Secondary Stall
Old December 7th 08, 03:04 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
w3n-a
Default Secondary Stall
http://w3n-a.blogspot.com/2008/12/secondary-stall.html
This stall is called a secondary stall since it may occur after a
recovery from a preceding stall. It is caused by attempting to hasten
the completion of a stall recovery before the airplane has regained
sufficient flying speed. When this stall occurs, the back-elevator
pressure should again be released just as in a normal stall recovery.
When sufficient airspeed has been regained, the airplane can then be
returned to straight-and-level flight.
This stall usually occurs when the pilot uses abrupt control input to
return to straight-and-level flight after a stall or spin recovery. It
also occurs when the pilot fails to reduce the angle of attack
sufficiently during stall recovery by not lowering pitch attitude
sufficiently, or by attempting to break the stall by using power
only.
Old December 7th 08, 04:40 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
brianDG303
Can we block this idiot?
Old December 7th 08, 06:59 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
Tuno
I reported it (to Google Groups) as spam.
Old December 7th 08, 07:33 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
Steve Hix
In article
w3n-a wrote:
[snip]
Into the killfile for you.
Old December 7th 08, 02:58 PM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
Dudley Henriques[_2_]
sufficient flying speed. *When this stall occurs, the back-elevator
only.
Usenet's amazing!!! :-)))
WHAT a marketing strategy!!!! The only good thing I can think of about
this is that it might have been placed here by this guy's
competition :-))))))))))))))))))))))))))))
Dudley Henriques
Old December 8th 08, 03:52 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
Peter[_4_]
ok, let's give the benefit....................so, what is the
point???????????
"w3n-a" wrote in message
only.
Old December 8th 08, 03:56 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
Steve R.[_2_]
On a fixed wing forum, the info is makes sense and it good to know. On a
rotory wing forum, it's totally irrelevant.
"Peter" wrote in message
point???????????
only.
Old December 8th 08, 05:09 AM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
309
You guys have it all wrong: This is what sleepy tow pilots do!
Pete
#309 (and former tow pilot)
Old December 8th 08, 03:57 PM posted to rec.aviation.restoration,rec.aviation.rotorcraft,rec.aviation.simulators,rec.aviation.soaring,rec.aviation.student
On Dec 7, 10:09*pm, 309 wrote:
You guys have it all wrong: *This is what sleepy tow pilots do!
Pete
This is an aircraft RESTORATION forum. No one here gives a rats's foot
for what sleepy tow pilots do!
Secondary Stall w3n-a Owning 12 December 10th 08 08:13 PM
Secondary Stall w3n-a General Aviation 10 December 10th 08 08:10 PM
Secondary Stall w3n-a Piloting 18 December 10th 08 08:10 PM
Secondary Stall w3n-a Home Built 3 December 10th 08 01:36 PM
Secondary Stall w3n-a Soaring 11 December 10th 08 01:35 PM
