*********A DEFENCE FOR MXMORAN***********
Old March 5th 09, 12:11 AM posted to rec.aviation.piloting
Ibby
Default *********A DEFENCE FOR MXMORAN***********
Not shown are the dozens of switches and buttons on the overhead
panel.
Jim Pennino
Remove .spam.sux to reply.
Apart from lighting controls the overhead panel isn't required much
during flight and only necessary for pre-flight and engine start. It
of course requires monitoring with fuel systems being configured for
tank/engine when required but apart from that no real input from the
pilot. Most of the work is via the MCP on the glareshield and the FMC
Ibby
Old March 5th 09, 12:18 AM posted to rec.aviation.piloting
Ibby
It's been two hours staring at that screen (NOT) and I am still
looking for the altitude hold button LOL *I'za along with the 100's of
passengers would have been dead 118 minutes ago looking for that durn
thing.
See the '10000' on the MCP (the linear panel along the length of the
window)
Below that is a knob rotate it left to assign a lower altitude and
right to increase, below this knob is a button which clearly says
'HOLD'
There is also a 'HOLD' button below Heading too which means the
aircraft can retain a set heading or altitude whilst you change to the
next desired, pressing Heading Select will result in the aircraft
turning at a time of your choosing rather than the second you touch
the knob and VS (Vertical Speed) switch will start the aircraft
climbing or descending at a choosen rate when this is pressed too.
Ibby
Old March 5th 09, 12:30 AM posted to rec.aviation.piloting
Ibby
Your statement was obvious nonsense from looking at the picture of
a real airplane.
Afraid MX is correct on this one. The overhead panel on 737's and
747's handle the IRS's (Inertial Referencing System, these are like
GPS), Hydraulics Systems, Battery and Electrical power system, fuel
control systems, engine autostart systems and continuous ignition if
visible moisture is present,anti-ice, pressurisation and air
conditioning systems, fire control system and internal and external
lighting controls. They do NOT control the atitude and etc of the
aircraft and require little input after takeoff. The Flight
Management Computer controls the majority of the flight by taking
control of the autopilot and autothrottle systems. The Mode Control
Panel which has 13 buttons, 4 knobs and 2 switches for the Flight
Director and Autothrottle are really all that is required for input to
manually over-ride the active flightplan in the FMC.
Airline pilots use this method when vectored into an airport by ATC,
or when given specific headings to follow or altitude and speed
restrictions
Ibby
Old March 5th 09, 12:34 AM posted to rec.aviation.piloting
Ibby
No one can reguilarly crash and die.
True. *It's a different pilot each time.
Sorry but that is funny observation ;-)
Ibby
Old March 5th 09, 01:15 AM posted to rec.aviation.piloting
a real airplane.
His original statement was there are only a dozen or so switches and
buttons.
If you look at the entire panel, there are a lot more then that.
restrictions
Ibby
Jim Pennino
panel.
Jim Pennino
Ibby
No one said it was required during flight.
The point of contention is how many switches and buttons are present
and have to be looked at to find a particular one, not what they do.
Jim Pennino
Old March 5th 09, 03:08 AM posted to rec.aviation.piloting
Maxwell[_2_]
"Mxsmanic" wrote in message
I'm talking to a pilot who largely admits having no clue about 747s, but
that
doesn't stop him from talking about them.
As opposed to a dumb assed, non-pilot that has no clue about a 747.
  #29
Old March 5th 09, 03:13 AM posted to rec.aviation.piloting
Maxwell[_2_]
-b- writes:
Fortunately, safe pilots are not so brazen. Instead of testosterone to
assert
knowledge, they rely on documentation and they cross-check.
They can do that with simulation alone.
Prove it moron.
  #30
Old March 5th 09, 03:17 AM posted to rec.aviation.piloting
Maxwell[_2_]
BeechSundowner writes:
Some people will, but they have to start with an open mind.
Waaaaaaaaaaaaaa, says the poster child for those with a closed mind.
There goes another irony meter.
[email protected] Glenn Alderton[_2_] Aviation Photos 14 January 5th 07 02:35 AM
UK Defence Shakeup Ian MacLure Military Aviation 0 July 22nd 04 03:40 AM
U.S. pilot has new defence Otis Willie Military Aviation 0 June 30th 04 10:50 PM
Bulldozing US Homeland Defence. Tamas Feher Military Aviation 44 June 13th 04 10:12 PM
USA Defence Budget Realities Stop SPAM! Military Aviation 17 July 9th 03 02:11 AM
