Another way to enjoy wave
Old January 2nd 09, 06:46 PM posted to rec.aviation.soaring
kd6veb
Default Another way to enjoy wave
Hi Gang
Yesterday I was to cross the Sierras and fly to the Bay Area in my
Jabiru J250 light sport aircraft (LSA). Cap clouds were beginning to
build up over the peaks in anticipation of a storm and this would be
the only chance for this flight for a couple of days. Looking west
across the Central Valley of California from the crest of the Sierras
there was a low ugly brown opaque fog layer for 70 miles obliterating
views of the ground. An engine out would probably have been a
disaster. So I did the only prudent thing and that was a 180 degree
turn back to Minden. Now the clouds were beginning to look
interesting. Cap clouds and small lennies over the Sierra, then a blue
gap on the lee side of the mountains and finally roll clouds with high
lennies above - indicative of good wave.So with nothing better to do I
went for it.
At 12k msl at the windward edge of the roll clouds I cut power to
just above idle, dropped the IAS to between 60 and 65 knots for
minimum sink with about 7 degrees of flaps and there I was a near
equivalent to a glider. In about 20 minutes I was at 17.9k msl. Lift
was still about 300 feet per minute with the engine a little above
idle. The engine was still running smoothly even though it has a Bing
carb with no mixture control. My feet were toasty warm because of the
heater and I was comfortable, in fact more so than in the SparrowHawk
where I would be cold which makes me want to pee often. This was
luxury!
So will I do this again? You bet! I will add another EDS oxygen
system so I can take a passenger. Also I intend, when the wave window
is open, to explore altitudes above 18k up to say 25k. Sometimes it
pays to just think outside the box and do new things!
Dave
Old January 2nd 09, 07:29 PM posted to rec.aviation.soaring
Eric Greenwell
luxury!
The wave window is also a "box", so I hope you will think outside of
that one, too, and try some cross-country wave flights. I don't know how
practical that is in the J250, but you could go downwind a long ways,
and motor back the next day when the wind has died down - no lengthy
retrieve.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old January 2nd 09, 10:40 PM posted to rec.aviation.soaring
Brad[_2_]
On Jan 2, 10:46*am, kd6veb wrote:
Hi Gang
* *Yesterday I was to cross the Sierras and fly to the Bay Area in my
went for it.
* At 12k msl at the windward edge of the roll clouds I cut power to
luxury!
* So will I do this again? You bet! I will add another EDS oxygen
Dave
My Friend Ron soared Glacier Peak in Washington State a few years ago
in his Piper Colt. He did basically the same thing you did. They flew
to the LE of the lennie, chopped power and gained several thousand
feet at idle.
Then last year got a chance to soar the mountain again with several
other pilots in their sailplanes.
Brad
Old January 2nd 09, 10:48 PM posted to rec.aviation.soaring
Brad[_2_]
Hi Gang
went for it.
luxury!
Dave
feet at idle.
Brad- Hide quoted text -
- Show quoted text -
oh, and I alomost forgot this:
A buddy of mine rebuilds Pilatus turbine Porters. Several years ago we
took off in his latest rebuild project and headed across the Skykomish
Valley to Haystack Mountain, where a big Q had been building all day.
As soon as we got there he handed me the controls, pulled the engine
to idle and as soon as I centered in the thermal he turned the engine
off!
We gained about 700' before he took over, started the engine, and
demonstrated the engine ON capabilities of this airplane.
Remarkable.
Brad
If you enjoy UseNet you might read this... Ronnie Baker Aviation Photos 5 June 28th 08 09:40 PM
A story most pilots will understand, and enjoy [email protected] Piloting 8 June 30th 07 07:56 PM
A few thoughts I think most will enjoy. Chris W Piloting 2 December 4th 06 06:04 PM
Enjoy your achievements as well as your plans. Martin Piloting 1 February 10th 04 12:35 AM
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 11:33 AM
