation.homebuilt
Survivable Ercoupe crashes where the occupant(s) burned to death (NTSB
Identifiers, no more static URLs for crash reports):
SEA00LA136
NYC98FA107
CHI96FA034 Not clear this one was survivable, absent the fire
MKC82FCG17 Pilot lived a few weeks, died of burns.
NYC85FA222 "water and sludge throughout the fuel system"
This IS not to conclude the Ercoupe is unsafe. Reading accident
reports is always instructive and sobering, but it would take more
analysis than I have time or energy for on a school night to reach
solid conclusions.
Drunks seem to be drawn to Ercoupes is one extremely shaky conclusion
drawn from my reading of 50 fatal accidents since 1962, out of 482
accidents in the same time period.
Old October 21st 08, 07:46 AM posted to rec.aviation.homebuilt
This ain't rocket
Agree.
As with most engines, the VW fuel pump is driven at cam speed but it
is NOT driven off the cam shaft, a significant difference with regard
to its mechanical durability. It is driven off the crankshaft via its
own gear-train. The pump is a two-chamber type in which the
mechanical input serves only to extend a compression spring. The
spring is then free to retract, the amount of retraction determined by
the quantity of fuel drawing into the lower chamber during the
extension cycle. In effect, the pumping action is performed by the
spring rather than by the engine.
Mechanically, the pump is isolated from the engine by a push-rod that
is actuated by a pinion gear. The flexible diaphragm that makes up
the floor of the lower pumping chamber has a useful service life in
excess of 1000 hours, the push-rod slightly more than that. Output
pressure is typically between 8 and 16 ounces, depending on the
spring. Any flow-control valve, such as the ball-valve in the stock
Solex carburetor, which typically has a pressure between 8 ounces and
two pounds is sufficient to shut off delivery. However, any fracture-
failure in the delivery circuit will cause the pump to spray gasoline
in all directions. Wear in the push-rod is reflected by its length
which may be meausred by removing the pump (two studs). Volkswagen
provided three pump push-rods of different lengths.
Failure of the flexible diaphragm offers a bit of visual warning in
the seepage of fuel at the parting line of the pump. This is only
valid for the early model, rebuildable fuel pumps, which is what I
prefer to use on my VEHICLES. In an airplane I'm more comfortable
with a gravity-fed system, even if that includes a header tank in the
fuselage.
The push-rod actuates a bell-crank in the base of the pump body, which
is a white-metal casting. The bell-crank's pivot bears on the casting
without provision of bushings or bearings. In a high-time pump it is
common to see the bearing-holes worn to an oval. The pivot itself is
held in place by a cotter key (early) or snap-ring (late) which is
also subject to wear. The pallet of the bell crank calls for periodic
lubrication with axle grease, maintenance it seldom sees when the
vehicle is maintained by the typical owner. (I believe the service
interval was every 12,000 miles or annually but I'd have to check the
Factory Service Manual. I do it about once a year and have never had
a mechanical failure due to lack of lubrication. I have had the pivot
and the fastener break.)
In my opinion, each builder is responsible for answering such
questions for themselves. I can offer an opinion and may provide an
example to support it but ultimately, that's the limit of my interest
and responsibility; I can always refuse to ride in the thing. (And
have, on several occasions.) Personally, I don't care for pumps and
would eliminate them if possible, especially if they are engine-
driven. The next best choice would be an electrically driven pump (or
any number of them) located where a failure would not douse the engine
with gasoline. Even so, at best all this would do is reduce the risk
of an IN-FLIGHT fire. Following a crash or bad landing, there is
usually some amount of fuel at the scene regardless of where the fuel
tank is located and no matter how the fuel is delivered to the engine.
-Bob Hoover
Old October 21st 08, 03:18 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
My blog has become a way for me to think out loud about my project.
Putting things down in a narrative helps me crystallize my thoughts,
and give me something to refer back to when the time comes to move
from thinking to doing.
Anyway, I've been THINKING about my fuel system, and have put down my
thoughts, I encourage those with more experience to comment either
here or via the blog.
http://users.lmi.net/~ryoung/2008/10...tings-and.html
Lots of good stuff in the links, especially the Sacramento Sky Ranch
ones.
I'm in what I hope are the closing stages of a build of a 601XL with a
William Wynne built Corvair engine. I have the exact fuel system shown
in the photo.
Go with the AN stuff. You can get them from Summit Racing and they don't
cost that much.
For those that suggest a pumping into a header tank. That is exactly
what the older 601HD and HDS did. There just isn't room for it in the
601XL if you have any kind of radios behind the panel.
Old October 21st 08, 03:21 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Vaughn
That's why we ZenVair people use real good batteries.
Old October 21st 08, 07:41 PM posted to rec.aviation.homebuilt
AN fittings are available in aluminum. They weigh almost
nothing. Look for the blue fittings. But watch when you thjread an
aluminum pipe thread into another aluminum fitting or tank boss;
they'll grab and gall and tear the threads apart if you don't use some
decent sealant. We use Seal-Lube, Permatex Aviation Form-A-Gasket,
sometimes Loctite hydraulic sealant. Stay away from teflon tape.
Dan
AeroStar Fuel system? Al G[_1_] Owning 12 November 27th 07 04:36 PM
AeroStar Fuel system? Al G[_1_] Piloting 0 November 12th 07 04:53 PM
Troubleshooting the Comanche fuel system Thomas Owning 9 March 28th 06 11:07 AM
Shadin's Fuel Flow Management System Tom Alton Products 0 September 1st 04 06:07 PM
Pawnee fuel system leak Rod Pool Soaring 0 August 12th 04 04:29 AM
