Is anyone working on or studying using WAAS GPS data to make a stand-
alone vario? How would TE be implemented in such a device? Ground speed change during a pullup? TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 |
On Jan 13, 8:23*am, "kirk.stant" wrote:
Is anyone working on or studying using WAAS GPS data to make a stand- alone vario? *How would TE be implemented in such a device? Ground speed change during a pullup? *TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. *I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 Yes but how does it tell the difference between an increase in wind and a pull up? How will it handle STF calculations in a strong headwind/wave where it may be really confused what is going on? Darryl |
On Jan 13, 8:36*am, Darryl Ramm wrote:
On Jan 13, 8:23*am, "kirk.stant" wrote: Is anyone working on or studying using WAAS GPS data to make a stand- alone vario? *How would TE be implemented in such a device? Ground speed change during a pullup? *TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. *I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 Yes but how does it tell the difference between an increase in wind and a pull up? How will it handle STF calculations in a strong headwind/wave where it may be really confused what is going on? Darryl Darryl's right (again). I don't think there's really a satisfactory way to take wind out of the equation. You could try to do it with track and drift trends, but that's not very precise given how much the wind can vary with altitude, position and over time. 9B |
Hi,
Interesting thought. To answer your 2nd question below, I have flow with SeeYou Mobile with a WAAS GPS only (CF GPS) and I found the thermal assistant to be pretty much useless. However, it worked great when connected to a 302. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "kirk.stant" wrote in message ... Is anyone working on or studying using WAAS GPS data to make a stand- alone vario? How would TE be implemented in such a device? Ground speed change during a pullup? TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 |
On Jan 13, 11:03*am, wrote:
On Jan 13, 8:36*am, Darryl Ramm wrote: On Jan 13, 8:23*am, "kirk.stant" wrote: Is anyone working on or studying using WAAS GPS data to make a stand- alone vario? *How would TE be implemented in such a device? Ground speed change during a pullup? *TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. *I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 Yes but how does it tell the difference between an increase in wind and a pull up? How will it handle STF calculations in a strong headwind/wave where it may be really confused what is going on? Darryl Darryl's right (again). I don't think there's really a satisfactory way to take wind out of the equation. You could try to do it with track and drift trends, but that's not very precise given how much the wind can vary with altitude, position and over time. 9B- Hide quoted text - - Show quoted text - Cmon, let's think out of the box! An INS/IMU can measure winds without air data. How accurate (read "expensive") would an inertial sensor need to be to provide useful wind data (or just TAS vs GS)? Or bite the bullet and T into the pitot/static system and provide the data to the GPS vario - no worse than a TE connection for a conventional vario. Question is whether it would be cheaper and/or better than current mechanical or electronic TE varios? Better or worse at altitude, faster/slower response, etc? I'm thinking: One little box with an LCD display. TE vario, audio, horizontal lift distribution in the current thermal in real time (for centering), current average, past averages/acheived climbs (trend for MC settings), logger, GPS output for other devices. Run off ship power and have a backup rechargeable battery. Stick in a 68mm hole, hook up pitot/static and power, off you go. Replaces your backup mechanical or electric, gives you a real backup when your TE probe falls off! Do it for less than $500 (yeah, right, I know...) and you stick it in every glider out there (think of all the crap instruments in club/commercial gliders in the US). And please don't say "Cambridge 302" - TE probes are soooo 20th century! Kirk 66 |
Kirk - it's about time you came back home to Arizona. We don't need
no stinking varios here! Mike |
On Jan 13, 10:05*am, "kirk.stant" wrote:
On Jan 13, 11:03*am, wrote: On Jan 13, 8:36*am, Darryl Ramm wrote: On Jan 13, 8:23*am, "kirk.stant" wrote: Is anyone working on or studying using WAAS GPS data to make a stand- alone vario? *How would TE be implemented in such a device? Ground speed change during a pullup? *TAS based on circling winds? Do the current PDA software programs (mSeeYou, Winpilot, etc.) when used in GPS-only mode provide accurate vario data when hooked up to a WAAS GPS? Just curious - seems a 5 hz WAAS GPS could be the basis for a really nice vario that wouldn't need any pitot-static imputs. *I use mSeeYou and a Themi, non-WAAS, and the "vario" data seems close, but I use it more for trend and average than instantaneous data. Winter can't end soon enough! Kirk 66 Yes but how does it tell the difference between an increase in wind and a pull up? How will it handle STF calculations in a strong headwind/wave where it may be really confused what is going on? Darryl Darryl's right (again). I don't think there's really a satisfactory way to take wind out of the equation. You could try to do it with track and drift trends, but that's not very precise given how much the wind can vary with altitude, position and over time. 9B- Hide quoted text - - Show quoted text - Cmon, let's think out of the box! An INS/IMU can measure winds without air data. *How accurate (read "expensive") would an inertial sensor need to be to provide useful wind data (or just TAS vs GS)? Or bite the bullet and T into the pitot/static system and provide the data to the GPS