... Cancer Report for Wed, 19 Nov 2008 @ 1700 I was initially diagnosed with Multiple Myeloma on 14 June 2008. The diagnosis was confirmed on 20 June 2008. X-ray and MRI located the tumor in my pelvic girdle and lower spine. Over a two-week period X- ray therapy was used to kill as much of the tumor as possible without damaging the adjacent healthy bone & tissue. Following the X-ray therapy I was put on an aggressive regime of chemotherapy which was adjusted from week to week based on data provided by periodic blood tests. The blood tests indicated I was doing quite well with regard to the tumor but I was wracked by a constantly increasing level of pain in my lower back. On 22 October a series of X-rays revealed I'd suffered a compression fracture of the #3 lumbar vertebrae. On 30 October I underwent vertebroplasty, a surgical procedure in which the crushed vertebrae is first returned to its original length and configuration then fixed in that position by injecting a fast- setting cement into the voids the tumor had created INSIDE of the vertebrae. The procedure was successful. The cessation of pain allowed me to devote more time to the exercises needed to restore the musculature that had been destroyed by the tumor... and by the chemotherapy. Today, the 19th of November, 2008, the aggressive regime was deemed a success and was replaced with a more benign regime using drugs that do not have the side-effects of the original regime. I still have cancer. I'm still as weak as a cat. But the cancer has been reduced to a manageable state that may lead to remission. The weakness now depends on my determination to overcome it. --R.S.Hoover The five-year survival rate for MM is not the greatest. http://cancer.emedtv.com/multiple-my...ival-rate.html One in three. But, I'm sure you've done the research. Hope you manage to buck the odds. To do that you've got to eat and get your strength back. This includes exercise. Swimming might be good for you as your spine probably precludes impact activity. This "weak as a cat" stuff just won't get it. Too bad chemo tends to suppress the appetite. Try smoking pot. Anything to get your appetite back. -- Gregory Hall |
On Nov 19, 9:46*pm, "Morgans" wrote:
Jim: *YOU have done that, by keeping your projects alive, and going, as best you could. *Keep up the good fight. *Your news today, I believe is just one in a long line of successes. --------------------------------------------------------------------------------------------------- Dear Jim, et al, Now my hat don't fit... How are we going to solve that one? :-) ------------------------------------------------------------------------------------------------------ I'm scheduled for another MRI today, this one will focus on my right hip which has formed an unexplained lump. ------------------------------------------------------------------------------------------------------ The most worry-some side-effect is neuropathy along my left side. Neuropathy is a fancy name for ANY kind of pain or unusual behavior. In this case it means my left arm & hand have 'gone to sleep.' I'm unable to grasp things with my left hand. AND I CAN'T TYPE. I'm doing okay now but the tingling will become worse as the day wears on until my left hand becomes disabled. The problem here is that neuropathy resulting from a drug interaction or side-effect is often PERMANENT. The physician has discontinued the drugs that are the most likely candidates for causing this particular side-effect but it will take several days for my system to flush-out the remnants. My worry here is that if the effect proves permanent, I may not be able to type. I'll just have to wait and see. -R.S.Hoover |
On Nov 20, 10:06*am, " wrote:
On Nov 19, 9:46*pm, "Morgans" wrote: Jim: *YOU have done that, by keeping your projects alive, and going, as best you could. *Keep up the good fight. *Your news today, I believe is just one in a long line of successes. --------------------------------------------------------------------------------------------------- Dear Jim, et al, Now my hat don't fit... *How are we going to solve that one? *:-) ------------------------------------------------------------------------------------------------------ I'm scheduled for another MRI today, this one will focus on my right hip which has formed an unexplained lump. ------------------------------------------------------------------------------------------------------ The most worry-some side-effect is neuropathy along my left side. Neuropathy is a fancy name for ANY kind of pain or unusual behavior. In this case it means my left arm & hand have 'gone to sleep.' *I'm unable to grasp things with my left hand. *AND I CAN'T TYPE. *I'm doing okay now but the tingling will become worse as the day wears on until my left hand becomes disabled. The problem here is that neuropathy resulting from a drug interaction or side-effect is often PERMANENT. *The physician has discontinued the drugs that are the most likely candidates for causing this particular side-effect but it will take several days for my system to flush-out the remnants. *My worry here is that if the effect proves permanent, I may not be able to type. *I'll just have to wait and see. -R.S.Hoover Thanks for the update Bob. It is in the early stages, I'm sure you can flush out that side-effect. Monk |
