SLOL/LSA Expectations
Old February 6th 09, 12:55 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default SLOL/LSA Expectations
stol wrote:
On Feb 4, 6:16 pm, Brian Whatcott wrote:
Peter Dohm wrote:
... if
you are willing to accept the as-delivered reliability of the automotive
FADEC systems, which have become very good, then the primary issue would be
lead fouling of the oxygen sensor...
Peter
Yes.
It is not contentious to mention that the longevity of auto engines has
increased by leaps and bounds since the advent of FADECs.
Longevity does not equate to reliability exactly, but electronic
ignition has been helpful, I believe crucial in fact, and mechanical
design of self adjusting lifters is no longer a black-art. It seems to
me that the water-cooled engine can be made to cope with the high
rejected-heat associated with high throttle operation. There is still a
question in my mind about the heat-shedding arrangements for lube oil
but an oil radiator is nothing new, and exhaust valves would benefit
from some premium qualities.
Brian W
You are right in your thoughts,,, I fly one almost every day to prove
your point....
Ben
www.haaspowerair.com
http://video.google.com/videoplay?do...50730841&hl=en
Some good looking FWF pictures. When I see the big V-8, I ask, how
heavy? how many hours before MOH?
Brian W
Old February 6th 09, 01:30 AM posted to rec.aviation.homebuilt
Anthony W
your point....
Ben
Is that a 302 Ford? I know that Ford has or at least had an aluminum
block 302 V8 on special order. Is that what you're using?
I take it that PRSU is a belt drive? It's hard to be sure from the pix.
Anyway it's a nice looking setup. I think it would be even nicer in a
full scale Storch replica...
Tony
Diana-2 VH-VHZ, Expectations BlueCumulus[_2_] Soaring 1 July 28th 07 08:17 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
