Sandblasting Grit size?
Old November 1st 08, 09:40 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Sandblasting Grit size?
is it reasonable to assume that if presented with a choice of grit
sizes (20.40.80), that 80 would be the finest? like sandpaper
roughness - Mike
Old November 1st 08, 10:42 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 01 Nov 2008 05:40:16 -0400, Michael Horowitz
roughness - Mike
ballottini (glass beads) comes in a two letter designation.
I used AH grade after some experimentation. it worked best on the
steel tubes of the Auster.
when bead blasting an aircraft component you need to take into account
the fatigue characteristics of the resultant blasted surface. for this
reason you need round particles not sharp grit.
we have sandy soils over here in Perth. some of the most effective
bead blasting media I used was fine round particle washed quartz sand
just beside the neighbouring hangar.
use the appropriate style of grit for aviation.
Stealth Pilot
size comaprison: B-36 & B-29 centerplace Aviation Photos 3 January 11th 08 10:32 PM
Sandblasting reference? Michael Horowitz Home Built 7 November 20th 07 07:01 AM
File size Maple1 Aviation Photos 1 June 16th 07 03:31 AM
What size hole saw do I use? [email protected] Home Built 22 July 16th 05 08:21 AM
Size does matter HECTOP Piloting 59 May 13th 04 11:48 PM
