Gang,
	I'm leaving this Friday to pick up a glider that I purchased 1100 miles away. The trailer looks brand new, but is about 12 years old, as are its tires. The glider and trailer weigh in the vicinity of 950 #. The tire spec from the owner is : Carlisle Sure Trail ST ST205/75014 (replaces F78-14ST) Max Load 1760 lbs @ 50 PSI (actual load will be under 500 lbs) I plan to buy 2 new tires before the trip, and stop at the first service station after the pickup and have them mounted. Question is, what to buy. It does not appear that the trailer has any suspension, so I think I'd run the tires slightly soft, maybe 25-30 psi. I was wondering about whether it should be radial or bias ply? Any particular brands? Thanks in advance, Ed  |
Ed,
	My research into this question resulted in me concluding that one should look at the Duro, Maxxis, Denman (in that order) tire brands. Goodyear Marathons are variable. Carlisle are not recommended (note that Carlisle also owns Titan). I chose Duros. Whatever you choose, make SURE that it is an ST tire - this stands for Special Trailer. And DO NOT run them at low pressure - run them at whatever the pressure is that is stamped on the sidewall to get maximum load carrying ability with minimum heat build up. As for the radial/bias question, radial tires are *not* recommended when lateral sway is a problem. However, radials do run cooler, and they provide a softer ride. I chose radials for my Cobra trailer, since sway has never been an issue, and there is no suspension. As for longevity, it's recommended that you replace trailer tires every 5 years. Although they may look "new", the sun and atmosphere damage the rubber. Finally, what kind of glider did you buy? -John On Jan 20, 10:14 am, flying_monkey wrote: Gang, I'm leaving this Friday to pick up a glider that I purchased 1100 miles away. The trailer looks brand new, but is about 12 years old, as are its tires. The glider and trailer weigh in the vicinity of 950 #. The tire spec from the owner is : Carlisle Sure Trail ST ST205/75014 (replaces F78-14ST) Max Load 1760 lbs @ 50 PSI (actual load will be under 500 lbs) I plan to buy 2 new tires before the trip, and stop at the first service station after the pickup and have them mounted. Question is, what to buy. It does not appear that the trailer has any suspension, so I think I'd run the tires slightly soft, maybe 25-30 psi. I was wondering about whether it should be radial or bias ply? Any particular brands? Thanks in advance, Ed  |
Get ready for some great advice on this topic. My pennies worth are to
	never run tires below reco. pressure unless you want more traction out of a mud pit or to lower your vehicle to get it below a bridge. Low pressure will cause more sidewall flex and lead to an overheat failure. Get Trailer tires only as they will have an extra sidewall layer needed for trailer sway that will wear on car tires. I learned from Charlie Spratt that you want 10% min. of the total tow weight on the ball to help prevent excessive rear end swaying. Finally, Walmart sells mounted trailer tires, that's tires and rims together, ready to go in 13", 14", 15" size that have a C rating. $79, not bad. You can mount them at the pickpoint and be ready to haul. Next.....  |
I'd also check the axle bearings. If they haven't been repacked in the
	past couple of years, you'll want to repack them before your trip. -Kevin  |
On Jan 20, 10:43*am, "  wrote:
	---snip Finally, Walmart sells mounted trailer tires, that's tires and rims together, ready to go in 13", 14", 15" size that have a C rating. $79, not bad. You can mount them at the pickpoint and be ready to haul. Great idea, except that I have no idea what lug spacing is on there, and there are many possibilities.  |
At 15:14 20 January 2009, flying_monkey wrote:
	Gang, It does not appear that the trailer has any suspension, so I think I'd run the tires slightly soft, maybe 25-30 psi. Hard to imagine a trailer without any kind of suspension. Seems to me it would bounce like crazy over any kind of rough road, not to mention beating the glider to pieces. Jim Beckman  |
Jim Beckman wrote:
	At 15:14 20 January 2009, flying_monkey wrote: Gang, It does not appear that the trailer has any suspension, so I think I'd run the tires slightly soft, maybe 25-30 psi. Hard to imagine a trailer without any kind of suspension. Seems to me it would bounce like crazy over any kind of rough road, not to mention beating the glider to pieces. Agreed. An axle using torsion arms for sprung suspension may "look" like it has no springs, i.e. no leaf springs or coil springs, when in fact it does. Regards, -Doug  |
At 15:27 20 January 2009, jcarlyle wrote:
	Ed, My research into this question resulted in me concluding that one should look at the Duro, Maxxis, Denman (in that order) tire brands. Goodyear Marathons are variable. Carlisle are not recommended (note that Carlisle also owns Titan). I chose Duros. Whatever you choose, make SURE that it is an ST tire - this stands for Special Trailer. And DO NOT run them at low pressure - run them at whatever the pressure is that is stamped on the sidewall to get maximum load carrying ability with minimum heat build up. I would Not do this. The pressure marked on the tyre is the maximum permitted inflation pressure. This would not allow the tyre to flex and only the central part of the tyre would be in contact with the road. It would also bounce all over the place on a rough surface. Inflate to the reccomended pressure for the trailer. If not available try 35-40psi If the trailer weighs considerably less than the max tyre load heat build up will not be a problem. Nigel  |
jcarlyle wrote:
	Whatever you choose, make SURE that it is an ST tire - this stands for Special Trailer. And DO NOT run them at low pressure - run them at whatever the pressure is that is stamped on the sidewall to get maximum load carrying ability with minimum heat build up. Be aware ST tires have a 60 mph speed rating at the standard pressures. You can raise the rating to 70 mph if you inflate to required pressure for this higher speed. As for the radial/bias question, radial tires are *not* recommended when lateral sway is a problem. Cobra delivers all their trailers with radials. Go to the RV dealers and look at all travel trailers and 5th wheel trailers, and you will find out they are all riding on radials. That's because radial tires are far better tires, even for trailers. The bias ply tire's only advantage is it's a few dollars cheaper. If you compare a passenger car radial to a bias ply ST trailer tire, you might be right. However, radials do run cooler, and they provide a softer ride. And they are more road hazard resistant. I'm leaving this Friday to pick up a glider that I purchased 1100 miles away. The trailer looks brand new, but is about 12 years old, as are its tires. The glider and trailer weigh in the vicinity of 950 #. What is in it? It is worth weighing it if you are at all suspicious about the claimed weight. Assuming the 950 pounds is right... Unless you are towing this with a Volkswagen Beetle, it seems unlikely such a light trailer will cause any problems, regardless of the tires. The tire spec from the owner is : Carlisle Sure Trail ST ST205/75014 (replaces F78-14ST) Max Load 1760 lbs @ 50 PSI (actual load will be under 500 lbs) The ST inflation chart show a load rating of 850 pounds at 15 psi! This tire is serious overkill for the weight of your trailer. Even the smaller ST175/R13 has a 670 pound rating at 15 psi. If it were my trailer, I'd just put on passenger car tires with a speed rating about 20 mph higher than I planned to tow, and a 1000 or so pound load rating, then use the correct pressure for a 600-700 pound load. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org  |
| Cobra Trailer Tires (US) | RN | Soaring | 25 | July 25th 08 07:11 AM |
| glider trailer tires | Ken Ward | Soaring | 18 | October 3rd 06 05:15 AM |
| Tires... | Blueskies | Home Built | 0 | May 10th 05 01:26 AM |
| Glider trailer tires | Greg Arnold | Soaring | 7 | December 7th 04 07:42 AM |
| Replacing Cobra trailer 13 inch tires with larger? | Andy Blackburn | Soaring | 6 | August 19th 04 04:15 AM |
