#31
Brian Whatcott wrote:
Dan wrote: ... One of the advantages in living alone in a house is one of my bedrooms is my machine shop. It's more comfortable than a garage and cheaper than a climate controlled shop. Dan, U.S. Air Force, retired But who cooks breakfast? Oh, yes. I do! :-) (Unfair to my beloved - she cooks and washes up after me without cease.) B I'm a hermit by choice. The truly amazing thing is I have survived my own cooking. My meals are almost as good as C rats or LRRP rats. Dan, U.S. Air Force, retired |
#32
Copperhead wrote:
On Feb 16, 6:07 pm, Anthony W wrote: Brian Whatcott wrote: Brian W Try a 50/50 mix of automatic transmission fluid and kerosene. You will be amazed how well it both lubes and protects against rust. Tony If anything is siezed the auto trans fluid will free it up quick. In addition to removing paing it also likes to clean up rust. Joe S. But explosives are much more satisfying for un-seizing. All seriousness aside, in my gun smithing days I had a Krag come in with it's bolt rusted shut. Transmission fluid released it. I have no idea how long it actually took since I soaked it over night. Dan, U.S. Air Force, retired |
#33
Copperhead wrote:
Try a 50/50 mix of automatic transmission fluid and kerosene. You will be amazed how well it both lubes and protects against rust. Tony If anything is siezed the auto trans fluid will free it up quick. In addition to removing paint it also likes to clean up rust. Joe S. Well - something else I hadn't heard before! Thanks B |
#34
![]() "Anthony W" wrote The 50/50 kerosene and ATF is an old formula for a gun oil and short term preservative. I didn't even think about it being bad for paint but it has worked great on my rifles for many years. Yep, but on guns, there is linseed oil or varnished stocks, and gun blue, or polished metals, with no paint. It would be possible to kero down most machines, and stay away from what little paint is on most of them. A rag soaked in it, or a sponge would be as quick, and cover 98%, with a squirt here and there where rags will not reach. -- Jim in NC |
#35
![]() "Morgans" wrote in message ... "Anthony W" wrote The 50/50 kerosene and ATF is an old formula for a gun oil and short term preservative. I didn't even think about it being bad for paint but it has worked great on my rifles for many years. Yep, but on guns, there is linseed oil or varnished stocks, and gun blue, or polished metals, with no paint. It would be possible to kero down most machines, and stay away from what little paint is on most of them. A rag soaked in it, or a sponge would be as quick, and cover 98%, with a squirt here and there where rags will not reach. -- Jim in NC The shop I once worked in had, for nearly sixty years, ordered a Friday-afternoon last shift ritual where the chips were all shoveled out, and every machine was entirely sprayed down with kerosene. That was a routine that was only halted when the accumulated fine dust on the roof trusses and rafters was finally so slopped with kerosene and it all caught fire and took the roof right off the shop. That also was the end of all the overhead shafting that had remained unused for twenty-five years, the lights and most of the machine power wiring. Oh yeah, the shop was shut down for ten days. The local Firefighting And Barbecue Society was impressed. (Their motto at the time was "If we don't light 'em, we don't fight 'em") Flash |
#36
![]() The shop I once worked in had, for nearly sixty years, ordered a Friday-afternoon last shift ritual where the chips were all shoveled out, and every machine was entirely sprayed down with kerosene. That was a routine that was only halted when the accumulated fine dust on the roof trusses and rafters was finally so slopped with kerosene and it all caught fire and took the roof right off the shop. That also was the end of all the overhead shafting that had remained unused for twenty-five years, the lights and most of the machine power wiring. Oh yeah, the shop was shut down for ten days. The local Firefighting And Barbecue Society was impressed. (Their motto at the time was "If we don't light 'em, we don't fight 'em") Flash Appropriate Sig, there.... |
#37
On Sun, 15 Feb 2009 13:35:56 -0800 (PST), "
wrote: ----------------------------------------------------------------------------------- I would not dream of putting a machine lathe in an unheated workshop where the ways might attract a layer of rust. ----------------------------------------------------------------------------------------- So buy a Flit gun and 5 gallons of kerosene. After using the lathe, pump up the Flit gun and give the lathe a light coating of kerosene, then cover it with a piece of canvas that is NOT allowed to touch any unpainted surface. -Bob PS -- Can't find a Flit gun? Then use one of those refillable aerosol cans... or use an air-brush. my lathe sits in an unheated workshop. when the workshop was an asbestos cement shed I had moisture problems. now I have a colourbond tin workshop, still unheated, and all I use is shell tellus 46 on the slideways and a thick plastic sheet draped over it. the plastic being impervious to moisture unlike the canvas. the poms who have your snow merely put a cover over the lathe and sit the smallest light globe they can find down in the ways. probably about 15 watts. the heat from that keeps the lathe and the air around it just above ambient temperature and prevents condensation. if you are really desperate spray a lathe under plastic with CRC or WD40 and it should be ok. stealth pilot |
Marking sheetmetal | Michael Horowitz | Home Built | 41 | September 23rd 06 05:25 PM |
Conservative friends of aviation at work | Paul Tomblin | Instrument Flight Rules | 2 | April 30th 05 04:30 PM |
Did your ELT work? | Eric Greenwell | Soaring | 11 | June 24th 04 02:45 PM |
where's the THRILL is flying, rec.aviation.balloon, rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring | BW | Rotorcraft | 0 | October 15th 03 11:42 AM |
