Engine Certification
Old February 16th 09, 12:36 AM
aerojones aerojones is offline
Junior Member
First recorded activity by AviationBanter: Feb 2009
Default Engine Certification
Hi,
Could anyone give me a brief overview of the benefits of buying a certified engine over a non-certified engine? Why do manufacturers sell both? Price difference? Does the owner have to get the engine certified after purchasing?
Thank you for your help
Old February 16th 09, 04:17 PM posted to rec.aviation.owning
BT
More information needed.
What country?
Into which airframe is it going?
A certified engine/propeller combination into a kit built aircraft may
shorten the certification process for the aircraft.
An non certified engine/propeller combination into a kit built aircraft
could lengthen the certification process and procedures for the aircraft.
In the US, a non certified engine into a "standard" certified aircraft could
impact (limit) the future use of that aircraft to non commercial
applications.
"aerojones" wrote in message
Hi,
after purchasing?
aerojones
Old February 16th 09, 10:54 PM posted to rec.aviation.owning
BT
"Peter" wrote in message
could
applications.
I think it would be a bit more serious than that
True.. putting in an engine that is outside of the TCDS will require
paperwork, 337 field approval and all of that.
If there is already an STC for that engine in that airframe.. it's a tad
easier..
But in any case.. a non certified engine.. even if approved for
installation.. could remove the aircraft from commercial services.
Old February 18th 09, 06:46 PM posted to rec.aviation.owning
Robert M. Gary
applications.
Huh??? Either the engine is approved (by STC or by the FSDO
(unlikely)) or its not. There is no seperate standard in the US to
allow a certified airplane to run an non-certified engine..
-Robert
Old February 18th 09, 06:47 PM posted to rec.aviation.owning
Robert M. Gary
If the gov't requires you to use a certified engine you must use a
certified engine. If it does not there is no reason to use a certified
engine. The price difference is the cost of getting the gov't
certification (which also usually means the engine is less advanced
since certificating authorities hate dealing with advancements). For
instance an IO-360 vs the same Lycoming engine for experiementals, you
would never buy the certified IO-360 unless you are required to.
-Robert
On Feb 15, 4:36*pm, aerojones
Hi,
after purchasing?
aerojones
IFR GPS certification nobody Instrument Flight Rules 17 March 16th 05 04:16 AM
IFR GPS certification nobody Owning 14 February 28th 05 04:07 PM
FAA Certification fred D Soaring 7 June 15th 04 03:01 PM
Pitts Certification moby Aerobatics 2 February 4th 04 01:26 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
