Want to build a REAL engine?
Old January 17th 09, 04:14 PM posted to rec.aviation.homebuilt
bildan
Default Want to build a REAL engine?
I've been kicking this idea around with some mechanical engineers for
a couple of years.
Motorcycle in-line fours are state of the art high performance engines
unencumbered by smog controls. They get more than 100HP per liter
with some at 140 HP/liter. Of course, they rev like a dentist's
drill.
More importantly, the cylinder/head assembly just bolts to the
crankcase. Now, think of 7 or 9 of these in-line water cooled 4-cyl
blocks arranged radially around a common crankcase.
To make it work, you have to make the case, crank and new master/
articulating connecting rods. You'd also need a gear case to drive
the cam chains. Finally, you'd need some serious gear reduction
(~7:1) planetary gear set in the nose case. I'd also use an aircraft-
type fuel injection system instead of carbs.
If it worked, in the case of 9 cylinder blocks, you'd have a 36
cylinder, 500 pound, 30" diameter, 1000HP+ liquid cooled radial
reminiscent of a half scale Lycoming XR7755.
Now build a slick little carbon composite airplane around the monster
and take it to Reno. I'll bet the sound alone would wow the crowds.
Old January 17th 09, 05:05 PM posted to rec.aviation.homebuilt
John Kimmel[_2_]
a couple of years.
drill.
Already been done.
http://www.bigbikeriders.com/48cyl.htm
John Kimmel
I think it will be quiet around here now. So long.
Old January 17th 09, 06:06 PM posted to rec.aviation.homebuilt
bildan
On Jan 17, 10:05*am, John Kimmel wrote:
a couple of years.
unencumbered by smog controls. *They get more than 100HP per liter
with some at 140 HP/liter. *Of course, they rev like a dentist's
drill.
crankcase. *Now, think of 7 or 9 of these in-line water cooled 4-cyl
articulating connecting rods. *You'd also need a gear case to drive
the cam chains. *Finally, you'd need some serious gear reduction
(~7:1) *planetary gear set in the nose case. *I'd also use an aircraft-
and take it to Reno. *I'll bet the sound alone would wow the crowds.
Already been done.http://www.bigbikeriders.com/48cyl.htm
John Kimmel
I think it will be quiet around here now. *So long.
Actually, I think I made a mistake on the 30" diameter. I got that by
measuring the distance from the crank center to the top of the valve
covers of a Kawasaki. That's fine for a 4-cylinder but a radial is a
different matter.
To make room for 9 blocks and the intake/exhaust manifolds that go
between them, the engine diameter would have to be larger. Maybe 42"
- 48" diameter would work.
Old January 17th 09, 06:28 PM posted to rec.aviation.homebuilt
Dan[_12_]
John Kimmel wrote:
a couple of years.
drill.
Already been done.
I bet that is great at straight lines, but how big is the turn radius?
Dan, U.S. Air Force, retired
Old January 17th 09, 09:22 PM posted to rec.aviation.homebuilt
bod43
a couple of years.
drill.
Here is a proper V8 made using 2 x suzuki hyabusa engine
blocks and heads. It is properly engineered and
gives twice the power of the original - say 350hp.
If memory serves me correctly the power is taken off of a gear at
the centre of the crank on the original and the V8 is likely the same.
http://flickr.com/photos/10983301@N06/3068124763/
If you want more maybe a turbine should be considered
http://www.pistonheads.com/roadtests/RadicalSR8.htm
some description here with weight and power.
Says £20,000 ready to run.
Was built for car racing.
There have been a number of similar projects I understand.
google [radical v8]
Old January 17th 09, 09:37 PM posted to rec.aviation.homebuilt
bod43
a couple of years.
drill.
Looks like the centre drive take off comment was rubbish - probably
Here is another one.
http://www.h1v8.com/albums/album_ima...06/1363744.htm
The web site is quite informative.
Old January 18th 09, 12:30 AM posted to rec.aviation.homebuilt
Stuart Fields
"John Kimmel" wrote in message
a couple of years.
drill.
Already been done.
John Kimmel
The big bike reminds me of the task of putting windshield wipers on a
duck's ass. It represents a technical challenge, but the outcome is of
questionable value. Too much spare time?
Old January 18th 09, 01:28 AM posted to rec.aviation.homebuilt
bildan
a couple of years.
drill.
Already been done.
John Kimmel
* * The big bike reminds me of the task of putting windshield wipers on a
duck's ass. *It represents a technical challenge, but the outcome is of
questionable value. *Too much spare time?
OK, the bike's prove you can take motorcycle 4 cyl blocks and create a
monsterously powerful multi-bank engine with them. The Hyabusa V8 is
particularly neat. The 48 clinder seems to be 2- stroke cylinders
which is weird.
For aviation, a big, round, mean, screaming, 1000HP radial would take
the show.
Old January 18th 09, 02:34 AM posted to rec.aviation.homebuilt
Alan Baker
In article
a couple of years.
drill.
Take a look at this:
http://www.hartleyenterprises.citymax.com/page/page/1562069.htm
400hp from an engine weighing just 200lb.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old January 18th 09, 10:06 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 17 Jan 2009 10:06:29 -0800 (PST), bildan
a couple of years.
drill.
John Kimmel
different matter.
try these....
http://www.mile16.com/Radial.html
Soooo, what is the best plane to build around a corvair engine? Lou Home Built 21 November 11th 06 12:56 AM
Real Time to build an RV10 [email protected] Home Built 13 October 31st 05 02:20 AM
My 9th Wedding Anniversary Trip, To Newport, OR Carb Ice & Real Engine Out "Long" NW_PILOT Piloting 32 June 28th 04 11:45 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
