[OT] USA - TSA Obstructing Armed Pilots?
Old December 26th 03, 02:14 AM
John R Weiss
"Mary Shafer" wrote...
Not on my airplane, I hope. Nice tidy little bullets are one thing,
but a handful of shot is another entirely. Pressurization systems are
good, but there is a limit.
As in most things, "it depends"...
If you are thinking about a 10 or 12 gauge shotgun loaded with #4 buck or larger
in normal loads, you are probably right (though I haven't done or seen any
analysis). With "bird shot" (#7 or 8 lead), though, the trade-off would be the
close-range "column of shot" effect vs lesser penetration. Even with a cylinder
bore in a 18 1/2" or sawed-off (highly illegal in most cases) barrel, the shot
does not disperse significantly until some finite distance from the barrel.
Until then, the shot is effectively a .72 cal (for 12 gauge) slug with muzzle
energy of 2000-3000 ft-lb.
OTOH, a short .410 gauge shotgun will likely have less muzzle energy (650 ft-lb
typical for slugs) than a max .45 Colt (410-840 ft-lb -- using comparative
figures for a multi-purpose [.45 Colt/.410 shotshell] Thompson/Center Contender
handgun) or typical .44 magnum (1100-1600 ft-lb) load, and slightly more than a
..45 auto (350-530 ft-lb). A 16 or 20 gauge shotgun will, obviously, be
somewhere in between (1400-2000 ft-lb).
I suppose I would worry most about a short-range "clean miss" with a 12-gauge
and buckshot -- it would make a BIG hole. Also, I would worry about ANY miss
with ANY firearm -- the potential for injuring innocent passengers is high
(though more acceptable than crashing the airplane and killing everyone).
However, longer-range "misses" with smaller-size shot would be less likely to be
lethal or damage-producing, and may be stopped by a seat back or partition.
OTOOH, I have seen evaluations of shotshells in .357 and .45 Auto caliber in
handgun loads. They are much less effective than any solid bullet load against
clothed bodies.
  #43
Old December 26th 03, 02:32 AM
Juvat
After an exhausting session with Victoria's Secret Police, "John R
Weiss" blurted out:
What kind of numbers are you looking at with a H&K USP 40 Compact LEM?
Just curious...and out of pocket for five days.
Juvat
  #44
Old December 26th 03, 03:11 AM
Jim Yanik
"Paul J. Adam" wrote in
news
In message , Jim Yanik
writes
Ed Rasimus wrote in
m:
My point exactly. Security clearance and arming individuals are
apples and oranges.
A security clearance is a form of TRUST,is it not? It says something
about a person's character.
Would an untrustworthy person be able to obtain a security clearance?
A very few have, and have done a lot of damage as a result. The
clearance routine is good but not perfect.
NO system is perfect.But because we cannot achieve perfection doesn't mean
we should do nothing.
Consider the 34 US states that allow concealed carry;the number of those
people who commit gun crimes or get their permits revoked due to gun misuse
are extremely low,fractions of one percent.They haven't gone mad and shot
up places.Vermont doesn't even require any permit,one can carry if they
wish.
Yet,people worry that pilots,many with former military service,might misuse
their weapons aboard a commercial flight.(but won't fly their plane into a
building)
IMO,they're missing the big picture.
Jim Yanik
jyanik-at-kua.net
  #45
Old December 26th 03, 03:59 AM
Harry Andreas
"Paul J. Adam" wrote:
In message , Ed Rasimus
writes
On Thu, 25 Dec 2003 01:03:54 GMT, Mike Marron
Jeez Juvat, *that* really helped. I just had my wife read your
response but I'm afraid your "RELAX.......LOTS OF GUYS WITH
GUNS ON US AIRLINERS RIGHT NOW" failed to set her at ease,
if ya' know what I mean.
Lemme see, your wife is one of those who doesn't like good guys with
guns around her, but ignores the fact that the bad guys with guns will
be there regardless?
Having been through a few passenger screenings for transatlantic flight
recently, how are "bad guys" meant to get aboard with available
firearms? If my belt buckle sets off the alarms then a handgun will do
so. (Please no foolishness about Glocks being 'undetectable', I owned
one and the frame is barium-filled plastic with metal inserts, the slide
solid steel - superb handguns but fully compliant with security
requirement)
Barium filled ?
