Legal? - SPOT Helium Balloon Race
Old March 3rd 09, 07:03 AM posted to rec.aviation.soaring
Jim Logajan
Default Legal? - SPOT Helium Balloon Race
"Paul Remde" wrote:
I was planning on including a parachute
so it won't land hard if all the balloons pop,
I presume the parachute (or perhaps a simple cloth drogue?) would already
be deployed - it'd hang limp (most of the time) till needed.
But I don't want to do it if it is not safe, or not legal, etc. I
don't want to "take my chances" that it will be safe - unless the
risks are miniscule.
As far as I can tell it can be done legally since a SPOT allegedly weighs
only 209 gms (~7.4 oz) and the smallest surface is ~4.7 in^2, or ~1.6
oz/in^2 -- well under the 3 oz/in^2 specified by 101.1(a)(4)(i). (Numbers
extracted from the specs on the SPOT web site.)
I'd be mindful of 101.7 when determing when and where to launch. I'd launch
in clear weather and use 101.33 as a guideline (even though it isn't
applicable to such a small balloon.) So if the worst happens I'd have shown
intent to not launch in a hazardous manner.
I don't know what the probability is of it causing an accident, but I'd
guestimate it is indeed miniscule. Infinitesimal probability of a
collision, multiplied by a small amount of damage, multiplied by the
probability that small amount of damage yields fatalities.
Bottom line is I would not personally have any issue if such a balloon were
launched while I was in any sort of aircraft in the same area.
Old March 3rd 09, 01:38 PM posted to rec.aviation.soaring
Andy[_1_]
On Mar 2, 11:18*pm, Jim Logajan wrote:
I believe you've misread the regulations by not reading 101.1. That is
where it states:
True, I missed that. It would appear that only 101.7 is applicable
given the mass of SPOT. That looks like an FAA wild card to be played
anytime they want.
Andy
Old March 3rd 09, 02:09 PM posted to rec.aviation.soaring
Paul Remde
Thank you everyone for the interesting and informative posts.
While it may be legal and would be safe 99.999% of the time, I think I'll
scrap the idea. I would never want it to cause any issues.
Good Soaring,
Paul Remde
"Jim Logajan" wrote in message
Andy wrote:
On Mar 2, 4:24 pm, Jim Logajan wrote:
Why not? Last I checked, balloon launchers had an equal right to use
the public airspace as anyone else. (In the U.S. part 101 contains
the regulations pertinent to safe operations of balloons.)
The operation described by the OP does not appear to be compliant with
101 subpart D. Perhaps he left out all the details that would make it
compliant. Perhaps he'd post again telling us how he intends to
comply.
where it states:
"This part prescribes rules governing the operation in the United States,
of the following:
(4) Except as provided for in 101.7, any unmanned free balloon that ...
So the "applicability" in 101.1 specifies the criteria that must be met
for _any_ of the remainder of Part 101 to be applicable.
Now in 101.31 in "Subpart D" it states "This subpart applies to the
operation of unmanned free balloons." But that subpart _isn't_ applicable
if the conditions in 101.1 aren't met. (Because it is a _subpart_.) If it
were applicable, then according to 101.33(d), anyone releasing something
as small as a helium party balloon in a town would be in violation of the
FARs.
When properly read, according to 101.1 any unmanned free balloon under 4
lbs of payload that presents suitably large surface areas is not subject
to any Subparts of Part 101.
I've been startled by party balloons when flying power planes in
the Phoenix area. They wouldn't hurt if I hit one. I don't relish
the idea of getting a spot through the prop or windshield.
I hate to break it to you, but you are more likely to run into a bird
than a balloon of any sort. Or even another manned aircraft.
Maybe that's because unmanned balloon operations are regulated by 101
subpart D. The flight of birds is, to the best of my knowledge,
unregulated.
A SPOT weighs 209g. It has a density less than water (it's designed to
float.) Might dent the prop or crack the windshield, but can't see it
causing a serious hazard. (You can save the prop from significant damage
but shutting off the engine and gliding. ;-))
And as I said, Subpart D of Part 101 isn't applicable to all unmanned
balloon operations. Small balloons meeting the criteria of 101.1(4) are
not covered by Part 101. The balloon the OP proposes could no doubt be
easily made to comply. And since the OP is a pilot would no doubt perform
the operation as safely as feasible.
Old March 3rd 09, 02:41 PM posted to rec.aviation.soaring
vontresc
scrap the idea. *I would never want it to cause any issues.
