#21
On Nov 11, 7:30*am, Big Wings wrote:
I'm wondering if SeeYou is confused by the fact that the flight wraps around midnight (UTC) and apparently starts after it has ended. When I run animation against the relevant IGC file its starts at the launch time but when it reached midnight UTC (part way along the second leg) it thinks the flight has ended and jumps back to the launch. Looks like this could be a SeeYou bug - even if it's not the root cause of the original landout problem. I believe this is a known problem and I expect Naviter will be fixing it. However if you set the correct UTC Offset in ToolsOptionsGeneral this won't happen. Darryl |
On Nov 11, 7:41*am, Darryl Ramm wrote:
On Nov 11, 7:30*am, Big Wings wrote: I'm wondering if SeeYou is confused by the fact that the flight wraps around midnight (UTC) and apparently starts after it has ended. When I run animation against the relevant IGC file its starts at the launch time but when it reached midnight UTC (part way along the second leg) it thinks the flight has ended and jumps back to the launch. Looks like this could be a SeeYou bug - even if it's not the root cause of the original landout problem. I believe this is a known problem and I expect Naviter will be fixing it. However if you set the correct UTC Offset in ToolsOptionsGeneral this won't happen. Darryl NOT UTC, NOT 302A! Problem was fixed by increasing the Observation zone radius in See You, under 'Tools' / 'Options' / 'Observation zone' Many thanks to 5Z (Tom) and everyone else who looked into this! |
On Nov 11, 8:31*am, Uncle Fuzzy wrote:
On Nov 11, 7:41*am, Darryl Ramm wrote: On Nov 11, 7:30*am, Big Wings wrote: I'm wondering if SeeYou is confused by the fact that the flight wraps around midnight (UTC) and apparently starts after it has ended. When I run animation against the relevant IGC file its starts at the launch time but when it reached midnight UTC (part way along the second leg) it thinks the flight has ended and jumps back to the launch. Looks like this could be a SeeYou bug - even if it's not the root cause of the original landout problem. I believe this is a known problem and I expect Naviter will be fixing it. However if you set the correct UTC Offset in ToolsOptionsGeneral this won't happen. Darryl NOT UTC, NOT 302A! Problem was fixed by increasing the Observation zone radius in See You, *under 'Tools' / 'Options' / 'Observation zone' Many thanks to 5Z (Tom) and everyone else who looked into this! I should have been clear, Tom clearly had nailed it, but the UTC offset will catch people if a flight wraps as Big Wings reported. It may not be an issue, or you may have the offset set correctly in SeeYou on your PC. This comes up when people view a flight trace from a different timezones, and may need to reset their UTC offset to work around this. Darryl |
#24
On Nov 10, 7:13*pm, 5Z wrote:
Consider a 50+ km diameter thunderstorm sitting on top of the turnpoint. *If using a camera to document the flight, you might just be SOL due to not being abole to see any landmarks at or near the turnpoint. But wasn't it ok to verify being in the sector by photographing a recognizable feature in the sector rather than the TP itself. I know that was not valid for US contest TP but it was ok for badges and records wasn't it? It's been a long time since I used cameras. Andy |
| Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 06:32 PM |
| Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 06:32 PM |
| Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 08:48 AM |
| "Airplane Drivers" and "Self Centered Idiots" | Skylune | Piloting | 28 | October 16th 06 06:40 AM |
