Sailplanes have of necessity a polar with min sink at speeds where
circles can be small enough to center thermals, and L/Dmax only a few knots higher. Ballast is added to raise the L/D max perhaps 10Kts higher. What might a wing look like that was built for optimum L/D @ 80-100Kts? What kind of L/D might be possible? (will this winter never end?) Mark J |
On Jan 28, 1:59*pm, Mark Jardini wrote:
Sailplanes have of necessity a polar with min sink at speeds where circles can be small enough to center thermals, and L/Dmax only a few knots higher. Ballast is added to raise the L/D max perhaps 10Kts higher. What might a wing look like that was built for optimum L/D @ 80-100Kts? What kind of L/D might be possible? (will this winter never end?) Mark J The wing you are talking about woudn't be a whole lot different than current flapped ships with the flaps in the first reflexed position. This is the target sweet spot for these ships now. UH |
Sailplanes have of necessity a polar with min sink at speeds where circles can be small enough to center thermals, and L/Dmax only a few knots higher. Ballast is added to raise the L/D max perhaps 10Kts higher. What might a wing look like that was built for optimum L/D @ 80-100Kts? What kind of L/D might be possible? (will this winter never end?) Mark J Antares 20E max L/D is already up around 70 knots. Still, there are a lot of compromises to make these modern gliders thermal well... See ya, Dave "YO electric" |
On Jan 28, 5:58*pm, DRN wrote:
On Jan 28, 1:59*pm, Mark Jardini wrote: Sailplanes have of necessity a polar with min sink at speeds where circles can be small enough to center thermals, and L/Dmax only a few knots higher. Ballast is added to raise the L/D max perhaps 10Kts higher. What might a wing look like that was built for optimum L/D @ 80-100Kts? What kind of L/D might be possible? (will this winter never end?) Mark J Antares 20E max L/D is already up around 70 knots. Still, there are a lot of compromises to make these modern gliders thermal well... See ya, Dave "YO electric" If you think just in terms of wing loading, and ASW-27 needs about 14lbs/sq ft to get best L/D up to 80 kts and 18 lbs/sq ft to get it to 90 knots. Ignore aspect ratio, Reynolds number effects, etc and take it back to wing area and you are talking about 62-79 sq ft. instead of the 98 sq ft of the -27 and an aspect ratio of 31-39 instead of the 25 on the current -27. Without doing the math, say that the aspect ratio effect outweighs the Reynolds number effect by a little bit and you get a 75-80 sq ft wing and an aspect ratio just above 30. I'm guessing with current construction techniques you could build it, but without some new airfoil innovation it might not climb very well. 9B |
On Jan 28, 9:05*pm, wrote:
On Jan 28, 5:58*pm, DRN wrote: On Jan 28, 1:59*pm, Mark Jardini wrote: Sailplanes have of necessity a polar with min sink at speeds where circles can be small enough to center thermals, and L/Dmax only a few knots higher. Ballast is added to raise the L/D max perhaps 10Kts higher. What might a wing look like that was built for optimum L/D @ 80-100Kts? What kind of L/D might be possible? (will this winter never end?) Mark J Antares 20E max L/D is already up around 70 knots. Still, there are a lot of compromises to make these modern gliders thermal well... See ya, Dave "YO electric" If you think just in terms of wing loading, and ASW-27 needs about 14lbs/sq ft to get best L/D up to 80 kts and 18 lbs/sq ft to get it to 90 knots. Ignore aspect ratio, Reynolds number effects, etc and take it back to wing area and you are talking about 62-79 sq ft. instead of the 98 sq ft of the -27 and an aspect ratio of 31-39 instead of the 25 on the current -27. *Without doing the math, say that the aspect ratio effect outweighs the Reynolds number effect by a little bit and you get a 75-80 sq ft wing and an aspect ratio just above 30. I'm guessing with current construction techniques you could build it, but without some new airfoil innovation it might not climb very well. 9B Oh, and I'd be surprised if you could get the max L/D much above the mid 50s on a 15 M ship. Of course, you'd want to cruise it well above the max L/D speed. Out west you might be able to imagine a glider that could win races optimized around 14 lbs/sq ft, but I'd think even western conditions might prove insufficient to support a glider with a best L/D design point of 100 kts, since that implies cruise speeds pretty considerably into triple digits and stall speeds and circling radii that are pretty big. 9B |
Hi All, I once read an article by a 'boffin' at Cranwell, who stated that
Vx was always 84% of Vy. In other words the two speeds are mathematically linked... Something like the inverse of the 4th root. I can understand that the induced drag increases by the inverse square, as the speed decreases, so there must be one further square root to take into effect in the equation. So if you have a high Vy then your Vx will also be high, and the glider will not turn in the thermals very tightly. Unless you can modify the wing shape, with flaps, for the two different types of flight. Pilot Pete |
