#91
Viperdoc writes:
An airplane will keep flying without a PFD, all of which require backup. An airplane without any instruments will fly perfectly well. It's the pilot who becomes the problem when instruments fail. In your limited opinion it is iffy technology, but it doesn't matter anyway, since you'll never use it other than in a game. True, that's one of the advantages of simulation. I'm not betting my life on inadequately tested software. Because the premise of your question was incorrect, and you are a non sequitor. Then why do you suggest that others answer the question? This seems inconsistent. |
#92
"Mxsmanic" wrote in message
... That's because I'm not a troll. And you've never had a blog either. Both are false statements. |
#93
Michael Ash writes:
If your fancy glass cockpit fails you either go back to looking out the window or you revert to steam-gauge instrements. In either case, the failure is at worst an annoyance. A lot of pilots are forgetting how to revert to anything. If the glass fails, they die. If your engine fails in the wrong circumstances then you die. See above. |
#94
... A lot of pilots are forgetting how to revert to anything. If the glass fails, they die. Nope. Never happens. |
#95
Michael Ash writes:
Not all of it is done by the computer. The pilots still have to know how the stuff works and how to run it. It is largely to the point where they can push the lever and get the power, but not 100%. If you believe otherwise, just look at the circumstances surrounding the recent 777 crash at Heathrow. The computers didn't save those pilots from a dual flameout on short final. So what was the cause? Has a final report come out? I really have to wonder if you realize just how unbelievably insulting that statement is. To whom? Your obsession with people's "purpose" is bizarre and nonsensical. Purpose is what motivates behavior. It's hard to overemphasize its importance. Anything you do while piloting an airplane is "flying", whether it's cruisng steadily or endlessly fiddling with the engine levers. So going to the toilet or galley qualifies as flying? In that case, I have flown airplanes. So, I ask you: what does one have to do in order for "flying" to be their purpose? And why should anyone care? Why do you ask the question if you don't know why anyone should care? |
#96
#97
Viperdoc writes:
How would you know- have you ever flown one? The miracle of photography, which eliminates the need to see everything in the world in person. |
#98
In rec.aviation.piloting Mxsmanic wrote:
writes: The increased reliability of car engines comes from materials and new technologies, such as better valves and seats, better spark plugs, and electronic ignition. Yes, engineering. To some degree, but not mechanical engineering which is what you stated and snipped. -- Jim Pennino Remove .spam.sux to reply. |
#99
John Smith writes: ... and electronic control. Electronic parts are usually much more reliable than mechanical parts. But when they are combined with software, the opposite may prove to be true. And it may not, which makes your post pointless. -- Jim Pennino Remove .spam.sux to reply. |
#100
Viperdoc writes: An airplane will keep flying without a PFD, all of which require backup. An airplane without any instruments will fly perfectly well. It's the pilot who becomes the problem when instruments fail. A ridiculous, childish line of reasoning. -- Jim Pennino Remove .spam.sux to reply. |
Full Stalls Power Off | w3n-a | Soaring | 5 | December 4th 08 10:29 PM |
Full Stalls Power On | w3n-a | Piloting | 0 | December 4th 08 02:30 PM |
Can hydraulic lifters cause inadequate full power? | [email protected] | Owning | 13 | October 23rd 08 07:40 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
4--O-470 pistons,used | jerry Wass | Aviation Marketplace | 0 | August 17th 04 05:07 PM |
