IGC log file tabulator
Old January 4th 09, 03:02 AM posted to rec.aviation.soaring
Tuno
Default IGC log file tabulator
PC console program to create tab-delimited files for importing into a
spreadsheet-based logbook.
http://www.justsoar.com/public/igc2tablog/
(Yes -- free!)
2NO
Old January 4th 09, 02:17 PM posted to rec.aviation.soaring
Gary Emerson
(Yes -- free!)
2NO
Cool! Thanks for doing that! Works great.
Old January 4th 09, 03:34 PM posted to rec.aviation.soaring
Gary Emerson
(Yes -- free!)
2NO
If you name the output file with an .xls extension you can open it
directly with excel.
Old January 4th 09, 05:07 PM posted to rec.aviation.soaring
Tuno
An early bug report with an easy workaround: the hyperlinks in the
output have a semicolon between the arguments, which works for
OpenOffice Calc. If you import into Excel, you'll need to search and
replace the semicolons with commas first. (The hyperlinks exist to
open individual log files in SeeYou, or whatever software you use that
opens .IGC files.)
Thanks to Mark Hawkins for the bug report.
2NO
Old January 4th 09, 07:08 PM posted to rec.aviation.soaring
ablackburn6@comcast.net
opens .IGC files.)
2NO
Pretty neat Ted. I had to brush up on my command line skills.
I can't get the hyperlinks to work. I get a "Can't Open the Specified
File" error. I suspect it has to do with the path name. Now all I need
to do is create a linked import sheet that draws from your format into
mine.
9B
Old January 4th 09, 09:02 PM posted to rec.aviation.soaring
Tuno
Andy - the hyperlinks will only work if you have an application
installed (like SeeYou) that is associated with .IGC files. If you
have SeeYou installed, check your system settings to make sure the
file type association is in place.
2NO
Old January 4th 09, 11:44 PM posted to rec.aviation.soaring
2NO
Yup - I have SeeYou and the correct association to .igc. In fact the
hyperlinks I set up manually using Excel pull-down menus work fine.
(sound of head scratching)
9B
Old January 6th 09, 02:37 AM posted to rec.aviation.soaring
Tom[_6_]
2NO - Thanks for this tool. Helped me fill out my log book. Also, looking
at the output I noticed that throughout the year the GID in my 302 changes,
so I need to find which program (SeeYou Mobil, ConnectMe, or the Cambridge
CE tool) is setting it incorrectly.
I too have the HYPERLINK problem and I'm using OpenOffice Calc. My file
associations are okay since SeeYou is launched if I double-click an IGC in
Explorer. The error message from Calc says, file:///845C46G3.IGC The
specified path does not exist.
I have the Calc file in the same folder as the IGCs.
Tom
OD2
Old January 6th 09, 02:31 PM posted to rec.aviation.soaring
MarkHawke7
Tom,
You can do a couple of things to get the link to be correct.
1) Do a search and replace of "///" with "///path to IGC files
or
2) Specify the full path to the igc files on the command line.
The problem with #2 is that, as his readme file says, he's still
working out how to allow for directory names with spaces in them such
as "Documents and Settings". So unless you have your files in
something like "C:\IGCFiles" it won't put the proper directory name in
the Hyperlink. The good news is that #1 is pretty easy to do.
Later!
-Mark
On Jan 5, 7:37*pm, "Tom" wrote:
I too have the HYPERLINK problem and I'm using OpenOffice Calc. *My file
Explorer. *The error message from Calc says, file:///845C46G3.IGC *The
Tom
OD2
Old January 6th 09, 03:14 PM posted to rec.aviation.soaring
Tom[_6_]
Got it! Thanks Mark.
"MarkHawke7" wrote in message
Tom,
or
Later!
-Mark
Tom
OD2
Here is another "ID this Craft" poser (4 pics - Read the 00 file first) - File 1 of 4 - Query_a.jpg (0/1) Mean ol' Lee Aviation Photos 2 November 1st 08 09:49 PM
There is NO malware in this zip file - On Topic post of a different type - File 1 of 1 - AmericasSpirit.zip (0/2) Lee[_2_] Aviation Photos 9 October 31st 08 07:51 PM
There is NO malware in this zip file - On Topic post of a differenttype - File 1 of 1 - AmericasSpirit.zip (1/2) Gary R. Schmidt Aviation Photos 3 October 23rd 08 04:49 AM
Filling a Request for Doug in Brisbane (The Old Bloke) Read the 00 file first - File 1 of 8 - NASA photos of ISS from STS-124 080611 s124e010013_0.jpg (0/2) Lee[_2_] Aviation Photos 6 August 26th 08 06:32 AM
Filling a Request for Doug in Brisbane (The Old Bloke) Read the 00 file first - File 3 of 8 - NASA photos of ISS from STS-124 080611 s124e009982.jpg (3/3) Lee[_2_] Aviation Photos 0 August 19th 08 11:47 PM
