EW loggers and Linux + WINE
Old December 16th 08, 08:27 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default EW loggers and Linux + WINE
Has anybody tried succeeded in getting the EW Uploader to run on Linux
under WINE and successfully talk to an EW Model D?
I'm using WINE 1.1.9 under Fedora 9. The uploader seems to run OK and can
see the logger when I boot it, but for some reason its not managing to
login to the model D. The Port list window shows the uploader trying to
connect to the logger for 2 seconds or so. Then the port state goes back
to "Awaiting connection" and the logger starts flashing.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 17th 08, 01:13 AM posted to rec.aviation.soaring
bod43
On 16 Dec, 20:27, Martin Gregorie
This by the way is complete guesswork but
may with a bit of luck be worth considering.
The first thing that springs to mind is the
configuration of the serial port.
A google of [wine serial port] produces a few hits
that suggest that it is not all automagic (which is
perfectly reasonable).
Linux will need to release the port to wine and
windows will need to understand what ports are
available and what to refer to them by - com1, com7?
Old December 17th 08, 03:23 PM posted to rec.aviation.soaring
can see the logger when I boot it, but for some reason its not managing
to login to the model D. The Port list window shows the uploader trying
to connect to the logger for 2 seconds or so. Then the port state goes
back to "Awaiting connection" and the logger starts flashing.
This by the way is complete guesswork but may with a bit of luck be
worth considering.
The first thing that springs to mind is the configuration of the serial
port.
A google of [wine serial port] produces a few hits that suggest that it
is not all automagic (which is perfectly reasonable).
Linux will need to release the port to wine and windows will need to
understand what ports are available and what to refer to them by - com1,
com7?
Problem solved. I now have the latest version of the EW Uploader running
successfully on Linux under WINE 1.1.9.
I thought I could simply FTP my (oldish) copy of the uploader across to
Linux: the result semi-worked as described above. Then I found that there
is a 2003/4 Uploader release on the EW website that fixes some problems
with USB-Serial converters. I downloaded that and installed it by running
its installer under WINE. That 'just worked'.
This uploader version now talks to my model D through one of the built-in
serial ports on my motherboard. However, it still won't deal with the USB-
serial converter. That could be down to a number of reasons, ranging from
it simply not liking my converter through incompatibilities with the
Linux USB management system. Maybe WINE needs the Windows USB drivers to
be installed. Who knows.
I'm ignoring the USB problem because I have another solution. Both my
serial ports have permanent uses and I could do with a few more anyway,
so rather than waste time fooling with USB, I'll simply drop in a six
port PCI card and use that for the uploader.
org |
Old December 17th 08, 07:07 PM posted to rec.aviation.soaring
On Wed, 17 Dec 2008 16:26:49 +0000, Tim Newport-Peace wrote:
Now if you had said that you were trying to work via a Serial/USB
converter...
These can give problems even in native Windows. It largely depends on
the manufacturer of the converter. What make/model were you using?
Yes, I'm aware that they can be a bit dodgy and worse, I've set up WINE
to pretend its Win95, which is really pre USB.
How does a USB serial adapter appear to a Windows system and is a driver
needed? On a Linux program a USB serial adapter is to all intents and
purposes just another serial port (COM1-COM4 are /dev/ttyS[0-3] and USB
adapters are /dev/ttyUSB[0-9] but the name is the main [only?]
difference).
I'm using pfrac.com's U232-P9 USB-serial adapter. It costs a bit more
than the Belkin, but its selling point has always been that it 'just
works'. I've never tried it with Windows, but its always done what it
says on the tin with Linux. I've never noticed any slowness, but then
I've never run it faster than 9600 baud.
A serial_PCI/Cardbus connection seems to be the best answer. I have
never tried the Serial ExpressCard solution however.
I've just ordered a 6 serial port PCI card. That may be slight overkill,
but at least its cheap overkill.
org |
Old December 17th 08, 11:37 PM posted to rec.aviation.soaring
Oops. For 'pfrac.com' read 'pfranc.com'.
org |
OLC Loggers RN Soaring 8 November 17th 07 12:11 AM
Wine with your 100LL? tom Piloting 52 January 1st 06 03:54 AM
IGC loggers again tango4 Soaring 3 July 14th 04 05:50 PM
Vanity Loggers? Steve Soaring 0 October 5th 03 03:54 AM
x-plane under wine Tim Hogard Simulators 1 August 31st 03 01:28 PM