In article
, " wrote: On Nov 19, 9:46*pm, "Morgans" wrote: Jim: *YOU have done that, by keeping your projects alive, and going, as best you could. *Keep up the good fight. *Your news today, I believe is just one in a long line of successes. ---------------------------------------------------------------------------- ----------------------- Dear Jim, et al, Now my hat don't fit... How are we going to solve that one? :-) ------------------------------------------------------------------------------ ------------------------ I'm scheduled for another MRI today, this one will focus on my right hip which has formed an unexplained lump. ------------------------------------------------------------------------------ ------------------------ The most worry-some side-effect is neuropathy along my left side. Neuropathy is a fancy name for ANY kind of pain or unusual behavior. In this case it means my left arm & hand have 'gone to sleep.' I'm unable to grasp things with my left hand. AND I CAN'T TYPE. I'm doing okay now but the tingling will become worse as the day wears on until my left hand becomes disabled. The problem here is that neuropathy resulting from a drug interaction or side-effect is often PERMANENT. The physician has discontinued the drugs that are the most likely candidates for causing this particular side-effect but it will take several days for my system to flush-out the remnants. My worry here is that if the effect proves permanent, I may not be able to type. I'll just have to wait and see. There are ways to deal with that problem, such as chording keyboards. Helped a friend of mine who lost one side to a stroke. But worry about that when it's definite. Sufficient unto the day is the evil thereof, and all that. |
![]() wrote I'm scheduled for another MRI today, this one will focus on my right hip which has formed an unexplained lump. ------------------------------------------------------------------------------------------------------ Jim: Good luck. Theere are bound to be ups and downs. The most worry-some side-effect is neuropathy along my left side. Neuropathy is a fancy name for ANY kind of pain or unusual behavior. In this case it means my left arm & hand have 'gone to sleep.' I'm unable to grasp things with my left hand. AND I CAN'T TYPE. I'm doing okay now but the tingling will become worse as the day wears on until my left hand becomes disabled. Jim: I wonder if that is more problems with the spine, and nerves being pinched. I have a bad back that often gives me similair syptoms in my leg. The problem here is that neuropathy resulting from a drug interaction or side-effect is often PERMANENT. The physician has discontinued the drugs that are the most likely candidates for causing this particular side-effect but it will take several days for my system to flush-out the remnants. Jim: Keep us up on how the "flush" goes. We will hope that does it. My worry here is that if the effect proves permanent, I may not be able to type. I'll just have to wait and see. Jim: Plenty of one handed typers, out there. Plenty of one handed mechanics, and everything out there, too. Let's not go there, yet, though. Again, my thoughts and prayers will be with you on your journey. Good luck, and best wishes to you. -- Jim in NC |
On Thu, 20 Nov 2008 07:06:09 -0800 (PST), "
wrote: I'm scheduled for another MRI today, this one will focus on my right hip which has formed an unexplained lump. are you sure now that you arent a pimple on the arse of a very patient frog? (it's an old bar room joke :-) about a drunk ordering another beer...) ol' snake unda the verandah. |
Cancer | [email protected] | Home Built | 18 | November 8th 08 04:52 AM |
The Cancer Engine | [email protected] | Home Built | 3 | July 12th 08 02:03 PM |
cancer?? | Tri-Pacer | Piloting | 11 | October 24th 07 08:38 PM |
Cancer | purtybird0 | Piloting | 4 | July 4th 07 12:34 AM |
Medical after cancer | Chas[_2_] | Piloting | 37 | March 20th 07 11:48 PM |
