CASTING CALL!
Old January 20th 09, 03:24 AM posted to rec.aviation.homebuilt
Default CASTING CALL!
To All.
The subject of this message is also the subject of the first article
in my blog...
bobhooversblog.blogspot.com
....where you will find some ILLUSTRATIONS of what I've been doing over
the weekend.
Have you ever cast aluminum?
Me too. In fact, most home-builders have some experience in the arts
of Thor. Most of us never progress beyond flat-castings. Those who
get Serious about casting will have delved into Cored Castings. And a
very few of those are able to Speak of Lost Wax or Lost Foam and a few
other more of the trickier bits.
I'm trying to cast individual heads for the VW engine, which is pretty
much a loser in the Power Department. That's because it wasn't
designed for Power, it was designed for Durability and Low Cost and
half a dozen other things you want to see in a practical People's Car.
And then I come along and start talking People's Plane!
I'm being forced to learn two things. The first, and where I'm most
likely to fail, is in the casting itself. Particularly in making a
suitable pattern and cores to produce a cylinder head capable of
satisfying the SECOND thing, which is to come up with the design of a
cylinder-head casting capable of coupling the required amount of heat
to the atmosphere.
I've got Liston's book on the design of aircraft engines and he has
been rather kind to people like me, taking the time to explain the
factors he uses in his equations. I don't think I'll fail because of
dumb-ness. The area in which I'm most likely to fail will be in
translating those Factors and the equations in which they are used
into the wooden patterns needed to turn the abstract into reality.
The illustrations in the blog offer some idea as to how I'm
approaching the problem. Something they don't show is the fact I'll
have to go back to basics with regard to the casting, since none of my
flasks are large enough to accept a pattern as large as the one needed
for a single head. That was something of a surprise but there have
been others :-)
All in all, it has been an enjoyable weekend.
-R.S.Hoover
Old January 20th 09, 02:50 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Mon, 19 Jan 2009 19:24:00 -0800 (PST), "
yes
just bentonite based greensand because it is reusable time and time
again.
to the atmosphere.
bob I couldnt visualise the head so I went out to the bench and got
myself a stuffed oily head to turn over in the hand.
first some amazement. people have sawn these heads in half so that the
higher thermal expansion of the rear jugs didnt jack the head off
square on the cylinders. how they did it I cant fathom because the web
between the intake ports is just 5mm wide at the manifold face.
anyway...
to me the design doesnt start from the whole downward as your blog
drawings suggest. doing this will send you insane.
start at the combustion chamber roof and work outward.
take the positions of the spark plugs top and bottom as set.
(I know you want only single ignition but dual is feasible so design
the heads for dual - it's easy)
we can of course tilt the plugs over to one side a little to gain
working clearance around their bodies.
I thought the valves could also stay where they are.
I also think that the exhaust duct can stay where it is.
one thing that needs to move is the inlet duct. this needs to move
away from the centreline and the manifold bolts need to go from being
located fore and aft to above and below. they are studs so it looks
doable to me.
as I squinted at it I realised that with the studs top and bottom the
plug position didnt even need to change.
the finning around the exhaust duct needs to change. I think the vw
fins in the area between the exhaust duct and the rocker well were
accepted as less than optimal to make the well a simple tooling shape.
bugger that though because it reduces the fin area just where you
need it around the exhaust duct. there is also a lot of interrupted
finning in this area.
if you look at the head side on so that you can see through the fins
around the exhaust duct, you can see that the fat fin at the exhaust
valve is an inch high. at the exhaust manifold the fin is quarter of
an inch high because the rocker well has been cast with a flat bottom.
what needs to happen is that the base of the rocker well needs to be
curved to keep it an inch off the exhaust duct.
the exhaust duct fins are wider spaced than the rest of the fins and
this seems to me to be wrong.
I think that by making the rocker well curve to stay parallel to the
exhaust duct and making the fins slightly closer together you would
nearly double the fin area in just the right area.
the existing exhaust spring could sit into a recessed well but you
could also machine up a longer valve and keep the spring standard.
I think that it is possible to substantially improve the exhaust
finning without changing the external dimensions much at all.
you just need to change the shape of the bottom of the rocker well.
tweaking the inlet duct position to achieve individual heads seems
trivial.
Stealth Pilot
Old January 20th 09, 02:56 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
re my head suggestions in the other post....
I have to ask my edm owner to verify that this is possible.
in an ideal world I would cast everything castable and I would spark
erode the recesses to create the exhaust finning.
I'm not sure if spark eroding aloominum is possible but eroding
generally can do this sort of job with amazing precision.
Stealth Pilot
Old January 20th 09, 03:25 PM posted to rec.aviation.homebuilt
Monk
On Jan 20, 9:56*am, Stealth Pilot
Stealth Pilot
SP & Bob,
Just wanted to let you guys know that even though I may not
participate in every discussion, I do read most of them and appreciate
your contributions here.
Old January 20th 09, 05:31 PM posted to rec.aviation.homebuilt
Maybe one should acquire one of these French engine heads and see how
they
did it.
http://www.jpx.fr/Jpx/english/4tx75E.htm
Reggie
Old January 20th 09, 05:50 PM posted to rec.aviation.homebuilt
On Jan 20, 7:50*am, Stealth Pilot
SNIP
Stealth Pilot
Rather than modifying the VW head It might be of interest to look at
the Corvair and adapt it to the VW?
