#11
On Feb 15, 4:34*pm, Brian Whatcott wrote:
. . . a corrosion preventative that sets waxy, like BoeShield T-6 aerosol would be better. Veeduber had it right. With the kerosene, you take the canvas off, use the lathe, sweep up the chips and cover it again. With the waxy stuff, you must remove it from any working surfaces before you can use the lathe. It's formulated to be difficult to remove. You'll end up not using the lathe for small jobs. Rich S. |
![]() "Stuart Fields" wrote Second to Jim. Zemlock helicopters at Chino showed me one of those Insecticide sprayers used to clean up his D model Bell 47, which if they could ever find a crop that could use engine oil, would find it's niche. No spray booms required. The sprayer worked like it was designed for the task. Actually, many (most) garden sprayers will not last long using any petro-chemicals. You can get one from a concrete supply company that is designed to spray concrete post treatment, that is petrochemical proof, or find a sprayer for treating decks with waterproofing at a lumber supply house. -- Jim in NC |
Maxwell wrote:
Kerosene works well, depending on how often the machine is used. But you can greatly extend it's effectiveness by adding a percentage of oil to suit you needs. Although most effective, adding wax would probably leave a film that would have to be removed before each use. I went looking for Boeshield T-6 or LP-3 in town today. No joy. But I did find silicone sprays which I don't like, and this aerosol from 3M called "5-WAY". The label says aliphatic hydrocarbon (which I assume is kerosene), petrolatum and heavy parrafinic oil. It says it leaves a sticky surface. That's better than nothing..... Brian W |
On Feb 16, 3:00*pm, Brian Whatcott wrote:
It says it leaves a sticky surface. That's better than nothing..... ------------------------------------------------------------------------------------------------------------ Most of the comments are coming from people who have never used kerosene & a flit-gun to protect their machine tools. I suggest you try it before wandering off in all directions. Kerosene is called 'paraffin oil' for a pretty good reason: As the kerosene evaporates it leaves behind a layer of WAX. It is the layer of wax that protects the surfaces of your machine tools. Cleaning it up is no problem. Simply re-spray and wipe it off. Some times the 'old ways' are best. I think you'll find this is one of those times. -R.S.Hoover |
"Bryan Martin" wrote in message
... In article , cavelamb wrote: Peter Dohm wrote: "Brian Whatcott" wrote in message ... wrote: I would not dream of putting a machine lathe in an unheated workshop where the ways might attract a layer of rust. -------------------------------------------------------------------------- You might also try LPS-3, if I recall correctly--or was it LPS-2. In any case, I believe that the one that gets waxy is also fairly popular for spraying in pick-up truck beds before istalling a bed-liner. Peter That's LPS-3. But I can't find it anywhere locally. There's also a product called Dow Corning (or Molykote) metal protective coating. It's an organic wax dissolved in a solvent in an aerosol can. It seems to only be available from industrial supply companies. I did find a place to order it online but they only sell case lots. -- Bryan Martin N61BM, CH 601 XL, Ram Subaru, Stratus redrive. LPS-3 seems to be available from various sources on line as well--and in container sizes up to a gallon. But I don't know of any place to just pick it up on my way home. Peter |
I understand this objection. But I have an objection to WD-40 or straight kerosene. It evaporates. Then here comes the FeO2 (At least, that's what I have in mind - I would be pleased to hear I'm wrong on this one...) Brian W Try a 50/50 mix of automatic transmission fluid and kerosene. You will be amazed how well it both lubes and protects against rust. Tony |
![]() "Anthony W" wrote in message ... Brian Whatcott wrote: I understand this objection. But I have an objection to WD-40 or straight kerosene. It evaporates. Then here comes the FeO2 (At least, that's what I have in mind - I would be pleased to hear I'm wrong on this one...) Brian W Try a 50/50 mix of automatic transmission fluid and kerosene. You will be amazed how well it both lubes and protects against rust. And if there is paint on the machine that is not bake on, epoxy, or powder coat, it can also remove the paint. -- Jim in NC |
wrote: ... buying a lot of metal-working tools doesn't mean you'll be turning out usable parts. ... So instead of day-dreaming about a 48" metal brake from Harbor Freight that you'll probably never buy anyway, why not pick up a piece of angle iron and start LEARNING how to do metal-work.... -R.S.Hoover There is another outcome possible at Harbor Freight - other than the day-dream ending. Like me, you may BUY a tool. I am thinking of the tube bender I bought. I KNEW that the usual tube bender that features a ram pushing a forming tool against a pipe while two side rollers hold it in place - is a disaster - it is about guaranteed to collapse the wall unless the tube is loaded with sand, ice, eutectic - whatever. So I bought the BETTER type tube bender on sale. This has a roller that pulls the tube round a die - this provides the motivation to stretch the tube wall on the outside, rather than ripple the tube wall on the inside of the turn. So fine: I bought it, and I bought a tube drilling jig, to make those nicely fitted tube joints at 90deg, 45 deg etc....and plenty of other things too. What's wrong with that? I haven't used these tools at all. Not once. And now I covet a machine lathe too (there could hardly be a more bargain deal for $400 after all). Trouble is, Momma would have conniptions if I put it in my study, and I would not dream of putting a machine lathe in an unheated workshop where the ways might attract a layer of rust. That would about break my heart..... Brian W One of the advantages in living alone in a house is one of my bedrooms is my machine shop. It's more comfortable than a garage and cheaper than a climate controlled shop. Dan, U.S. Air Force, retired |
Marking sheetmetal | Michael Horowitz | Home Built | 41 | September 23rd 06 05:25 PM |
Conservative friends of aviation at work | Paul Tomblin | Instrument Flight Rules | 2 | April 30th 05 04:30 PM |
Did your ELT work? | Eric Greenwell | Soaring | 11 | June 24th 04 02:45 PM |
where's the THRILL is flying, rec.aviation.balloon, rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring | BW | Rotorcraft | 0 | October 15th 03 11:42 AM |
