New Iraqi Airborne Strike Capability Spotted
Old October 22nd 08, 06:34 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
Default New Iraqi Airborne Strike Capability Spotted
On Oct 22, 11:55*am, frank wrote:
On Oct 22, 1:22*am, Mark Borgerson wrote:
In article ab5f457c-92f8-4016-9d19-ef56508e44f0@
79g2000hsk.googlegroups.com, says...
On Oct 21, 5:42*pm, BlackBeard wrote:
On Oct 21, 12:52*pm, Jack Linthicum
On Oct 21, 3:10*pm, BlackBeard wrote:
On Oct 21, 7:00*am, Mark Borgerson wrote:
In article 9870b6e3-029a-4701-9405-6919ed5d2cd0
@s1g2000prg.googlegroups.com, says...
On Oct 20, 9:59*pm, Mark Borgerson wrote:
says...
On Mon, 20 Oct 2008 13:59:09 -0700 (PDT), Jack Linthicum
On Oct 20, 4:50*pm, Peter Skelton wrote:
On Mon, 20 Oct 2008 13:42:34 -0700 (PDT), BlackBeard
Thanks Jack and Dumpst. *That link worked. *I don't believe it can
carry 12 passengers with all that equipment onboard.. *I worked on
several projects where we loaded EO/IR sensors, trackers, and
targeting equipment onboard similar platforms we were using as test
beds. *Not much room left after all that gets shoehorned in.
re. OV-10. *I have a friend that was a USN test jumper who jumped
several times from the Bronco. *He claims they'd sit on the deck, nuts-
to-butts facing aft. *The Bronco would go into a steep climb and
they'd all slide out the back. *Crazy...
If the maximum payload load is 3500 lb as Cessna says, 12 kitted
soldiers are not going to fit.
Peter Skelton
specs for the Grand Caravan Super Cargomaster, listed at 14 passengers
plus two crew. Something like 3700-3800 pounds of cargo/people
Weights:
Empty Weight
1,746kg
Maximum Take-Off Weight
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
Ramp Weight (Grand Caravan, Super Cargomaster)
3,985kg
http://www.aerospace-technology.com/...van/specs.html
Interesting. The Cessna website gives the maximum useful load
number I gave above. The Brochure downloadable from the site
gives 1862 kg. It also shows that, for a range of 100 nm, the
maximum payload, exclusive of 170 lb pilot and 45 min fuel
reserve is 1588 kg. to get 300 nm it's down to 1361 kg.
http://www.cessna.com/MungoBlobs/746...n_Brochure.pdf
12 kitted soldiers is too much weight.
The MC-5 and MP-360 canopies used by the Marine Corps
Force Recon troops can easily handle 400 pounds. *They
have been tested at weights up to 700 pounds. *I don't
think they regularly jump anywhere near that weight, but
400 pounds divided between the Marine and his separately-
suspended duffel is probably not uncommon.
http://atairaerospace.com/onyx/ul/
(been there, wrote the software, but DIDN'T jump out
of the airplane----I'm a 62-year old ex-squid, after
all!)
Mark Borgerson
Test jump site looks like Marana...
The test site with visible cactus, *known as "Area 52", *is about 15
miles East of Eloy, Arizona. * The dry lake bed is Red Lake, about
30 miles North of Kingman, Arizona.
Mark Borgerson
Thanks, I knew it had to be Az. but it didn't look like Yuma which was
my first thought. *I didn't know about Area 52. *Who runs it?
BB
I guess everybody has some mountain to climb in their life.
It's just fate whether you live in Kansas or Tibet.
http://www.lasvegasnow.com/Global/story.asp?S=7340352
Thanks Jack, I've been to Tonopah more than once. *I was referring to
the site Mark mentioned in Az.
BB
I used to have a cite for the location of all of the "areas". As I
understand it Area 51 is now partially in Tooele Proving Ground.
I remember---but can't find---a reference to some black aircraft
programs moving to a site in Utah. *In any case, the area 52 to
which I was referring is very much a local nickname. *On the
Skydive Arizona web site they call it their own Area 51.
http://skydiveaz.com/filmoffice.html
Mark Borgerson
I'd heard Area 12 as the new place to be.
