Gary Osoba's record flight declined
Old November 1st 08, 05:13 PM posted to rec.aviation.soaring
Default Gary Osoba's record flight declined
On Nov 1, 8:25*am, wrote:
Gary *- *If you had been able to post your flight on OLC, you would
have scored 1483.63 pts (assuming 11.9M Woodstock). This would have
been the longest flight in North America and the second longest in the
world for 2008! *Great flight!
David Stevenson
Thanks, Dave. The 11.9M version is correct.
And congratulations on your world record flight in the Silent 2!
BTW, the best things about my scenario is that Leo Bennetti Longhini
will retain his open distance record- is there a nicer person in
soaring?
Best Regards,
Gary Osoba
Old November 1st 08, 07:07 PM posted to rec.aviation.soaring
Ramy
David Stevenson
will retain his open distance record- *is there a nicer person in
soaring?
Best Regards,
Gary Osoba
While it is definitely too late now, it is generally possible to
submit flights to OLC few days late, at least it used to be in the
past. All is needed is to email it to OLC and ask nicely. They are
more flexible than the FAI and can post it for you :-)
Could have won the OLC flight of the year award...
Ramy
Old November 2nd 08, 10:17 AM posted to rec.aviation.soaring
Ian Strachan
On Nov 1, 11:55*am, wrote:
No sour grapes here. I've been a little out of the loop for a couple
of years when it comes to matters of officialdom. However, if you're
going to play the game, officially, you need to be up on things. I
know this from past experience, and it really is my fault for not
checking more thoroughly ahead of time.
Dear Gary,
I feel for you, having flown such a great flight and then to find out
that your recorder is no longer IGC-approved for World Records or FAI/
IGC badge flights. Mind you, in my record-breaking days I had a
number of flights turned down for failures to comply with one aspect
of the rules or another, so I've been there too! One flight I did
before the days of IGC-approved recorders, was turned down because the
proof that the motor glider engine had not been run was not positive
enough. So, the next weekend I flew it again but had an OO seal the
engine inside the engine bay with tape (which could have been broken
if I needed to run the engine to prevent a field landing). The tape
was unbroken at the end of the flight and it was validated. Now, with
IGC-approved recorders we have a much better worldwide system.
As you generously say above, you should have checked. On that point,
it it easy for anyone to check by simply going to the IGC GNSS web
site and downloading the latest IGC-approval document for that type of
recorder. In your case the three legacy Cambridge models 10, 20 and
25.
Go to: http://www.fai.org/gliding/gnss
then go straight to the end where there is the list of IGC-approval
documents for all 43 types of IGC-approved GPS recorders from 16
different manufacturers. BTW, there are three new types of recorder
under test for IGC-approval at this moment.
On the IGC GNSS web site, there are also free downloads and many other
things. For example, the free IGC Shell program for downloading and
validating IGC files, which was created by distinguished SSA member
Marc Ramsey, who often posts on this newsgroup.
The issue with the three legacy Cambridge models was wider than the
lack of Public/Private Key security. With 43 types of recorders with
all sorts of different characteristics, it was becoming more and more
difficult to treat them all in the same way. Therefore, in 2005, IGC
introduced a series of different IGC-approval levels for ALL IGC-
approved recorders. These levels are listed in para 1.1.3.3 of Annex
B to the Sporting Code (also on the IGC web pages).
Another factor with the legacy Cambridges is that the IGC Validation
process does not work with the IGC file, only with the CAI binary
format. There have been several cases of pilots losing flight
validation because they did not realise this and lost the CAI file.