If you don't have a Corvair head handy the link below has some good
pics
http://people.consolidated.net/tboyett/
If you are trying to figure out where the rockers get bolted down, the
'vair used a combination head nut/rocker stud.
Leon McAtee
Old January 20th 09, 07:36 PM posted to rec.aviation.homebuilt
On Jan 20, 6:50*am, Stealth Pilot
My goal is to DOUBLE the amount of waste heat the head can handle.
Which means I need between 3x and 4x the AREA of the existing fins.
Examining a Lyncoming or Continental shows how they did it, although
there's no way I can emulate their fin 'density.'
Playing with a Corvair head shows how they did it... and did it using
a method which I CAN emulate. But I've found it impossible to
maintain the bank-to-bank symmetry that makes the VW such a treat.
If you are interested in this project I suggest you begin with a
junked late-model head. Cut it in half. Remove the rocker arm
towers. Remove the exhaust-stack studs.
Using modeling clay, move the exhaust stack to about the present
position of the existing push-rod tube hole (ie, the one farthest from
where you have just cut). You may install a boss where ever needed to
secure the Corvair-style exhaust stack. Fortunately, Volkswagen
includes a formed exhaust gasket in their muffler-gasket kit which
lends itself to using the Corvair-type of exhaust stack.
Now you can go back to extending/adding-on new fins. So far, I've
'discovered' about 96 square inches (!!) of fin area that it MAY be
possible to develop. But it is going to be one weird bit of pattern-
making. (Due to the fins, one portion of the pattern must be
withdrawn ninety degrees away from the other.) Right now I'm looking
at a FOUR-PART flask. ( Remember, I said 'looking at' -- not in love
with.) Even so, it's going to be more difficult than anything I've
ever cast before. Not just because of the casting, but because of the
machining that follows.
I've not done anything at all with the inlet.
One step at a time.
-Bob
-Bob
Old January 20th 09, 07:41 PM posted to rec.aviation.homebuilt
they
did it.
Nothing really new. CNC billets (look at the max CHT). Excellent
solution... if you're pockets are deep enough.
-R.S.Hoover
Old January 20th 09, 08:14 PM posted to rec.aviation.homebuilt
On Jan 20, 12:41*pm, " wrote:
Nothing really new. *CNC billets (look at the max CHT). *Excellent
-R.S.Hoover
Ya sure about that? I think I see signs of core shift on the heads.
Could be they are just optimistic about their temp ratings.
http://www.jpx.fr/Jpx/english/im_4tx75_1.htm
Also looks like a Franklin setup with steel sleeves. Nice idea but
too involved for this hobby machinist.
While it does have dual plugs I doubt they do anything for the
performance. Mostly there to satisfy the redundancy "requirement"
I read today that Fiat is taking a 35% share of Chrysler. Maybe the
power plants from the 500 will become available at a reasonable
price?
Leon McAtee
Old January 21st 09, 08:02 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 20 Jan 2009 11:36:31 -0800 (PST), "
the corvair head in leon's link shows me in the little marks from
casting that the head is cast into a multipart steel die.
I believe for short runs of castings these could be bolted together
with machined parts in mild steel and a silicon spray type release
agent used. Foseco make the release agent I have in mind.
I would have thought that you design one head and mirror image it for
the others. that is how the symmetry is achieved.
this is not an academic exercise for me. I will need just such an
engine for my Turbulent. The problem with the thread bases and the
woodruff key in the crankshaft causing fatigue failures is *exactly*
why I havent proceeded with just a simple vw conversion.
I'd actually like to build a sorted out trouble free engine.
sourcing one of the aero intended forged cranks and building around it
seems an option.
so you are moving the exhaust from front and rear orientation to
downward.
what type of sparkplugs would need to be used for this engine and
where would they go?
this is critical because they need access clearance for servicing.
One step at a time.
ok. our approaches differ in that the fins worry you so you are
concentrating on them. I think that they are a solvable problem.
my approach is to worry about them last because I can look to lycoming
and continental and pratt 'n whitney et al for the solution.
where do the plugs go in the combustion chamber roof and where do the
valves go?
do you keep the valves in a horizontal line and place the plugs
vertically above and below as the usual vw conversion does?
this keeps the existing underslung camshaft reasonably happy.
if you keep the valves in the existing position in the chamber roof
and redirect the inlet port to vertically above and the exhaust to
vertically below? what advantages does that give you?
note havent got to the fins yet.
what answers do your gut feel from years of experience tell us?
Stealth Pilot
Casting Four Individual VW Heads [email protected] Home Built 23 January 21st 09 11:07 PM
casting intricate finned heads Stealth Pilot[_2_] Home Built 13 January 16th 09 02:35 AM
got a call from BDR FSS Kevin Clarke Piloting 36 August 23rd 07 07:52 PM
Just call me Han...... JIM105 Rotorcraft 7 November 5th 04 12:29 AM
Who do you call? Travis Marlatte Piloting 4 August 21st 03 08:16 AM