I saw a glider with the Sinha (sp?) deturbulator tape this last
weekend. The owner was explaining the theory of how that works, and it seems to revolve around the turbulent stream hitting exactly at the location of this tape, which would explain why it works only at that speed. I thought about this question just after talking to him: Why not coat the whole aft 2/3 of the wing with the deturbulator material, then you would cover all the possible reattachment points? Of course, as a scientist, I wonder about the validity of any test where the proponent says that "You have to take each test individually, not aggregate them together." Sounds like anecdotal evidence to me. But, assuming that this would really work, then you could have what the owner described as a "induced drag only" wing, and it L/D would depend only on fuselage drag. So, a wing like this on a really streamlined fuselage (Diana?) might see high L/D speeds. Just my $0.02, Ed |
On Jan 29, 10:27*am, flying_monkey wrote:
I saw a glider with the Sinha (sp?) deturbulator tape this last weekend. *The owner was explaining the theory of how that works, and it seems to revolve around the turbulent stream hitting exactly at the location of this tape, which would explain why it works only at that speed. *I thought about this question just after talking to him: Why not coat the whole aft 2/3 of the wing with the deturbulator material, then you would cover all the possible reattachment points? *Of course, as a scientist, I wonder about the validity of any test where the proponent says that "You have to take each test individually, not aggregate them together." *Sounds like anecdotal evidence to me. But, assuming that this would really work, then you could have what the owner described as a "induced drag only" wing, and it L/D would depend only on fuselage drag. *So, a wing like this on a really streamlined fuselage (Diana?) might see high L/D speeds. Just my $0.02, Ed I share your skepticism - there may in fact be some favorable boundary layer effects associated with this type of surface treatment - I recall America's Cup boats used something that seemed similar about a decade ago (yes, it's a different fluid...). Nevertheless, the idea of totally eliminating form drag is overreaching by a lot methinks. I remember Helmut Reichman won the 1978 Worlds in France, flying the Akaflieg Braunschweig-built SB-11 which had slotless fowler flaps that could increase the wing area by about 25-30%. The design opted for improved low-speed performance as the 15M glider had an aspect ratio of around 17 with the flaps fully deployed. Deploying the flaps took some cranking I recall. That's all fine for Europe I guess, but this discussion does raise for me the idea of a glider that uses the same concept to give you climb comparable to existing gliders with a 10-15 knot higher cruise speed. It could be really interesting out west where the thermals are strong enough that a few ft/min of lower minimum sink would be a lot less advantageous than a higher inter- thermal cruise speed. Now if you could just fit all that mechanism into a 30:1 aspect-ratio wing with a 12% thickness ratio and still have room for ballast (can you add Epsom salts to water ballast?). 9B |
On Jan 29, 1:27*pm, flying_monkey wrote:
I saw a glider with the Sinha (sp?) deturbulator tape this last weekend. *The owner was explaining the theory of how that works, and it seems to revolve around the turbulent stream hitting exactly at the location of this tape, which would explain why it works only at that speed. *I thought about this question just after talking to him: Why not coat the whole aft 2/3 of the wing with the deturbulator material, then you would cover all the possible reattachment points? *Of course, as a scientist, I wonder about the validity of any test where the proponent says that "You have to take each test individually, not aggregate them together." *Sounds like anecdotal evidence to me. But, assuming that this would really work, then you could have what the owner described as a "induced drag only" wing, and it L/D would depend only on fuselage drag. *So, a wing like this on a really streamlined fuselage (Diana?) might see high L/D speeds. Just my $0.02, Ed NO Winter is cold enough to have this topic come up again. Let it die the death it deserves. The only think that has no form drag is a thing that has no size. UH |
Speed Astir | Jono Richards | Soaring | 3 | March 25th 06 07:19 AM |
One way to speed up a Fly Baby | Ron Wanttaja | Home Built | 4 | March 23rd 06 08:01 AM |
'Speed Pants'... | .Blueskies. | Home Built | 14 | December 14th 05 04:02 AM |
763 Cruising Speed. | [email protected] | General Aviation | 24 | February 9th 04 09:30 PM |
AI... is it speed consuming??? | Jesper Andersen | Simulators | 0 | October 3rd 03 11:24 AM |