vario - no worse than a TE connection for a conventional vario. Question is whether it would be cheaper and/or better than current mechanical or electronic TE varios? *Better or worse at altitude, faster/slower response, etc? I'm thinking: *One little box with an LCD display. *TE vario, audio, horizontal lift distribution in the current thermal in real time (for centering), current average, past averages/acheived climbs (trend for MC settings), logger, GPS output for other devices. *Run off ship power and have a backup rechargeable battery. Stick in a 68mm hole, hook up pitot/static and power, off you go. Replaces your backup mechanical or electric, gives you a real backup when your TE probe falls off! *Do it for less than $500 (yeah, right, I know...) and you stick it in every glider out there (think of all the crap instruments in club/commercial gliders in the US). And please don't say "Cambridge 302" - TE probes are soooo 20th century! Kirk 66 I am not aware of any IMS/IMU that attempt to calculate wind without air data input. Do you know of one? It is likely a significant challenge for rate based systems (vs. position based with GPS). e.g. "taking a turn" cannot help determine wind with an INS. All the poor thing can try to do is integrate external accelerations on the aircraft caused by changes in wind. While trying to integrate up rate based sensors to determine wind is likely impractical. Using rate based sensors to filter other rate base inputs likely makes more sense. I believe accelerometer based assistance is already used to help improve/filter gusts and other effects on variometers (wether using TE probe or digitally adjusted TAS +pitot). I believe the Cambridge 302 uses it's accelerometers for this, but also have heard rumors that this was never really fully developed in the software. I am not sure if other vario/computer systems also do this. I certainly like how the vario in the 302 performs (and I'm using electronic TE compensation with mine). Paul gives on example of the SeeYou Mobile thermal assistant not working well with just GPS+WAAS input. In the past other people have tried to use STF data through PDA software. Finally Naviter had to warn pilots this can't possibly work, they just don't have enough data to calculate something useful. Even if all the above were not show-stopping issues you'd have to look at the noise spectrum of the altitude signal around a fraction to 1 Hz to see how bad differentiating (for vertical velocity) and filtering this is going to be. I just don't have that data handy. And you may need a sophisticated antenna system to provide a good GPS satellite sky view when turning tightly. A TE probe, which is just a couple of holes or a slot cut in a few dollars worth of tube seems a lot easier way to get basic data. As Dick Johnson kept reminding us, you don't need a fancy tail mount TE probe a simple home made fuselage mounted one works great. An electronic pressure sensor to incorporate into a vario costs a few dollars. The software to make all this work really well. Priceless. I can't wait to see what Dave Ellis does at ClearNav... Darryl |
On Jan 13, 12:38*pm, Darryl Ramm wrote:
I believe the Cambridge 302 uses it's accelerometers for this, but also have heard rumors that this was never really fully developed in the software. More than a rumor I think. My recollection is that it was experimented with but never implemented in any way. You can read the accerolemeter values on one of the data pages though. Andy |
On Jan 13, 12:25*pm, Andy wrote:
On Jan 13, 12:38*pm, Darryl Ramm wrote: I believe the Cambridge 302 uses it's accelerometers for this, but also have heard rumors that this was never really fully developed in the software. More than a rumor I think. *My recollection is that it was experimented with but never implemented in any way. *You can read the accerolemeter values on one of the data pages though. Andy It would be interesting to know what they did and if there is anything used for gust filtering etc. The accelerometer (or one axis of it) is used for the slow flight warning, as can be demonstrated by playing around with the glider near the low-speed threshold. Darryl |
Darryl,
INS would be like a GPS that had accurate heading info - would still need TAS to solve the wind triangle, just like on an E6B. I didn't think it all the way through, obviously! The trouble with TE probes is that they are fragile have several failure points. So it's nice to have a backup system (electronic TE on a 302, for example). My experience with a non WAAS Themi, which also drives my mSeeYou, is that the "vario" data, once established in a thermal, is pretty good - since I'm looking for differences around the circle, not absolute climb values. And having the GPS show where in the thermal the stronger lift was located is useful. But it is not a replacement for a good TE vario. I'm just curious if the increased accuracy of WAAS can be merged into an instrument that will present a clearer 3-D picture of a thermal. The best current vario only tells you how well you were climbing a few seconds ago, but not where. PDA software is pretty good at showing historical flight path, but I think there is room for improvement on how to display a thermal in 3D that is useful for a pilot trying to dig out of a hole or max out a boomer. I'm going to have to run some simultaneous traces from a conventional logger (pressure altitude) and my PDA logger (GPS altitude) and compare the thermal data in SeeYou. Fun to what-if...! Kirk |
| WAAS info | Paul kgyy | Owning | 6 | February 18th 07 04:37 PM |
| WAAS for GNS 430/530? | Dane Spearing | Instrument Flight Rules | 58 | June 14th 05 03:22 AM |
| IGC APproval for GPS with WAAS | Ivan Kahn | Soaring | 11 | November 27th 03 12:00 AM |
| GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 01:39 AM |
| WAAS | Big John | Piloting | 8 | July 22nd 03 02:06 PM |
