![]() Tech Support wrote in message ... Merlin in 51 had a 2-1 gear reduction. 3000 rpm gave 1500 rpm prop speed as I recall. Many of the old big "V" and inline engines were 2:1, and were using the front end of a very strong camshaft as the prop drive, weren't they? -- Jim in NC |
![]() "Dana M. Hague" wrote in message ... On Tue, 25 Nov 2008 19:29:06 -0800 (PST), wrote: Both the Merlin and Allison V-12s were geared. And most of the big radials were geared. It was one of the few ways to get more horsepower out of a given displacement. Gearing an engine doesn't increase the horsepower; it multiplies the torque and divides the rpm down to a more usable (by the propeller) level. It does allow you to build a faster turning (and thus higher horsepower) engine and still be able to use it. In general, the way to get more horsepower out of a given displacement is to turn the engine faster, within limits of course. With the higher rpm's come increased wear and heat. In the "old" days (up to the mid 1930's or so) the available materials weren't adequate for a high revving engine, so low rpm's were the norm, and by happy coincidence the avilable rpm's were pretty well matched to propeller sizes convenient for the aircraft. As the technology advanced and higher rpm's became reasonable, reduction drives began to appear, especially on higher powered military aircraft... with some compromise (as others have pointed out) in reliability. Most of the small aircraft engines in use nowadays are derived from those 1930's engines, with only minor improvements. The A-65, for example, was redlined at 2300 rpm; the A-75, if I recall correctly, was the same engine upgraded to turn a little faster, and today's 0-200 turns around 2600 rpm if I'm not mistaken. By contrast, modern car engines are redlined at up to 8000 rpm. There two main reasons we're still using the "old style" aircraft engines. First is cost; not only does the gearing and such cost more money, but the existing engine designs are long amortized. Developing a new engine costs a lot of money, especially with the costs of _certifying_ a new engine. Second is reliability and longevity; a big slow turning engine is more reliable and lasts longer than a smaller fast turning engine of the same horsepower. Where we _are_ seeing reduction drive engines is in the ultralight / light sport area, where weight is much more critical. The ultralight movement introduced fast turning 2-stroke engines, mostly snowmobile derived, to aviation. When your engine turns 6500 rpm you NEED a reduction drive! For an ultralight, light weight is far more important than a 2000 hour TBO. In the case of the Rotax 912, a geared 4-stroke, Rotax was already used to building engines with redrives, so it made sense for them to take that approach. -Dana -- The gene pool could use a little chlorine. To expand the above points just a little: IIRC, snowmobiles are/were derived from chain saws--which required an engine light enough for a man to carry and use as a hand held tool. That made them an obvious choice for another application were light weight was the most critical factor--even at the cost of reliability and maintenance intervals... |
Gear boxes had bearings designed to handle prop loads. Engine only saw torque and no thrust or side loads, etc. Only engine I can remember was either a Lyc or Con that drove prop off cam shaft. Was not very popular for some reason and only lasted a few years???? Someone with experience with those engines might want to chime in and comment. Big John ************************************************** On Thu, 27 Nov 2008 07:15:24 -0500, "Morgans" wrote: Tech Support wrote in message .. . Merlin in 51 had a 2-1 gear reduction. 3000 rpm gave 1500 rpm prop speed as I recall. Many of the old big "V" and inline engines were 2:1, and were using the front end of a very strong camshaft as the prop drive, weren't they? |
Morgans a écrit :
Many of the old big "V" and inline engines were 2:1, and were using the front end of a very strong camshaft as the prop drive, weren't they? Rolls Royce and Allison V engines were (are) overhead camshafts. The prop reduction gear was driven from the nose of the crankshaft. According to Rolls Royce, the Merlin XX drive ratio was 0.42. Best regards, -- Gilles http://contrails.free.fr |
Tech Support wrote:
Jim Gear boxes had bearings designed to handle prop loads. Engine only saw torque and no thrust or side loads, etc. Only engine I can remember was either a Lyc or Con that drove prop off cam shaft. Was not very popular for some reason and only lasted a few years???? Someone with experience with those engines might want to chime in and comment. You don't often see that because any torsional resonance problems get amplified at an even-multiple ratio, like the cam's 2:1 ratio. Note the final drive ratio of almost any reduction gear train & it will be some odd number like 2.17:1, 2.85:1, etc. (Those are the options available on a common reduction drive for rotaries, & the planetary gear set comes from a heavy duty Ford automatic trans. BTW, someone mentioned 'no thrust or side loads' with planetary gears. There can actually be very high thrust loads if the gear set uses helical cut gears instead of spur gears to get more contact area for a given gear thickness. The drive mentioned above had to have a thrust bearing added to its input shaft after early testing because it destroyed the light duty thrust bearing on the rotary's E-shaft. Charlie |
On Nov 27, 11:58*am, Tech Support wrote:
Only engine I can remember was either a Lyc or Con that drove prop off cam shaft. Was not very popular for some reason and only lasted a few years???? The Continental Tiara 6-285. Kept breaking that shaft, IIRC. There's still a TCDS on it so there's a few out there yet. Dan |
On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm"
wrote: IIRC, snowmobiles are/were derived from chain saws--which required an engine light enough for a man to carry and use as a hand held tool. That made them an obvious choice for another application were light weight was the most critical factor--even at the cost of reliability and maintenance intervals... I've never heard that, seems unlikely... they are really very different, except for both (along with outboard motors) being 2-strokes. All for the same reason of light weight. -Dana -- If you glue a piece of toast, butter side up, to your cat's back, and drop it from a high place, which way will it land? |
![]() "Charlie" wrote You don't often see that because any torsional resonance problems get amplified at an even-multiple ratio, like the cam's 2:1 ratio. Note the final drive ratio of almost any reduction gear train & it will be some odd number like 2.17:1, 2.85:1, etc. Perhaps an even larger factor is to get different teeth meshing together in a cycle, each time around. it is better to not have the same mesh, time after time, although what you say about harmonics is also a factor. In the really big "warbird"engines, the gearboxes had to be built so hell-for-stout to deal with the HP levels, the harmonics were not as much of an issue because the resonance was hard to achieve with the components being so stiff. -- Jim in NC |
![]() wrote The Continental Tiara 6-285. Kept breaking that shaft, IIRC. There's still a TCDS on it so there's a few out there yet. TCDS?? -- Jim in NC |
Preheating engines: Airplane engines versus auto engines | Peter R. | Owning | 86 | January 2nd 08 07:48 PM |
Torque wrenches... | .Blueskies. | Home Built | 3 | January 11th 06 02:20 PM |
Autogas and high end engines | John Skorczewski | Home Built | 10 | August 17th 04 05:19 PM |
High-Strength Aluminum Helps 2-Stroke Engines | sanman | Home Built | 4 | April 29th 04 12:32 AM |
High-Strength Aluminum Helps 2-Stroke Engines | sanman | Rotorcraft | 4 | April 29th 04 12:32 AM |
