On Jan 23, 3:11*pm, wrote:
You have apparently not read the rules changes submitted , and approved ths morning. The addendum does permit *COTS loggers, with some limitations, for backup in National as well as a variety of lower cost options for use in Regionals. The more rigorous requirement you allude to would only apply in a case of trying to make the US Team. The impression you leave is that the RC is not responsive to your suggestions on this topic. In fact, a great deal of time has been spent on this while trying to find a reasonable balance between cost to individuals and fairness to all. You got your way, though maybe not 100% and you're still bitching. Our guiding principles put safety first, fairness close behind, and how any change affects participation right at the top of our list. If you think we need a new charter- feel free to propose it with concrete examples of how you would propose to accomplish such a charter. Sent as an individual member of the RC. UH- Hide quoted text - - Show quoted text - UH, I'm responding quickly because of the impression I gave you guys that I'm bitching. I'm not. I did read the proposed rules a few weeks ago when they were published and quickly re-read the section on flight recorders a few minutes ago just to see if anything had changed (it had not). I agreed with most of the changes, for whatever that's worth. But I admit I was disappointed in the section on COTS flight recorders and I'm going to push back. It completes the stealth change in 2008 that essentially eliminated their routine use as a backup device at the national level. I do recognize that P3 and I have been tasked with coming up with a workable solution for regionals use, and we appreciate the opportunity. It doesn't change the fact that the 2008 rules were a step away from 2007 and 2009 is still another step. Prior to 2008, if a flight recorder met the functional requirements in the Rules, it could be used as a backup. Period. We can argue about what was intended but that's what the rules said and that's what I and some others did using a cheap off-the-shelf Garmin unit. Last year the RC changed the rules: the functional specs were kept but you created three lists/classes of flight recorders and it was problematic whether COTS were accepted as backups (I was graciously granted a waiver to fly the October Region 4 contest with mine pending the RC's meeting). This year the process is complete: there are two categories of flight recorders, and COTS are tossed into the ingeniously titled "substandard" category [I love that name: did you guys debate using "schlock" or "junk" or "second class" as the descriptor or was this your unanimous choice? g]. And the way I read the chart, COTS are only for regional, not national use, and only by waiver (i.e., there's no X in the Nationals column for COTS in Appendix B). Another step backward, in my view, was the rule that says only one use of a "substandard" backup device is allowed without a penalty. After that, a modest 100 point penalty is imposed each day. Sarcasm intended. Obviously no one, serious or not, will take a chance on that one. So if your primary logger fails, you better hope to borrow another primary logger immediately (like by the morning of the next day). Oh, and if it's a CAI Model 20 with a dead battery, forget it. Because although that unit met the functional requirements for a backup device last year, it was specifically crossed off the list because of the broken security seal. This year it's still allowed as a backup, but you can only use a backup once before the penalty kicks in. So the unit I borrowed in Cordele last May wouldn't have done me any good because the security seal was dead on it at the time. Sorry for the details. You see where I'm going? On the surface, "I got what I wanted." But not really. Practically speaking, if I'm serious (meaning I will only spend the $1500 to $2000 to fly a nationals--and that's sleeping in the van every night--if I want to be scored every day), I need a second RC-approved logger or guaranteed access to one on short notice. OK, I'm focused on the COTS issue. I have a long history of "constructive" criticism of mandatory flight recorder use at contests. But I did see a theme he a tendency to try toeliminate "loopholes" (like the COTS use as a backup, which I and another pilot first mentioned to another RC member a few years ago) when there's no evidence that I'm aware of that such loopholes necessarily need filling. The start cylinder arc is another issue. I'm not going to worry about it. But it does strike me as odd that we now have a rule the application thereof won't be clear until well after we start. Say what you want about the impact on points being small, but it invites cynicism and rolling of eyes. Police officer pulling over a motorist: "I know there was no posted speed limit, sir, but our computer determined that based on the traffic density, weather, road condition, and time of day that you were traveling in excess of 15 mph over the imputed speed limit of 57.2 mph. That's a $100 fine and 2 points on your license. Please drive carefully, sir." I worry that the interaction of the ever-changing Rules and WinScore (which combination actually represents the scoring system) is doomed to small failures for the simple reason that the Rules themselves and now WinScore have been patched and fixed so many times that it is difficult to test them adequately. Using the first contest as the beta test site isn't a real solution. Yes, I know we been tasked with developing test data. But as the U.S. car companies discovered years ago, you can't inspect quality in at the back end of the process. You need to change the process. That means relatively simple rules and as few changes as possible. The scoring issue I raised privately was apparently in the system all year. It affected the daily winners and order of final placings (though not the overall class winners) at Region 4 in October. I profoundly appreciate the job you guys do. The results