Want to build a REAL engine?
Old January 18th 09, 05:54 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
Default Want to build a REAL engine?
"bildan" wrote in message
OK, the bike's prove you can take motorcycle 4 cyl blocks and create a
monsterously powerful multi-bank engine with them. The Hyabusa V8 is
particularly neat. The 48 clinder seems to be 2- stroke cylinders
which is weird.
For aviation, a big, round, mean, screaming, 1000HP radial would take
the show.
But it doesn't tell you if these hybrids are reliable.
There are a lot more issues with building a custom engine than just making
all the pieces fit together. None of these examples have been tested for
long periods of time at 75% power, and if they won't withstand such, they
serve little purpose other than exhibition.
Old January 18th 09, 08:37 PM posted to rec.aviation.homebuilt
bildan
monsterously powerful multi-bank engine with them. *The Hyabusa V8 is
particularly neat. *The 48 clinder seems to be 2- stroke cylinders
which is weird.
the show.
It would just be for exhibition and racing. Just put it on a trailer
and show up at airshows and wow the crowds by running it.
The first flight would be in an unlimited racer. By way of
comparison, the old WW2 engines aren't all that reliable by modern
standards anyway. This thing should be just as reliable. I can't see
an engine like this anywhere other than in an exhibition and racing
aircraft.
All that said, the superbike engines are bulletproof by reputation -
they get run really hard. The top end is where most engine failures
occur and that part has been thoroughly tested - tens of thousands
have been built and sold. The crank, rods, case and accessories would
be what needs testing.
Old January 19th 09, 04:18 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sun, 18 Jan 2009 10:06:02 GMT, Stealth Pilot
http://www.bigbikeriders.com/48cyl.htm
Not quite, the engine and gear box weigh over a ton, or at least 4X of
the target weight. W&B would be a bear.
Old January 19th 09, 06:12 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
It would fit nicely in a full scale F8F.
But it'd be a bit underpowered...
Old February 16th 09, 04:35 PM posted to rec.aviation.homebuilt
Zier & van de Steenoven
On Sat, 17 Jan 2009 08:14:43 -0800 (PST), bildan
In Europe quite a lot of aircraft are flying with BMW 2 cylinder
motorcycle-engines.
Reliable, good power weight ratio
With a reduction from http://www.takeoff-ul.de/
Our plane is a Cherry BX2 homebuilt from Switserland.
regards,
Rob
Old February 16th 09, 04:42 PM posted to rec.aviation.homebuilt
On Mon, 16 Feb 2009 16:35:26 GMT, (Zier & van de
The Youtube video on our Dutch Homebuilt Site
www.nvav.nl shows this
plane!!!
Old February 16th 09, 11:08 PM posted to rec.aviation.homebuilt
Brian Whatcott
motorcycle-engines.
regards,
Rob
My, that Boxer does look pretty.
Is there an English language version of that site, I wonder?
Or, if not, how much? how heavy? how many horses?
Brian W
Old February 17th 09, 11:08 AM posted to rec.aviation.homebuilt
On Mon, 16 Feb 2009 17:08:07 -0600, Brian Whatcott
Brian W
Try this;
http://www.spang-air.de/willkommen/B...mw_engine.html
On this site you will find a lot of information about BMW engines.
The owner Wolfgang Spang has lived in the US.
He can answer in English!
regards,
Rob -- Papa Hotel Victor India November
And
http://www.takeoff-ul.de -- Produkte --
http://www.takeoff-ul.de/pdf%27s/Des...ne_02-2006.pdf
Soooo, what is the best plane to build around a corvair engine? Lou Home Built 21 November 11th 06 12:56 AM
Real Time to build an RV10 [email protected] Home Built 13 October 31st 05 02:20 AM
My 9th Wedding Anniversary Trip, To Newport, OR Carb Ice & Real Engine Out "Long" NW_PILOT Piloting 32 June 28th 04 11:45 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
