On Nov 17, 12:45*pm, Stephen Haley wrote:
Have been watching the threads on the 310 with interest - my google trap fror the 310 recently threw up a potential Portrait mode driver - I dont have a 310 so this is UNTESTED seehttp://kpr3712.npage.de/downloads_89312177.html rgds Stephen Stephen, Thanks it worked and the screen is rotated portrait running SeeYou Mobile. It took a lot of fussing around. Richard www.craggyaero.com |
If you really want to use iPaq 310 platform, you can also run GPS_LOG
WinCE on it after you load some aditional software into it. More information on the Yahoo GPS-LOG users group (http://groups.yahoo.com/group/GPS_LOG/) Cheers, Henryk Birecki brianDG303 wrote: Lots of us run flight software on a PDA and complain about the dim and hard to read screen and can't help noticing those big bright GPS's we get to drive around with. It looks like SeeYou Mobile will soon run on some GPS platforms and it's now in beta running on the HP IPAQ 310 (Travel Companion) family. These are available for $180 factory refurbished or for $225 new. There are a ton of reviews to google and I'm not going to repeat that information here, but a few things- the overall size of the 310 is a little smaller than my IPAQ 3970 but the screen is a little bigger. The 310 is a landscape only display and measures 94mm wide by 58mm tall. Screen brightness- The 310 is 4x the brightness of the IPAQ 3970 and the same brightness as most other automotive GPS’s. There are other advantages to the 310 over a PDA, the anti reflective coating is state of the art so no aftermarket glare film is needed, and those cut the light output by at least 16%. The crispness and contrast of the screen, which is off the charts, help a lot. And the easy to adjust mount combined with fair off-angle viewing allows the unit to be adjusted to an angle that will minimize glare. Other news of interest: already an outfit in Europe has connected an HP 310 running SYM 3.1 beta to FLARM via a serial to bluetooth adapter, there is a link to a video of this, as well as a link to a comparison photo of SYM on a 310 and a PDA on the Naviter forum site. PocketFMS, PDA flight software for powered flight, is ahead of everyone else in this game and have a longer list of PNA's that will run ported software. This will give a clue as to which PNA's are good candidates for this conversion in the long run and what attributes they'll have. The firmware (I think that is the limitation) of each PNA's version of WindowsCE determines some of the features. (I don't know much about operating systems and am on shakey ground here, corrections invited) For instance, The 310 display runs in landscape mode as opposed to PDA's portrait, and for flight software it seems like portrait is better. The firmware (or whatever) of the 310 does not allow it to be run in portrait, other PNA's will. The PocketFMS people use the bluetooth connection to integrate ZAON traffic alerts so this is another possibility for gliders. Brian |
{It took a lot of fussing around.}
Richard, thanks for that. The gang at PocketFMS swears up and down it can't be done so I assumed it was not possible. Is this fussing that can be explained, or is it beyond us mortals? I personally could be happy with landscape. mounts. I suspect that using the suction cup to stick the 310 to the glass face of the altimeter won't get much approval. The ball and socket part of the mount ends in a 1/2" flat that meets the flat of a tightening knob. If the suction cup support arm was cut away a small hole could be drilled into flat stock (or the panel itself)and the 310 mount could be attached by by using the tightening knob as a mounting bolt. |
On Nov 17, 6:01*pm, Richard wrote:
It took a lot of fussing around. That's what PDAs are for ! See ya, Dave "YO electric" |
On Nov 17, 3:30*pm, brianDG303 wrote:
{It took a lot of fussing around.} Richard, thanks for that. The gang at PocketFMS swears up and down it can't be done so I assumed it was not possible. Is this fussing that can be explained, or is it beyond us mortals? I personally could be happy with landscape. mounts. I suspect that using the suction cup to stick the 310 to the glass face of the altimeter won't get much approval. The ball and socket part of the mount ends in a 1/2" flat that meets the flat of a tightening knob. If the suction cup support arm was cut away a small hole could be drilled into flat stock (or the panel itself)and the 310 mount could be attached by by using the tightening knob as a mounting bolt. Brian, Fisrt of all you need SeeYou Mobile installed on the SD Card. Then start the 310 SeeYou Mobile will run, shut it down and connect with active sync. You have to copy the .cab file to the flash drive of you Ipaq 310 and run it to install. Then run the rotate program it installs. I will have a cable and power converter kit on my web in a couple of days to power the 310 from your glider battery. I will also have mounting solutions with a tilt swivel that connects to goosenecks or ram mounts that I already sell. The GPS seems to work OK with the unit sideways, I will do more testing. Also I have contacted SeeYou with the information. Some tuning of the Beta program will be needed to make it look better. But it appears to work. Richard www.craggyaero.com |
On Nov 17, 3:35*pm, DRN wrote:
On Nov 17, 6:01*pm, Richard wrote: It took a lot of fussing around. That's what PDAs are for ! See ya, Dave "YO electric" Dave, That is why I designed and manufacture the Ultimate no fussing. We could do a custom 24" diagonal screen for you will all your available battery power. http://www.craggyaero.com/ultimate.htm Richard www.craggyaero.com |
On Nov 17, 4:40*pm, Richard wrote:
On Nov 17, 3:35*pm, DRN wrote: On Nov 17, 6:01*pm, Richard wrote: It took a lot of fussing around. That's what PDAs are for ! See ya, Dave "YO electric" Dave, That is why I designed and manufacture the Ultimate no fussing. *We could do a custom 24" *diagonal screen for you will all your available battery power. http://www.craggyaero.com/ultimate.htm Richardwww.craggyaero.com Richard, then Dave will want a 24" diameter image of an ILEC SN10. |
On Nov 17, 7:40*pm, Richard wrote:
Dave, That is why I designed and manufacture the Ultimate no fussing. *We could do a custom 24" *diagonal screen for you will all your available battery power. Unfortunately Richard, my glider, as with many popular motorgliders, cannot accomodate this in the panel. Motor- control, radio, transponder, full-size ASI, mini-Alt, two mini-varios, and the ILEC SN10 fills the remaining space... Thanks for the offer though ! See ya, Dave "YO electric" |
Software for flight planning???? | Prop | Piloting | 14 | March 9th 06 04:02 PM |
flight log software | Momme Mommsen | General Aviation | 0 | April 14th 05 10:02 AM |
Safelog software/flight log software question | Mark | Piloting | 2 | December 8th 03 02:34 PM |
Flight Log software for Palm OS? | Henryk Birecki | Soaring | 2 | August 29th 03 10:28 AM |
Flight Planning software | PA28Rdrvr | Instrument Flight Rules | 6 | August 12th 03 12:18 AM |
