![]() "Morgans" wrote What a striker. I love that engine. ***************************** Damn. Sometimes I hate spell checker. I thought I told it to leave that word alone. "Striker" was supposed to read "stroker." What a stroker. It can really chug away in the lower RPM's. Oh, it also has an impulse Fairbanks-Morse magneto. It will crank on the first or second pull, every time. -- Jim in NC |
![]() Tim Ward wrote: There is a thingummy available from Briggs and Stratton called a "glass bowl cutoff". It sits directly under the fuel tank, and has a glass sediment bowl of approximately the size you describe. *It has one input, one output, and a shutoff valve on... I think it's the input. The glass bowl cutoff, the replacement glass bowls, and a picture of both of them can be seen at: http://www.briggs.learnsmallenginere...BScarbkits.htm The assembly is $10.75, the glass bowl replacement is $5.75. Wouldn't it be easier to drill out one of these for better flow rather than making one from scratch? ---------------------------------------------------------------------------------------------- YES! The one in the photo is larger than the one I tested. On the one I had the bowl came to more of a point and the doohicky holding it on was made up of four wires and a screw rather than the straps as shown in the picture. -Bob |
On Nov 16, 6:36*pm, Anthony W wrote:
Wouldn't it be easier to drill out one of these for better flow rather than making one from scratch? -------------------------------------------------------------------------------------------- Dear Tony, Probably so, but I believe we still need to include such things in the archive of drawings. Some people don't have access to the retailers as we have here in the States and there's always the possibility that WE may not be able to buy such things in the future. -Bob |
On Nov 16, 1:27*pm, Ed wrote:
Actually, the tank was located behind the dash on the model A, The model T tank was under the front seat. That is why you had to back up a hill since the drop wasn't sufficient to gravity feed the carb. on a hill. ----------------------------------------------------------------------------------------------------- Dear Ed, Yes, you are correct. My recollection data-base is seventy years old. If someone had asked me relative to where we lived (West Avenue = farm = Model T, vs C Street = house = Model A) I would have aced the test :-) -Bob |
On Sun, 16 Nov 2008 21:45:28 -0800 (PST), "
wrote: On Nov 16, 1:27*pm, Ed wrote: Actually, the tank was located behind the dash on the model A, The model T tank was under the front seat. That is why you had to back up a hill since the drop wasn't sufficient to gravity feed the carb. on a hill. ----------------------------------------------------------------------------------------------------- Dear Ed, Yes, you are correct. My recollection data-base is seventy years old. If someone had asked me relative to where we lived (West Avenue = farm = Model T, vs C Street = house = Model A) I would have aced the test :-) -Bob Actually I checked it out since my brain is old. I had a 1921 model, but I found that they moved the tank under the dash in 1926 and 27. |
On Nov 16, 11:32*pm, " wrote:
On Nov 16, 6:36*pm, Anthony W wrote: Wouldn't it be easier to drill out one of these for better flow rather than making one from scratch? ---------------------------------------------------------------------------*----------------- Dear Tony, Probably so, but I believe we still need to include such things in the archive of drawings. *Some people don't have access to the retailers as we have here in the States and there's always the possibility that WE may not be able to buy such things in the future. -Bob All right! Finally a topic I have extensive first hand experience with instead of my usual neophyte airplane builder syndrome, i.e. just plain ignorant! One of the best sources of a gascolator is found on the sides of used farm tractors from the 1980’s marketed by Ford but built in Japan. Mine is a 1310 20 HP diesel engine model but other models are extensively available in a variety of sizes and HP. Yes, most other tractor’s have them to. What you have is a small gravity fed fuel collector bowl in front of the fuel injectors with an equally small internal filter in place. The fuel bowl is generally plastic but a simple home made adapter will allow you to put a variety of small mouthed bottles on it. Even better is these assemblies are available in either used or new configurations, or as Bob H. would say how good of a scrounger you are. |
On Nov 16, 10:32 pm, " wrote:
On Nov 16, 6:36 pm, Anthony W wrote: Wouldn't it be easier to drill out one of these for better flow rather than making one from scratch? -------------------------------------------------------------------------------------------- Dear Tony, Probably so, but I believe we still need to include such things in the archive of drawings. Some people don't have access to the retailers as we have here in the States and there's always the possibility that WE may not be able to buy such things in the future. -Bob Oh, Man. That problem--the disappearance of many components--is an increasing pain already. I went to the local Radio Shack last week to buy a couple of 9-volt battery terminal clips and they didn't have any and the catalog showed them as discontinued. Can you feature that? And the big electronics shop in the city doesn't have roller-lever microswitches or a decent selection of potentiometers or even a DPDT spring-center-off toggle switch. Nor dop they have the employees who know anything about some of this stuff. It seems that 99.9% of people are buying everything instead of building it, and either contracting out the repair of it or tossing it and buying a new one. Sad. And that's why so many of our young folks have no idea what's under the hood of a car or the cowl of an airplane, or even inside a simple switch or lawnmower engine. Dan |
On Mon, 17 Nov 2008 08:36:50 -0800 (PST), Copperhead
wrote: On Nov 16, 11:32Â*pm, " wrote: On Nov 16, 6:36Â*pm, Anthony W wrote: Wouldn't it be easier to drill out one of these for better flow rather than making one from scratch? ---------------------------------------------------------------------------Â*----------------- Dear Tony, Probably so, but I believe we still need to include such things in the archive of drawings. Â*Some people don't have access to the retailers as we have here in the States and there's always the possibility that WE may not be able to buy such things in the future. -Bob All right! Finally a topic I have extensive first hand experience with instead of my usual neophyte airplane builder syndrome, i.e. just plain ignorant! One of the best sources of a gascolator is found on the sides of used farm tractors from the 1980’s marketed by Ford but built in Japan. Mine is a 1310 20 HP diesel engine model but other models are extensively available in a variety of sizes and HP. Yes, most other tractor’s have them to. What you have is a small gravity fed fuel collector bowl in front of the fuel injectors with an equally small internal filter in place. The fuel bowl is generally plastic but a simple home made adapter will allow you to put a variety of small mouthed bottles on it. Even better is these assemblies are available in either used or new configurations, or as Bob H. would say how good of a scrounger you are. Tractor "sediment bowls" are available at TSC for about $55 Canadian. They have glass bouls thugh, and in Canada you will not get the OK on a homebuilt / experimental with a glass bowl. |
On Nov 17, 3:27 pm, wrote:
Tractor "sediment bowls" are available at TSC for about $55 Canadian. They have glass bouls thugh, and in Canada you will not get the OK on a homebuilt / experimental with a glass bowl. Didn't know that. Got a glass one on my Jodel, but it was licensed in the '70s. It's a thickwalled (1/4" or 5/16" thick) glass tube, actually, with cast aluminum or zinc top and bottom pieces. Not likely to break unless I drop it on the concrete at annual time. I think, since we have a lathe and mill here, I'll just buy a chunk of 2" 6061T6 aluminum round bar and machine my own for the Hummelbird. 2011T3 would be better if I could find it. Dan |
Is this a safe location for a Gascolator? | flybynightkarmarepair | Home Built | 0 | May 29th 07 01:38 AM |
Gascolator | Jonathan Goodish | Owning | 10 | September 29th 05 01:02 PM |
