other than for medical purposes has anyone seen powdered zinc oxide
that could be mixed with a second agent to produce a specific quantity of zinc oxide liquid (which could then be sprayed or painted on)? - Mike |
On Sat, 01 Nov 2008 13:32:35 -0400, Michael Horowitz
wrote: other than for medical purposes has anyone seen powdered zinc oxide that could be mixed with a second agent to produce a specific quantity of zinc oxide liquid (which could then be sprayed or painted on)? - Mike Get it from any good ceramic/pottery supply. |
Would you happen to know what the solvent would be to enable me to use
this as a light primer over steel? - Mike On Sun, 02 Nov 2008 01:55:15 -0400, wrote: On Sat, 01 Nov 2008 13:32:35 -0400, Michael Horowitz wrote: other than for medical purposes has anyone seen powdered zinc oxide that could be mixed with a second agent to produce a specific quantity of zinc oxide liquid (which could then be sprayed or painted on)? - Mike Get it from any good ceramic/pottery supply. |
On Sun, 02 Nov 2008 06:30:34 -0500, Michael Horowitz
wrote: Would you happen to know what the solvent would be to enable me to use this as a light primer over steel? - Mike On Sun, 02 Nov 2008 01:55:15 -0400, wrote: On Sat, 01 Nov 2008 13:32:35 -0400, Michael Horowitz wrote: other than for medical purposes has anyone seen powdered zinc oxide that could be mixed with a second agent to produce a specific quantity of zinc oxide liquid (which could then be sprayed or painted on)? - Mike Get it from any good ceramic/pottery supply. Tempo make it in rattle cans. You'll see it sitting on the shelf beside zinc chromate primer at your local pilot supply shop. Stealth Pilot |
On Sun, 02 Nov 2008 22:48:44 +0900, Stealth Pilot
wrote: On Sun, 02 Nov 2008 06:30:34 -0500, Michael Horowitz wrote: Would you happen to know what the solvent would be to enable me to use this as a light primer over steel? - Mike On Sun, 02 Nov 2008 01:55:15 -0400, wrote: On Sat, 01 Nov 2008 13:32:35 -0400, Michael Horowitz wrote: other than for medical purposes has anyone seen powdered zinc oxide that could be mixed with a second agent to produce a specific quantity of zinc oxide liquid (which could then be sprayed or painted on)? - Mike Get it from any good ceramic/pottery supply. Tempo make it in rattle cans. You'll see it sitting on the shelf beside zinc chromate primer at your local pilot supply shop. Stealth Pilot Yeah, I had read where somewhere just used the cans and that's appearing to be the easiest option, if just a tad expensive; now if I can find out if the Steward System glues are OK with zinc oxide and two part expxy, I'll be in better shape - Mike |
WAS: Red Oxide .NOW: Red colored ZC? | Michael Horowitz | Home Built | 9 | November 29th 05 09:41 AM |
"red oxide primer is a plus" | mhorowit | Home Built | 6 | November 27th 05 05:23 PM |
Zinc Chromate in 2005 | Michael Horowitz | Home Built | 4 | October 16th 05 06:44 PM |
Nitrous Oxide for towing safety? | Jason Payne | Soaring | 8 | March 10th 04 10:16 AM |
