http://www.cablestogo.com/product.as...=710&sku=03188
Would these cable work on aviation NAV/COM/antenna? Thanks in advance. Robin Hou |
Dear Robin, Yeah, it would probably work for you, signal-wise. But I don't know what you need with regard to weather and UV exposure -- some cables are better than others and the only person qualified to say, is you. But I can tell you that the outfit you've cited is kinda on the expensive side. If you'll check the address below I think you'll find their prices are a bit more reasonable. http://www.allelectronics.com/make-a...G58/U/-/1.html Also, once you make your connection with a BNC connector, it's kind of hard to add safety wire. So instead of wire (which can sometimes puncture the braid and lead to problems) the usual procedure is to use one of the sticky-tapes, which is also carried by All Electronics. The trick is to over-lap your wrappings, starting well beyond the metal fitting... give it an inch or so... then squeeze the tape down good & tight. You'll end up with a water-proof junction that also resists coming loose. -R.S.Hoover -KA6HZF |
On Mon, 12 Jan 2009 22:08:28 -0800 (PST), "
wrote: Dear Robin, Yeah, it would probably work for you, signal-wise. But I don't know what you need with regard to weather and UV exposure -- some cables are better than others and the only person qualified to say, is you. But I can tell you that the outfit you've cited is kinda on the expensive side. If you'll check the address below I think you'll find their prices are a bit more reasonable. http://www.allelectronics.com/make-a...G58/U/-/1.html Good quality RG-58 can be found for about 21 cents per foot (discount), BUT be careful about what kind you get particularly if its going to flex or be subject to vibration. Straight RG58 has a solid, tiny, center conductor while the AU and some others have stranded. Good BNC connectors are at least several dollars each. That makes me wonder about the quality of the above. Another alternative is one of the RG8X versions which is the same physical size as RG-6, but 52 ohms, is very flexible and runs about 32 cents per foot. It also has less loss than RG58. My choice is the RG8XIIA which has a foil plus braid shield at http://www.therfc.com/coax.htm BTW, regular RG8 cables are nearly a half inch in diameter while the X versions are much smaller. Most of the cable suppliers will have the specs as to whether the cable is UV resistant or not. Also, once you make your connection with a BNC connector, it's kind of hard to add safety wire. So instead of wire (which can sometimes puncture the braid and lead to problems) the usual procedure is to use one of the sticky-tapes, which is also carried by All Electronics. I use "flooded" heat shrink tubing. It has a layer of hot melt glue on the inside and when slid up over the connector as far as possible without interfering with the operation of the connector makes a good solid connection that is far stronger than tape. OTOH the stuff is only available in 1 meter lengths. It's easily cut, but runs about $10 a length. Although it can be removed with care, I consider all connections permanent and if I have to remove one I throw it away. http://www.rogerhalstead.com/ham_files/connectors.htm shows the installation on larger cable and connectors. The smaller size tubing 0400 starts out at 0.40" an shrinks to 0.12" minimum. This is a rather heavy, industrial grade tube so some might want something lighter. The trick is to over-lap your wrappings, starting well beyond the metal fitting... give it an inch or so... then squeeze the tape down good & tight. You'll end up with a water-proof junction that also resists coming loose. -R.S.Hoover -KA6HZF Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
| Need A Cable | Newps | Owning | 4 | May 2nd 06 04:05 AM |
| Connection cable for an IFR GPS | Doug | Owning | 8 | November 29th 04 02:56 AM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 09:51 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 06:11 PM |
| best Winch cable? | yo | Soaring | 2 | April 2nd 04 04:47 PM |