Good Soaring,
Paul Remde
101 subpart D. *Perhaps he left out all the details that would make it
compliant. *Perhaps he'd post again telling us how he intends to
comply.
where it states:
of the following:
FARs.
unregulated.
the operation as safely as feasible.- Hide quoted text -
- Show quoted text -
This is a bit off topic, but I found this neat project while googling
for balloon info yesterday.
http://www.members.shaw.ca/sonde/
These guys launched an RC glider to 65k' via a balloon. Cool Stuff!
Pete
Old March 3rd 09, 06:22 PM posted to rec.aviation.soaring
Eric Greenwell
Default Robot model glider launched at 65,000'
What a fascinating project!
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 4th 09, 05:32 PM posted to rec.aviation.soaring
lrbj
This might be an excellent and cheap way to have a local temp
trace!
Lars
Old March 4th 09, 06:21 PM posted to rec.aviation.soaring
sisu1a
Actually 20k' cooler, it was launched to 85k'!
-Paul
Old March 4th 09, 07:35 PM posted to rec.aviation.soaring
But I don't want to do it if it is not safe, or not legal, etc. *I
With the right size balloon you might be able to fit the Spot inside
the balloon envelope. I'm guessing that would reduce the chances of it
striking anything directly as the upwash ahead of any moving object
would tend to deflect it - plus you get a built-in airbag. Anyone
who's seen a balloon on a freeway can understand that.
As to the turbofan scenario - jet engines are designed to eat birds up
to 5 lbs (as Capt Sully found out to his dismay, geese are bigger). I
can't imagine a Spot is any tougher than a duck. You'd get some damage
I'd bet, but I doubt it'd be catastrophic.
With a little effort you could balance things so the balloon didn't
get into the Class A. For instance a small pinhole would allow helium
out at a rate to ensure that the balloon didn't get too high or go too
far - how long a chase do you want anyway? If you release it away from
and downwind of any significant terminal areas your odds of hitting
anything are infinitesimal.
Given all the time lags associated with Spot messages I doubt you'll
be able to track the thing close enough to actually see it until it's
already on the ground. Also, you'd have to worry about lakes and maybe
forests as possible unhappy endings. Without a good wide area wireless
connection you will have trouble tracking it in real time from the
road, so you'll have to wait for it to land, get a fix and go find it.
Overall it sounds a bit like you've run out of ways to entertain
yourself over the winter. ;-)
9B
Old March 5th 09, 12:14 AM posted to rec.aviation.soaring
Eric Greenwell
Assuming you mean "wireless" as used for computer communication, that
may not be a limitation: SPOT service can be set to send text messages
with the coordinates to your cell phone, which usually has a lot more
coverage. The truly determined could rent/borrow a satellite phone for
the day of the flight. SPOT floats - tow a boat with your retrieve vehicle!
Old March 5th 09, 01:48 AM posted to rec.aviation.soaring
Darryl Ramm
* "Transponders in Sailplanes"http://tinyurl.com/y739x4
* * * Sections on Mode S, TPAS, ADS-B, Flarm, more
You are going to want to hang the spot under the balloon some
distance, maybe on a little platform so the thing can be oriented
pointing roughly up for best GPS reception (not really an issue) and
best GlobalStar coverage (more of an issue).
Eric's idea of SMS message to an Iridium phone sounds sexy if you are
really remote. However SPOTcast/tracking only works to the internet
and won't transmit position data to SMS or email. So you will have to
modify the SPOT to "press" the OK button. Very simple to hack for
somebody with electronics skill, but encouraging this might annoy
SPOT, Inc. You'd need to find out if SPOT supports SMS to Iridium
numbers. Many places do, people even twitter to them etc.
My perception is that many of the SPOT position delays that Andy
mentioned are associate with the SPOT web pages, SMS and email
messages may get thought faster. It would be great to know if anybody
has hard data on this.
The problem on landing is the SPOT is unlikely to land upright
oriented with sight of the satellites so the best you may get is a 10
minute old position fix which may or may not be enough to find the
unit.
The idea of launching some balloons with small cameras etc on them as
a project with kids is quite interesting.
Darryl
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
Al(Race Card) Sharpton and Jesse (Race Warlord) Jackson GetErDone Piloting 1 December 8th 07 09:22 PM
I need materials to make helium balloons. John Doe Home Built 19 December 7th 04 05:51 AM
Best small balloon material for containing helium? John Doe Home Built 7 December 3rd 04 09:42 PM
How much weight will 15 ft.³ of helium lift? John Doe Home Built 1 December 3rd 04 04:07 PM
