Bob,
I fly with Brad Hill, and I'm sure he'll vouch for me. I'll take you up on the 10 dollar bet. My old club had a Jr and a Puchacz. Both planes seemed well constructed and gave honest performance along the lines of their published values. Back in college, I did measure our clubs Ka7 using the techniques outlined by Dick Johnson. I still have some of the equipment. Would you accept an independent measurement if we every get one up here in the Northwest? Kevin The only time I've ever used Dr, was back in college when I did some DJ'ing. I was known then as D.J. Dr. Finkenstein. |
On 8 Nov, 03:51, Bob Kuykendall wrote:
On Nov 7, 5:10*pm, KevinFinke wrote: I don't think 40/1 is remotely unreasonable for the Perkoz... Ten bucks says that if the Idafliegs do a polar it tops out at or below 39. Perhaps, but if Dick Johnson were still around he could stick some turbulator tape on it and suddenly get 45 ... Ian |
On Nov 7, 11:36*pm, "noel.wade" wrote:
Couldn't the wing use multiple airfoils or varying thicknesses to get around the need for (as much) washout, despite the moderate taper ratio? *Those wouldn't be immediately obvious from the visuals or 3- views... **shrug* --Noel Multiple airfoils is a slick way to design the desired tip stalling characteristics into a plane. I'm not sure if the Perkoz uses this, but I have noticed it seems to have a good bit of forward sweep to the wing. Forward sweep can certainly be used instead of washout, as demonstrated clearly on the Sisu. Based on independent tests I've seen done on other Polish gliders, I have no reason to doubt the SZD figures for the 54. The Pols have always been rather scientific and less optimistic about their polars and such. -Paul Hanson SZD-59 driver, claimed at 40/1 by SZD (wet w/winglets...) and measured by Johnson at 38/1 (dry w/no winglets...) |
At 14:52 08 November 2008, Ian wrote:
On 8 Nov, 03:51, Bob Kuykendall wrote: On Nov 7, 5:10=A0pm, KevinFinke wrote: I don't think 40/1 is remotely unreasonable for the Perkoz... Ten bucks says that if the Idafliegs do a polar it tops out at or below 39. Perhaps, but if Dick Johnson were still around he could stick some turbulator tape on it and suddenly get 45 ... Ian Quite the reverse - Dick Johnson tended to find that turbulated gliders performed better without the tape. He also usually found lower performance figures than the manufacturer's (and Idaflieg) polars. John Galloway |
![]() On Nov 8, 3:15*pm, John Galloway wrote: Quite the reverse - Dick Johnson tended to find that turbulated gliders performed better without the tape. *He also usually found lower performance figures than the manufacturer's (and Idaflieg) polars. John Galloway John - Actually, it depends. On earlier gliders he started finding benefits to the turbulator tape - which is why he developed the practice of sticking it on gliders he tested.... That's because earlier airfoils tended to have laminar separation bubbles, which could be eliminated by forcing the airflow to go turbulent (which, while higher-drag than laminar flow, is usually less-draggy than a bubble). It went on this way until the airfoils developed for some later gliders started to reverse the trend. I attribute that to the advancement of high-end wind-tunnels, CFD, and other computer-modeling techniques that allowed much better prediction and testing of airfoils for laminar bubbles and other boundary-layer effects. However, many of the gliders that are still popular today (and flown in large numbers) use airfoils that can benefit from select turbulation. --Noel |
lightning stikes a ASK21 | jeplane | Soaring | 15 | May 16th 09 05:03 PM |
Brake pad P/N for ASK21? | [email protected] | Soaring | 2 | September 28th 07 11:10 PM |
FS: ASK21 disassembly tool | Bob Kuykendall | Soaring | 0 | April 25th 07 08:35 PM |
ASK21 vs G103 | solo89 | Soaring | 13 | October 23rd 03 07:15 PM |
