Radio altimeter fault triggered Turkish Airlines crash
Old March 7th 09, 12:52 AM posted to rec.aviation.piloting
Robert Moore
Default Radio altimeter fault triggered Turkish Airlines crash
Dave Doe wrote
It was suggested (stated I spose) by another poster here that "most"
landings are autolands. I categorically disagreed with that statement.
Air New Zealand do about 1 in 7 autolands.
What ratio did you do?
Probably about 1 in 20. The company would have liked more, but that
took all of the fun out of flying.
Bob Moore
  #34
Old March 7th 09, 02:20 AM posted to rec.aviation.piloting
Just go look it up!
On Sat, 07 Mar 2009 00:49:41 GMT, Robert Moore
wrote
The shuttle does an autoland approach and touches down manually.
Not according to Wikipedia.....
From Wikipedia, the free encyclopedia
In aviation, autoland describes a system that fully automates the landing
phase of an aircraft's flight, with the human crew merely supervising the
process.
With 25 years of airline experience flying Boeing jetliners, I would
suggest that I know more about "autoland" operations and equipment than
either you or MX.
More from Wikipedia.....
Autoland requires the use of a radio altimeter to determine the aircraft's
height above the ground very precisely so as to initiate the landing flare
at the correct height (usually about 50 feet).
Autoland is highly accurate, and it lands the plane at the same spot on the
runway every time with very high accuracy. This is in contrast to manual
landings, where touch down points are relatively widely distributed within
the Touch Down Zone on the runway.
Bob Moore
PanAm (retired)
the problem here seems to be the inappropriate substitution of
"coupled approach" with "autoland" by certain people.
  #35
Old March 7th 09, 08:22 AM posted to rec.aviation.piloting
Mxsmanic
writes:
Yeah, right.
I know, thanks.
It is routine to turn on autoland during approach and turn it off just
before touchdown.
If you turn it off, it's not autoland.
  #37
Old March 7th 09, 01:21 PM posted to rec.aviation.piloting
Robert Moore
Yep!
Bob
  #38
Old March 7th 09, 07:45 PM posted to rec.aviation.piloting
Mxsmanic wrote:
writes:
There's no such thing as an "autoland approach." You can automate the
approach, but if the automation doesn't take you to touchdown, it's not an
autoland.
Funny, the FAA seems to think otherwise:
http://www.faa.gov/airports_airtraff...pubs/PCG/A.HTM
From the ink:
"AUTOLAND APPROACH- An autoland approach is a precision instrument
approach to touchdown and, -IN SOME CASES-, through the landing rollout."
Emphasis mine.
Wrong again.
Jim Pennino
Remove .spam.sux to reply.
  #40
Old March 8th 09, 12:55 PM posted to rec.aviation.piloting
Dave Doe
says...
writes:
Yeah, right.
I know, thanks.
before touchdown.
Like most landings eh?
Duncan
Manchester (EGCC) Turkish Airlines TC-JRA Andrew B Aviation Photos 0 May 29th 08 08:01 PM
ATC radio for cabin on airlines besides United? [email protected] Piloting 1 May 1st 06 10:48 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
Thunderbird pilot found at fault in Mountain Home AFB crash Ditch Military Aviation 5 January 27th 04 01:32 AM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