The IGC GFA Committee asked Cambridge several times to change their
external software so that IGC file would validate directly, but this
was not done in the commercial turbulence that happened after Dr David
Ellis sold the business and it moved from Vermont. You might think
that you could always go back to the recorder and extract the CAI
binary. However, this may not be in the recorder because with these
early models, if setup information is changed, previous flights are
erasedfrom the memory. Bear in mind that the memory capacity of all
older-generation recorders is much less than modern ones and, except
for the Volkslogger, old files are over-written when the memory is
full. For instance, I remember a flight by Chris Rollings that was
over 12 hours and his legacy Cambridge recorder ran out of memory at a
4 second fix interval and started over-writing the first bit of the
flight.
If you read the IGC-approval document for the legacy Cambridges, these
cautionary notes are included, and some others.
So that's the moral, every now and again go and look at the
information provided free for you on the IGC web site !
Regards to all SSA people from this side of the pond,
Ian Strachan
Chairman IGC GFA Committee
Lasham Gliding Centre, UK
Old November 2nd 08, 05:14 PM posted to rec.aviation.soaring
Hello Ian:
Thanks for your cogent and comprehensive remarks. Hopefully, these
will prove helpful to others as well.
And thank you for all of your hard work over the years!
Best Regards,
Gary Osoba
Old November 4th 08, 04:46 AM posted to rec.aviation.soaring
danlj
Best Regards,
Gary Osoba
After some private correspondence, Gary Osaba's flight is now posted
on OLC
http://www.onlinecontest.org/olc-2.0...tId=1538997862
dan johnson N18UF
Old November 4th 08, 02:48 PM posted to rec.aviation.soaring
Ian
And that, my friends, is why I'm sticking with clockwork and silver
nitrate!
Ian
Old November 4th 08, 06:04 PM posted to rec.aviation.soaring
kirk.stant
nitrate!
Ian
Which, I believe, are no longer accepted for badge/record claims (at
least in the US - no sure about Britain) - so why bother?
If you really think using a barograph is easier than a logger, you are
a real Luddite!
Cheers,
Kirk
Old November 4th 08, 06:41 PM posted to rec.aviation.soaring
noel.wade
I have no connection to the company, but I absolutely _love_ my
ewMicroRecorder. Flew with it in a few different gliders at a few
different places this year and it worked great everywhere I went.
Built-in GPS and a fully-approved IGC logger for all levels of
flights. It has ONE BUTTON to turn it on and off (and it
automatically turns on if you supply it with ship's power - for "hands-
free" operation). Plugs directly into a PC or Mac to grab the IGC
file (like a USB thumb-drive), or get the SD-card version and just
pull the card at the end of the day. No menu-insanity or switchology
like the Volkslogger or a lot of the fancy flight computers (I can
hook my PDA up to the MicroRecorder and get a lot of the same
functionality, and if the unit is hooked up to ship's power it can
even pass that along to the PDA and charge it in-flight).
Even if you have a comprehensive flight computer, the MicroRecorder is
a great secondary / backup unit. Its also the perfect "club logger"
because its so simple and rugged.
http://www.ewavionics.com/
(and Sold in the US by Cumulus Soaring)
--Noel
Old January 22nd 15, 11:55 AM posted to rec.aviation.soaring
Hi all,
I try to get into contact with Gary Osoba and Matt Michael, two owners of Woodstock,
as I placed a blog about the Woodstock and Gary at my Website UL-Segelflug.de
Could anybody give me the mail-adresses of both pilots? Would be very nice.
I know the thread is already seven years old, but maybe it still works.
Best regards from Germany
Klaus
http://ul-segelflug.de
Old January 22nd 15, 12:13 PM posted to rec.aviation.soaring
Tony[_5_]
They both still read this group
Cross country record: personal shortest flight Michael Ash Soaring 7 July 3rd 07 01:09 AM
777 records record flight [email protected] General Aviation 10 November 15th 05 02:32 AM
Record Soaring Flight by Fosset and Delore Paul Remde Soaring 0 January 27th 05 03:01 PM
Army National Guard celebrates flight safety record Otis Willie Military Aviation 0 June 19th 04 09:16 PM
Record flight video miriano Soaring 9 March 28th 04 09:51 PM
