Licensing new Experimental glider in USA
Old January 1st 09, 11:31 PM posted to rec.aviation.soaring
John Bojack[_2_]
Default Licensing new Experimental glider in USA
What sub-category of "Experimental" is adviseable to place a U.S. sailplane
used for racing in? The two big choices were "Racing" and "Exhibition".
I'm hoping for the least hassle....ie. program letters and all that.
Thanks,
J4
Old January 2nd 09, 01:17 AM posted to rec.aviation.soaring
Frank Whiteley
used for racing in? * *The two big choices were "Racing" and "Exhibition".
Thanks,
J4
I suggest downloading a copy of FAA Order 8130.2F with Chg3.
http://tinyurl.com/86zgo8
Read Chapter 4, Section 1, Section 6, and Section 8. Applicability:
Group I and ALL (see page 119). Other sections may apply, certain
placards required. Search the term 'program letter'. Good document
to understand if you race/fly experimental gliders in the US.
Racing, definitely.
Frank Whiteley
Old January 2nd 09, 02:50 AM posted to rec.aviation.soaring
Bob Kuykendall
a U.S. sailplane used for racing in?
Amateur-built.
Old January 2nd 09, 05:08 AM posted to rec.aviation.soaring
BT
"Bob Kuykendall" wrote in message
Amateur-built.
If it is an European import.. it most likely will have a US Type Certificate
Data Sheet that will specify which US airworthy certification it is
qualified for. Some are "standard" some are "experimental - Racing and
Exhibition"
Follow the guidance that Frank Whiteley provided.
Old January 2nd 09, 05:15 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
At 02:50 02 January 2009, Bob Kuykendall wrote:
Amateur-built.
Not for his new LS-10, Bob.
You will end up in Exhibition and Racing, with the requirement for a
yearly Program Letter. The best part is that when you take in the letter,
they will likely look at you and say "What is that for?" Make two
copies. One must be kept in the plane, and one sent to the FAA. So much
for the Paperwork Reduction Act!
Steve Leonard
Old January 2nd 09, 01:54 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
"Steve Leonard" wrote in message
Amateur-built.
Steve Leonard
Same story here for my first DG800B. I took the letter in (I had to go there
anyway to renew CFI, or I would have faxed it), and the FAA said "What am I
supposed to do with this?". That glider was already certificated in Calif. I
bought it and moved it to Georgia.
However--for a new glider--the program will have to be approved by the FAA
before the AW cert is approved, and that approval letter and Operating
Limitations also must be in the glider.
So read carefully the link Frank supplied especially the section on foreign
built "Racing and Exhibition" Glider category.
Good luck!
Hartley Falbaum
Hypothetical ?? About Licensing Kyle Boatright Piloting 5 March 14th 07 12:59 PM
Gyro's and Licensing TM Rotorcraft 0 December 31st 06 01:56 AM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
licensing for homebuilts Tater Schuld Home Built 24 February 27th 06 11:55 AM
BGA and licensing Mark James Boyd Soaring 6 August 24th 04 03:16 AM