I own two, and I've never heard anything about Barium.
Can you provide a cite? I'm interested.
Harry Andreas
Engineering Raconteur
  #48
Old December 26th 03, 04:38 PM
John Hairell
On Wed, 24 Dec 2003 20:34:30 -0800, Mary Shafer
On Wed, 24 Dec 2003 23:12:31 GMT, Ed Rasimus
Well, although you may have good reason for what you say, in my
experience, both in the military and in industry, there was never any
problem in the statement that one possessed a security clearance. In
fact, in industry, your company ID badge displayed stars to quickly
identify the level of your clearance. Two stars = secret, three stars
= TS.
NASA stopped doing that a while back. We used colored borders on the
badges, so we all had to get new badges without that information.
NASA may have stopped doing it where you worked but not where I work -
the guidelines aren't followed the same way all across the agency.
I's actually bad security form to identify clearance level via
color-coded badges, because it makes specific people identifiable to
hostile intelligence services. In many cases though the ease of
using color-coded badges overcomes the hassle of doing it in some
other way. Also, it's the first thing people think of when designing
badge systems, i.e. "Hey, why don't we use different colors to
designate access levels?".
And, your access to specific compartmentalized programs (i.e.
"black") was displayed with a letter and number code in an "egg crate"
at the bottom of your badge. It was easy to determine if someone had
access to a program by looking at your badge and theirs--same numbers
and in a cleared location, OK to discuss if they reasonably had "need
to know".
NASA uses lists of people briefed onto programs (i.e. having the need
to know for that program), rather than putting it on the badge. We
used to use badge coding, with a little YF-12 planform indicating
access to Senior Crown, for example. We stopped doing that when we
stopped coding clearance levels. I think we were told to stop.
People who are cleared into compartmentalized systems should be known
to each other. Everybody else should be escorted, or challenged.
There are some places where the badges can only be worn within the
compartment and are never seen by anybody on the outside.
Seriously, there's nothing magic about security clearances. The
security issue is not who has one, but what is accessible after the
fact. There is little to be gained in status by possession of a
clearance and nothing to be added by ascribing some sort of "bad juju"
to the system.
Exactly, although possession of an active security clearance right now
can significantly add to your job prospects.
John Hairell )
  #49
Old December 26th 03, 06:13 PM
Paul J. Adam
writes
news
wish.
Trouble is, the UK's firearm law is the shape it is because of two mass
homicides by permit-holding gun owners, without regard to the many
law-abiding folk like me who just liked blowing holes in paper with
like-minded people. Doesn't make it right, but that's democracy for you.
building)
I'm not particularly pro- or anti- armed pilots. There are significant
administrative issues (how do you secure the weapons between flights?
What happens when you fly to a country that doesn't recognise personal
carry?) but answers could be found: my main concern is that other more
effective measures for protecting the pilots and their aircraft get
ignored as too difficult or expensive, because "the pilots can be armed
so now there's no problem".
I don't see it as a hugely effective measure - you can't shoot well over
your shoulder while strapped into a seat - but I'm more worried about
airline pilots being drunk than armed
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
  #50
Old December 26th 03, 07:33 PM
John R Weiss
"Paul J. Adam" wrote...
There have been several proposals addressed to the TSA, but they seem to have
adopted the WORST one of all (probably in their apparent continuing effort to
minimize the number of pilots who will be armed). They have adopted a method
PROHIBITED for Air Marshals and other Law Enforcement Officers (e.g., prisoner
escorts) aboard airplanes!
Those other measures, "more effective" or not, will continue to be "too
difficult or expensive" regardless of other measures adopted. The miniscule
number of armed pilots PLUS Air Marshals CANNOT make up for ANY other measures!
However, when the lives of several hundred passengers are at stake, "defense in
depth" is a reasonable measure.
That's why specific training has been developed... Besides, the range is VERY
short, so long-range accuracy is NOT a factor in that case.
Bush Pilots Fly-In. South Africa. Bush Air Home Built 0 May 25th 04 06:18 AM
Joint German-Israeli airforce excersie (Israeli airforce beats German pilots) Quant Military Aviation 8 September 25th 03 05:41 PM
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future Jack White Military Aviation 71 September 21st 03 02:58 PM