Part of the problem is its not just getting the airframe there (and if
you're lucky its something you can load into a C-5 under a tarp) but
all the support. You want telemetry, maintenance, security, it adds up
fast. Janitors, toilet attendants.
Though with the way technology advances, it makes as much sense to
just start from scratch every decade. We were using an Atari to put
flight test data up on the monitor. Started as a 'proof of concept'.
Of course it worked, so nobody wanted to change it.
Utah had test and training range (UTTR). I think Edwards had better TM
and other data support. At least at the time, they were a step child.
Though they did have better camera setups. Tonopah had best stuff for
nuclear drops. Better operators. Probably better angles around drop
site.
Huge ****ing contest late 80s, Edwards wanted to get part of the
action. Just couldn't follow release and keep cameras trained on the
items.
Eglin had their own specialties, mainly weapons as opposed to
releases, all the aircraft specific tests.
Uncle Sam sure does have the real estate tied up to move though....
My personal encounter with the U-2 was on the back road to the beach
at Cubi Point, aircraft being unloaded from a 124, IIRC.
  #42
Old October 22nd 08, 07:57 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
says...
Peter Skelton
Weights:
Empty Weight
1,746kg
3,629kg
Maximum Load
1,900kg
Fuel Capacity
1,267l
3,985kg
all!)
Mark Borgerson
Mark Borgerson
BB
BB
Mark Borgerson
site.
items.
And then there's China Lake... We have it all.
BB
  #43
Old October 23rd 08, 04:05 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
frank
And then there's China Lake... *We have it all. *
BB
China Lake had some nice toys. Interesting what showed up there.
We had A-7s, they used A-7s for drones for air to air work. There was
quite a lot of under the table parts swapping going on. Their good
tires for our bad tires to put on their drone they were going to shoot
down anyway. Needed parts to keep things flying. Might have been some
other incentives between the maintenance guys.
Everybody flew when required so commands were happy.
  #44
Old October 23rd 08, 04:15 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
BB
My parents went to a tiny Kansas college, Southwestern, that seems to
have furnished a lot of the early staff members for China Lake. I met
them at the college's annual picnic in Southern California. In
addition one of my father's YMCA club members became the basketball
coach and then principle of Sherman Burroughs HS. Later I had contact
with people from China Lake who wanted help from the FCC. I don't know
if it is the desert air or just a tendency for hiring nice people but
I never met a bad personality from China Lake.
  #45
Old October 23rd 08, 06:50 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BlackBeard
On Oct 23, 8:15*am, Jack Linthicum
BB
I never met a bad personality *from China Lake.
You just got lucky It _is_ a bit like the show Eureka, there are
so many S&E's and post-grad degrees in this town you can't swing a
dead cat without knocking someone's pocket protector loose.
There are several schools that seem to dominate the recruiting
efforts. Rolla, MO. UT, and A&M have a strong presence. There's a
generation of old timers that have recently retired that every third
one was from New Mexico.
The Physics Dept. used to have a strong showing from UofAz and
Rochester. But Cal Poly seems to have the most consistent level of
alumni working here, probably because of the proximity, reputation,
and the fact that there are so many generations that work here.
Kids graduate from the local HS and leave swearing they'll never come
back to this terrible place. After a year or so of work once they've
completed college/service a whole lot of them come back. A lot of
them either come back to work on the base or teach in the schools.
As for the personality thing I equate it to the Submarine service.
When you live in a harsh, isolated environment, you learn to work with
and depend on each other. It develops the skills that make good
neighbors. I also think it's hard to survive such a place if you
don't have a sense of humor.
A lot of people are like me in that we came here figuring we'd put up
with it for a few years and then move on to greener pastures. But
between the interesting/rewarding work, great people, and small town
atmosphere it seems like if you don't leave in your first 3 years, you
stay forever. (Exceptions to every rule of course.)
BB
Flying Car Spotted at TIW C J Campbell[_1_] Piloting 9 May 30th 07 03:30 PM
APG-65/66/68/70 simultaneous track/attack capability Bjørnar Bolsøy Military Aviation 0 November 9th 03 12:15 AM
Question on airplane's IFR capability Slav Inger Instrument Flight Rules 10 July 12th 03 03:48 PM
New RAAF Air-To-Air Refuelling Capability Errol Cavit Military Aviation 11 July 2nd 03 06:43 AM