are pretty good. But I can tell you that no one flying that I have spoken with understands the current Rules. Most pilots don't worry about it. They look at the score sheet and take what's given to them. They might ask a question if they get a penalty but that's it. The only reason we tumbled onto the problem at Region 4 is that one exceptionally honest pilot--Mike Higgins, who ought to get a sportsmanship award--allowed during his winner's speech that he had busted the floor of the finish cylinder and warned the scorer that he ought to check his calculations again. I've covered a lot of ground. I agree you have safety at the top of your list. I believe you guys believe that you consider participation with each proposed Rules change. But do you consider it the same way as if you were required to justify each economic impact on a case-by- case basis? For example, raising the deposit from $100 to $150 (the "at risk" money) and pushing the full-refund date from 14 days to 30 days prior to the contest are significant changes this year. I'm sure many contest organizers have problems with no-shows and appreciate being able to plan for tow planes better. But this reminds me of the tendency for some legislators to raise taxes higher and higher assuming revenues will increase proportionately. In this case, some contest organizers have taken a different tack: the astoundingly successful Region 4N M-ASA regional, which didn't even exist five years ago and now sucks pilots from perennial favorite New Castle, doesn't enforce the late entry penalty. Want to fly? Come on down! Different approaches. I worry that we haven't given the RC enough latitude, or perhaps the right charge, to explicitly consider participation on the same level as ensuring competition that fairly determines the national champion and US team. I don't have the magic answer. But I also don't think that raising the questions I did is insulting or disloyal to the great group of dedicated guys who serve on the RC. Chip Bearden ASW 24 "JB" USA |
I responded at length to UH's posting because I was concerned I had
communicated the wrong message. My response to some of the latest postings is pretty short, however. I've been flying competition since 1968. I consider myself to be a serious competitor even though the results don't always show it. My glider is definitely NOTexpendable. Nor do I think contest flying is dangerous. There are risks, certainly. But if I thought they were significant, I wouldn't fly. Publishing these kinds of statements serves only to increase the divide between contest pilots and those who might think of trying it but are put off by the perception that it's dangerous or insular or just too difficult. I think the Rules Committee does a superb job of considering the safety aspects of every decision they make. Chip Bearden ASW 24 "JB" USA |
On Jan 23, 4:28*pm, ZL wrote:
wrote: On Jan 23, 1:46 pm, toad wrote: I think that the decline in contest flying has NOTHING to do with the racing rules ! *And no tinkering or restraint from tinkering will change that decline. It is simply mirroring the decline of soaring in general. Todd Smith 3S You may be right, although my impression is that neither soaring in general nor the SSA membership specifically has suffered a 14%+ decline in the past four years. snip Here's some slightly different stats over previous years. The US Competition Pilot Ranking list. Including some way back, pre-GPS, early sports class years I found in my files. It gives the total number of pilots that scored in an SSA sanctioned over the previous 3 years. Smooths out some of the outlying good and bad years. 1990 - *620 1992 - *630 1995 - *550 2001 - *501 2002 - *551 2003 - *619* 2004 - *636 2005 - *636 2006 - *590 2007 - *592 2008 - *594 * The online list shows 900, hand removing obvious duplicates gives 619 Looks to me like the 20 year trend is remarkably flat. Bigger percentage of SSA members today, but maybe not a different percentage of total active glider pilots. -Dave ZL In addition to the above, we have to also admit that non-sanctioned local contests which didn't even exist on a large scale 15 years ago are a legitimate form of racing which is growing. As ZA points out in another post, the Chicago area racing scene is alive and well. Same with the Governor's Cup in the PA/NY/NJ and the GTA races. I did a quick back-of-the-envelope look at these three racing series alone and came up with well over 50 pilots who do compete - just not in SSA Sanctioned events. So, if I use even the conservative number of 50 and add that to the numbers from the last 10 years or so (when most of these series got going), you would conclude that, if anything, there's been a slight increase in racing participation since the early 1990s. Given the overall decline in the number of SSA members, one could see reason for taking an optimistic view. None of this suggests we can afford to be complacent, but I think "the reports of racing's death are greatly exaggerated. " P3 |
snip
Of course one can fly hors de concourse and have some fun, but is that really competing, or just getting in the way? * snip I think this is where a lot of pilot miss it on contest flying. They think that contest flying = competing. Of course there a a few that do really compete but I bet at most regional contests 90% of the pilots are there for the concentrated week of flying (it is easier to take a week off of work and fly), availability of tows and crew, (There are always enough people to retrieve you if you land out), the social aspect, (spending lot of time around other glider pilots), and the once every 5 years that conservative flying and luck align to let you win a day. With so many MAT and TAT tasks being called most of the time it really is a lot like just going out and flying on a regular Saturday afternoon and going where you want to. Maybe we should start calling the a regional fly-in instead of a contest. Brian HP16T |
First let me say "I have never flown in a contest, but my friends have."
