steel 4130
Old October 17th 03, 09:01 AM
Philippe Vessaire
Default steel 4130
Hello,
when I read 90,000 lb/sqi for strength,
is it just before the part is broken or is it the elastic limit?
Thanks
Philippe Vessaire Ò¿Ó¬
Old October 17th 03, 03:46 PM
Cam
That would be UTS , ultimate tensile strenght. I think yeild
strength is at what point the material starts stretching.
Personally, I've had a problem with numbers, so i tend to
do destructive testing with a pull ram and a pressure gauge. As far as
chromolly steel goes, it seems to "snap"
right at the point of stretching. So I'd imagine its Yeild Strength is very
close to its UTS .
If you see two numbers for strength, pick the lesser one and halve it , and
design from that .
Cheers (no qualifications) Cam...
Thanks
Old October 17th 03, 06:00 PM
Paul Lee
Wicks aircraft catalog gives two values for 4130:
min tensile (breaking) 95,000 and min yield (where it starts
distorting) 75,000. Usually the initial yielding will have quite
a bit of strength giving you a chance to get back down. But
repeated cycles will weaken it and rupture. Check the structure
for any cracks and fix it.
Paul Lee, SQ2000 canard project: www.abri.com/sq2000
Philippe Vessaire wrote in message -moi...
Hello,
Thanks
Old October 17th 03, 08:28 PM
O-ring Seals
close to its UTS .
design from that .
Cam,
While that might sound like a good (and conservative) approach to the
design, he probably wants to build something that will be able to get
off the ground. If your suggested technique were to be used
throughout the aircraft, it would probably be too heavy to fly.
O-(some qualifications)Ring
Welding techniques for 4130? Building The Perfect Beast Home Built 29 September 4th 03 08:52 PM
4130 frame? Steve Thomas Home Built 23 August 27th 03 05:50 PM