A few years ago one of these friend took his well maintained Schreder sailplane to the Sport Class National contest. He is a skilled pilot and placed in the middle of the pack. At the time his EW Model D and Garmin were acceptable. For him to compete in the future he will be required to invest between 10 and 20 percent the value of his glider and trailer. What information is provided by the "approved" flight recorders that cannot be derived from a EW Model D? It appears that this type of rule's only purpose is to keep people with big buck gliders from being embarrassed by a kid flying an affordable 40 year old bird. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder wrote in message ... On Jan 23, 3:11 pm, wrote: ....Snip... Prior to 2008, if a flight recorder met the functional requirements in the Rules, it could be used as a backup. Period. We can argue about what was intended but that's what the rules said and that's what I and some others did using a cheap off-the-shelf Garmin unit. Last year the RC changed the rules: the functional specs were kept but you created three lists/classes of flight recorders and it was problematic whether COTS were accepted as backups (I was graciously granted a waiver to fly the October Region 4 contest with mine pending the RC's meeting). This year the process is complete: there are two categories of flight recorders, and COTS are tossed into the ingeniously titled "substandard" category [I love that name: did you guys debate using "schlock" or "junk" or "second class" as the descriptor or was this your unanimous choice? g]. And the way I read the chart, COTS are only for regional, not national use, and only by waiver (i.e., there's no X in the Nationals column for COTS in Appendix B). .... Snip ... Chip Bearden ASW 24 "JB" USA |
But the EW D is still an approved IGC recorder up to Diamonds, and National
Comps in most parts of the World (provided it is attached to an appropraite Garmin so that the record shows it was set to WGS84). Does the USA have different rules to IGC? At 16:25 24 January 2009, Wayne Paul wrote: First let me say "I have never flown in a contest, but my friends have." A few years ago one of these friend took his well maintained Schreder sailplane to the Sport Class National contest. He is a skilled pilot and placed in the middle of the pack. At the time his EW Model D and Garmin were acceptable. For him to compete in the future he will be required to invest between 10 and 20 percent the value of his glider and trailer. What information is provided by the "approved" flight recorders that cannot be derived from a EW Model D? It appears that this type of rule's only purpose is to keep people with big buck gliders from being embarrassed by a kid flying an affordable 40 year old bird. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
On Jan 24, 1:15*pm, Peter Purdie wrote:
But the EW D is still an approved IGC recorder up to Diamonds, and National Comps in most parts of the World (provided it is attached to an appropraite Garmin so that the record shows it was set to WGS84). Does the USA have different rules to IGC? At 16:25 24 January 2009, Wayne Paul wrote: First let me say "I have never flown in a contest, but my friends have." A few years ago one of these friend took his well maintained Schreder sailplane to the Sport Class National contest. *He is a skilled pilot and placed in the middle of the pack. *At the time his EW Model D and Garmin were acceptable. *For him to compete in the future he will be required to invest between 10 and 20 percent the value of his glider and trailer. What information is provided by the "approved" flight recorders that cannot be derived from a EW Model D? It appears that this type of rule's only purpose is to keep people with big buck gliders from being embarrassed by a kid flying an affordable 40 year old bird. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder- Hide quoted text - - Show quoted text - He can us it today- we mirror the IGC list. UH |
"Peter Purdie" wrote in message ... But the EW D is still an approved IGC recorder up to Diamonds, and National Comps in most parts of the World (provided it is attached to an appropraite Garmin so that the record shows it was set to WGS84). Does the USA have different rules to IGC? Peter, In Appendix B of the 2009 USA rules proposal the EW Model D is allowed at the Regional competitions; however, is excluded for National level competitions. For all, I woke up on the "wrong side of the bed" this morning and found this restriction to handicapped Sport Class meets especially irritating. Wayne HP-14 "6F' http://www.soaridaho.com/ |
Hank,
Forgive me, I miss read Apendix B!!! (http://www.ssa.org/files/member/2009DraftRulesv5.pdf) I hope it continues to remain a Sport Class option in the future. Sorry about that!!! Respectfully, Wayne HP-14 "6F" http://www.soaridaho.com/Schreder P.S. I knew I woke up on the wrong side of the bed this morning!!! wrote in message ... On Jan 24, 1:15 pm, Peter Purdie wrote: But the EW D is still an approved IGC recorder up to Diamonds, and National Comps in most parts of the World (provided it is attached to an appropraite Garmin so that the record shows it was set to WGS84). Does the USA have different rules to IGC? At 16:25 24 January 2009, Wayne Paul wrote: First let me say "I have never flown in a contest, but my friends have." A few years ago one of these friend took his well maintained Schreder sailplane to the Sport Class National contest. He is a skilled pilot and placed in the middle of the pack. At the time his EW Model D and Garmin were acceptable. For him to compete in the future he will be required to invest between 10 and 20 percent the value of his glider and trailer. What information is provided by the "approved" flight recorders that cannot be derived from a EW Model D? It appears that this type of rule's only purpose is to keep people with big buck gliders from being embarrassed by a kid flying an affordable 40 year old bird. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder- Hide quoted text - - Show quoted text - He can us it today- we mirror the IGC list. UH |
| Jim Weir's OSH Chairs | Jay Honeck | Owning | 4 | October 7th 06 05:44 AM |
| Jim Weir's OSH Chairs | Jay Honeck | Piloting | 6 | August 18th 06 05:34 AM |
| Jim Weir's OSH Chairs | Jay Honeck | Owning | 6 | August 18th 06 05:34 AM |
| Jim Weir's OSH Chairs | Jay Honeck | Home Built | 6 | August 18th 06 05:34 AM |
| Roger Long Titanic Discovery | john smith | Piloting | 11 | December 8th 05 08:56 PM |
